10-29-2014, 11:16 AM | #1 |
Rep 554
Alternate wheels for winter
Car came w/ staggered 398 wheels 18x8 et 34 in front on 225/45 tires and 18x8.5 et47 in rear on 255/40. Original plan was to use these same wheels w/ a set of Blizzak WS80 tires 225/45/18 all around. However, TireRack is showing that I can also use 215/55/17 tires which is .34" taller. Narrower tire we all know is better through the snow. This 17" set up is also about $140 cheaper.
So in looking for 17" wheels, I'm finding many sets for $150-$250 from E36's and E46's. Which is the ideal or acceptable offsets? I'm thinking et34-et38 should be good? Many sellers don't know the offset of the wheels they're selling, just that they came off a specific vehicle. Where can I find what the original wheel offsets were say on an e36 M3, e36 328i or e46 325ci? I also found a set from an e60 530xi that has an et43, would that work?
Boston CCA 383036
'20 M340i '18 MB GLS550 '07 4Runner V8 Limited 4WD |
11-01-2014, 04:11 AM | #2 |
Rep 554
For those following this thread, I've narrowed my search to finding a set of 17" wheels w/ an offset around et37. 37 seems to be the ideal number for our car so anything in the 34-40 range should not be a problem. Hope this info helps others out there. Keep in mind that I have a 320 w/ rwd & the 312mm brakes. Those w/ awd or larger brakes, 345 or 370mm brakes are going to have different results.
Boston CCA 383036
