01-10-2013, 05:39 PM | #1 |
Rep 250
Drives: E82 N52 6MT A51
To All F30 Coders!!!
hello peeps,
I have an inquiry. I am contemplating coding my car but would only get started if these few features were possible. Is there a way to code the car to : 1. Remote start the engine from fob 2. if not 1, maybe remote engage ignition from fob 3. or remotely enable heated seats from fob Winter is killing me and I want to make my driving winter experience completely seamless from indoors to car. Any info will help, thanks! |
01-10-2013, 07:28 PM | #2 |
Rep 568
Go download BMW remote app on your smartphone, you may have access to "precondition car" option, which lets you turn on the climate control from your phone from anywhere prior to getting into your car.
01-11-2013, 10:55 AM | #4 | |
Rep 784
Also, pre-condition only turns on the fans to circulate outside air. So, it is really only useful in summer as it somewhat cools the car. |
01-11-2013, 01:17 PM | #5 |
Rep 250
k thanks
01-13-2013, 12:20 PM | #6 |
Rep 30
Hey wayman519, maybe you have slight misunderstanding of coding. It is just a way of editing config files, like what you do with your Linux box (EDIT: or windows registry - this is more like it). You basically can't achieve any fancy feature that wasn't designed by BMW through coding, like you just can't make Windows xp do windows8 stuff just by editing its registry...
But, for the heated seat there might be a possibility as I vaguely remember seeing an option to set the heating seat on during power on.. if this could happen maybe when you press the button on your fob it will unlock the car and turn on the heated seat. However even if this is possible I cannt see it offer much help though because we are just talking about turning it on maybe 10 seconds faster. . |
01-14-2013, 04:07 PM | #7 | |
Rep 250
01-14-2013, 06:06 PM | #8 | |
Rep 30
02-24-2013, 12:37 PM | #10 |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
If you are in the U.S. you cant. It is not available here. And quite frankly the app is annoying, hard to use, and has a huge delay.
FBO-PS1 and stuff
05-09-2013, 04:00 PM | #12 | |
Rep 30
only turning the fan on, not with a/c or hot air so can only be useful in the summer days. |
05-09-2013, 04:07 PM | #13 |
Rep 1,436
ya I have that, you set up the timer and bam it's very helpful here in Egypt it's damn hot lol thx.. I have questions about coding only the tv in motion worked when I did the TPMS it showed bar but didn't read anything for the disclaimer and hp wasn't changed what should i do ?
05-09-2013, 04:36 PM | #14 | |
Rep 1,892
I don't understand your disclaimer or HP question. NAV disclaimer is a single code change as is the unit change for the sports display. They are both in the cheat sheets. What issue(s) are you having? |
05-10-2013, 03:32 AM | #15 | |
Rep 1,436
05-10-2013, 05:08 AM | #16 |
Rep 40,774
And what did you code to do this?
05-10-2013, 05:11 AM | #17 |
Rep 1,436
05-10-2013, 05:14 AM | #18 | |
Rep 40,774
If so, is the setting now showing on your CIC to change the units of measure?
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 01-14-2014 at 05:44 AM.. |
05-10-2013, 05:52 AM | #19 |
Rep 1,436
yes I changed only dropdown value but when I do the other werte changes too so i guessed it doesn't need to be changed and what's CIC ?
05-10-2013, 06:15 AM | #20 | |
Rep 40,774
CIC = Your Head Unit, aka Stereo, aka iDrive system. Go into iDrive settings, and check if the screen is there to change the units of measure, and that if it is, it is set properly.
05-10-2013, 07:32 AM | #21 | |
Rep 1,436
what worked : -digital speed BC -TV in motion -Tire pressure (but no values) :/ -DRL both tail lights -sport configure what did NOT work: FEM BODY values says error when I hit read coding it includes -Auto start stop -HP value -windows rolling with no door interruption -mirror unfold at .. speed idk what to do |
05-10-2013, 07:34 AM | #22 | |
Rep 1,892
So, once you code this, go to the Menu -> Settings -> Units screen and change the Power and Torque units to the units you want (HP and ft-lb). Then go back to the Sports Display and the display should be correct. |
