BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > F10 N20 JB4 Drivetrain Malfunction Error
      07-18-2014, 01:14 AM   #1
tinghei
Drives: f10 528i
Hi All,
I recently upgraded my stage 1 to JB4 but when I plugged in the JB4 I kept getting a Drivetrain Malfunction error but I don't see any active error code thru OBD..... email Jon from Burgertuning.... he said it should be just plug and play.... He said I have to get the USB cable first to see what's going on......
Any of you experienced this before????
      07-18-2014, 02:23 AM   #2
Chris@codemybimmer
Chris@codemybimmer's Avatar
Drives: AW F30 328i Xdrive
Originally Posted by tinghei View Post
Hi All,
i got drive train malfunction when i went from stage 1 to JB4 as well.
turned out when i installed it i accidentally swapped the CAN wire connection.
      07-18-2014, 04:02 PM   #3
tinghei
Drives: f10 528i
Can you show me a picture if possible?
      07-19-2014, 03:00 AM   #4
Chris@codemybimmer
Took this form BMS install guide.
i accidentally swapped these two and got that problem.
also make sure your MAF sensor is unplugged, you dont need it for the stage 2
      07-21-2014, 12:28 PM   #5
tinghei
Drives: f10 528i
THanks..... Got it figured it out..... The dealer mechanic had mess with the wiring before and they had reversed the wastegate connector.....
