04-28-2017, 04:07 AM | #177 | |
Rep 407
You need to have an FEM which supports comfort access. It is probably easier to go with the bimmer-tech comfort access retrofit.
04-28-2017, 06:52 AM | #178 |
Rep 314
So how did you do that? Did you order a new one from BMW and somehow convince them you need a FEM MAX or did you buy a used one and somehow were able to copy the CAS keys from your old FEM to your new one?
04-28-2017, 06:55 AM | #179 |
Rep 407
I was doing an engine swap on my car so I used donor keys, DME and FEM which happened to be an FEM MAX.
04-28-2017, 08:15 AM | #180 | |
Rep 191
I prefer OEM if possible. It was mentioned earlier that memory seats requires FEM MAX, is this true? If so I have the MAX version. I will take out the trim and check the version before I go and buy any bits. Can I confirm what you did:
Did you fit the rear and boot antennas? If my car does have a MAX FEM is it possible to code CA to it? |
04-28-2017, 08:16 AM | #181 |
Rep 191
04-29-2017, 03:24 PM | #182 | |
Rep 407
I fitted driver door handle, all missing antennas (passenger, boot, rear bumper) and coded. The donor had an FEM MAX but did not have CA from factory.
05-31-2017, 06:12 PM | #183 | |
Rep 25
Let's create a DataBase! I have FEM Model: FRM-LR01-ZB6_MID_BIX_IB HW8.3 My Vin: G317066 Thats is the only way to find out what fem hold back on us!! Last edited by yoodog; 06-05-2017 at 04:31 PM.. |
06-05-2017, 03:08 PM | #184 |
Rep 106
I have almost the same FEM Model (I have BIX instead of BIC on yours).
So, here's my FEM: FRM-LR01-ZB6_MID_BIX_IB HW: D8.3 SW: 15.100.20 cedchung , would it be possible to take a photo of your FEM? |
06-05-2017, 04:31 PM | #185 | |
Rep 25
Do you have Comfort Access or other cool stuff? |
06-08-2017, 12:31 PM | #188 |
Rep 193
06-09-2017, 11:58 AM | #189 |
Rep 106
06-09-2017, 12:14 PM | #190 |
Rep 193
06-09-2017, 03:39 PM | #192 |
Rep 193
06-18-2017, 05:00 AM | #193 |
Rep 407
Here
06-18-2017, 11:14 AM | #195 |
Rep 106
Thanks
Now that's even weirder, all FEM MAX I saw have post-fix after part number -02, yours has -01. Also, I cannot find the part number of my FEM anywhere. I'll dig further. bimmer456 Bimmer Tech But I don't like fitting unoriginal stuff in my car, that's why I'm digging this further, if I won't be able to make it, then I won't make it |
06-18-2017, 08:52 PM | #196 | |
Rep 314
06-29-2017, 11:32 AM | #197 |
Rep 3
Have you guys considered getting the CA retrofit kit from bimmer-tech.net? Seems to me like it's considerably cheaper than buying all the separate parts, and also less headache... They send you as many handles ad you need, the antennas, and the control module that plugs directly into your FEM.
