BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > BMW 335i M Performance Power Kit (PPK) Dynos at 336 bhp / 377 lb-ft
      03-28-2013, 06:07 PM   #89
RASHID007
Drives: 2014 535d X-Drive
Originally Posted by F30form
Originally Posted by RASHID007 View Post
275hp / 0.88 = 312.5hp stock
290ft-lb / 0.92 = 315.2ft-lb stock
292hp /0.88 = 331.8hp with kit
320.45/0.92 = 348.3ft-lb with kit
Gain of:
19.3hp at crank
33.1ft-lb at crank
310.18hp / 0.88 = 352.5hp with JB Stage 1
357ft-lb / 0.92 = 388ft-lb with JB Stage 1
Gains of:
40hp at crank
73ft-lb at crank
So BMW kit is almost exactly half of JB Stage 1. Simple
Pardon me, but where is the "stock" # of 310.18 hp and 357 ft-lbs coming from?
In fact, where are the stock crank #s coming from. Source? Why would one stock # be 35 horse off of another calculation?
310hp and 357ft-lb aren't stock. That is from JB tuning website for their dyno of a stage 1 N55.
      03-28-2013, 09:24 PM   #90
tdizzle
Drives: 2017 F80 ZCP
That wasn't the stock numbers, they were:
275-277 is what I've seen stock F30 335i's dyno range about.
I think torque has been as high as low 300s, but he probably used the lowest numbers for the comparison.
Edit: Guy above me got it. That's the Stage 1 numbers for JB4, but that's the "high" of the two runs they show. The "low" is 307whp/341wtq.
http://burgertuning.com/images/N55_dyno_beta.jpg
      03-29-2013, 02:03 AM   #91
rev7400
rev7400's Avatar
Drives: 15' 640i, 11' X3
Forgive me, but I don't understand the comparisons to JB4 Stage 1 and other aftermarket "off the shelf maps".
Why wouldn't people who are willing to buy those just go to a reputable local tuner and get a protune? Surely that will yield better results as the tune will be specific to your car and your car only.
Has anyone ever considered this?
      03-29-2013, 03:12 PM   #92
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
Unsure if it can be "cracked"...it's not like an AEM tune or flash that can be done by any tuner...I loved those days with my Evo 8!!
SOLD: 2012 335i Mineral Gray
      03-29-2013, 03:30 PM   #93
buildbright
buildbright's Avatar
155
Drives: F80 M3 MG
Well the problem is most "professional" tuners suck. They only care about peak numbers and not longevity or drivability. Tuners like Terry or others have been tunning these cars for years. They not only tune customer cars they own them and do dataloging constantly to improve the product. Also they give you varibles to make changes to get more power if you take it to a professional.
      03-30-2013, 07:19 AM   #94
BMWBUSINESS007
F30 335 OWNER
Drives: 2013 BMW 335i xDRIVE Sedan
very nice
      04-15-2013, 11:53 PM   #95
KevinJ
Drives: 2k11 335is
Motortrend 0-60 for the 335i, rolling start and torque braking not eq 335is
If you refer to that original Motortrend video, they explained they were torque braking to get that 0-60 time which was bogus. A later review of the 2012 335i they got 4.7 from a rolling start and not a stand-still. Even one article calling out the 335is on this bad comparison data. I call it marketing.
Believe me the 335is can do 0-60 in 4.7 all day long without launch control even. Best reported times for the 335is are 4.6. Consistent times are 4.7.
Originally Posted by TractionControlOff View Post
Actually, motor trend has a well documented test of the 2012 335i (not the 335is) and the 0-60 was 4.7 sec. It was with the regular auto transmission -- not even the dual clutch.
If the 335is wont at least do it in 4.5 sec it would be sad. Doesnt the 335is come with the power kit, an overboost function, dual clutch tranny and better tires?
      02-20-2014, 12:07 AM   #96
TractionControlOff
Drives: 2023 M340i Dinan Exhaust
Ok, I'm going to have to admit my ignorance here. What the guy did in the video was get the rpm's over 2,000 and then release the brake from a standstill. Is this torque braking? If so, how is this different from dropping the clutch on a manual? And how does either make the 0-60 time bogus? Is there a standard protocol testers use to come up with a legit 0-60 where they go straight from brake to gas pedal with the engine at idle? Below is a link to the article and video. They mention how it gets the same time as the previous 335is. Please explain b/c I am confused...
http://www.motortrend.com/roadtests/...5i_first_test/
