07-29-2017, 03:54 PM | #1 |
Moderator
429
Rep 465
Drives: E46 M3 / E92 M3
Tail Light Connector Plug Part #
Hi. Does anyone know the part number for the 6-pin tail light housing connector plug for the driver side? My ground pin burned out and I'm trying to replace it. Here's an image below.
[Track] 03 AW/CIN 6MT E46 M3
[Street] 08 AW/FR 6MT E92 M3 [Tow/Overland] 23 Toyota Tundra HV TRD Off-Road |
07-29-2017, 11:57 PM | #2 |
Rep 54
f30_adler had the same issue and found the new connector. Maybe message him at this post:
http://f30.bimmerpost.com/forums/sho....php?t=1405916
2015 328i M-Sport - Wagner FMIC, ER Charge Pipes, JB4, Injen CAI, Wagner DP, M-Performance spoiler, M-Performance LED Tail Lights, H&R sport springs, Bilstein Shocks, M-Perfomance Exhaust.
02-03-2018, 08:57 AM | #3 |
Rep 1
Its called a REP. KIT FOR SOCKET HOUSING part no.
61-13-2-359-993. You can get it from the dealer for about $18.00 or ECS Tuning for $15.00 https://www.ecstuning.com/b-genuine-...g/61132359993/ |
08-22-2018, 11:28 AM | #4 | |
Rep 8
I spoke with ecs to confirm if this part fits f30 328i they said it’s only listed as compatible with f20, do you know if this is accurate or if this part is actually compatible? Thanks in advance |
08-22-2018, 07:05 PM | #5 | |
Rep 67
10-16-2018, 10:07 AM | #6 |
Rep 3
How do you install this?
I just picked up this part from ECS because my ground also burnt out. Looking at the ECS part and a bit confused how to assemble it. Any help is appreciated.
03-15-2019, 03:39 PM | #7 |
Rep 1
03-21-2019, 06:21 PM | #8 |
Rep 67
06-01-2019, 05:19 PM | #10 |
Rep 7
Had this happen to me for the second time, Right side was fixed by the dealer under warranty, the left side as a quick fix I put a jumper in for the ground.
I also have just bought the replacement bulb socket and the repair kit for the plug, sunny sunday install later. For the ground jumper, drilled a small hole through the bulb socket, fed a wire into it, located the common ground and soldered the wire to it, used a wire splicer to marry the grounds together. Works great and better connection then the small pin that had melted away. It appears the ground overheats due to vibrations or a poor connection and therefore arcs and melts. The real pisser is that you cannot extract the remains of the pin from the plug. |
07-08-2019, 07:25 PM | #11 |
Rep 3
Will this same tail light connector work for my f32 bmw 2014 435i? Its not listed as compatible on ecs but it looks the same as the one im trying to replace due to the same problem as above.
07-09-2019, 07:44 AM | #12 | |
Rep 2,196
https://www.realoem.com/bmw/enUS/par...5i&mg=61&sg=15
10-17-2019, 01:14 PM | #14 |
Rep 1
Hey guys, I just found out I have the same problem, The 2 parts to replace are
https://www.ecstuning.com/b-genuine-...t/63217313043/ https://www.ecstuning.com/b-genuine-...g/61132359993/ |
10-17-2019, 04:41 PM | #15 | |
Rep 10,473
09-02-2022, 04:25 PM | #16 |
Rep 1
I have the same problem and was about to order the repair kit and bulb holder, but then I saw a pigtail plug with wires that could just be soldered or spliced. Is this a legitimate way to fix the problem, or should I go with the repair kit?
Here’s a link to the pigtail: https://www.amazon.com/gp/product/B0...7GU6THUE&psc=1 |
09-02-2022, 10:36 PM | #17 |
Rep 16,079
Use the method in Post #10. The connector pin is too small to handle the current, so it will burn out again unless you change to all LED bulbs, which reduces the current.
