BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 19x9.5 38 offset 265/30/19
      12-12-2012, 02:08 AM   #111
Andy0323
Drives: F30 328i
Cleeeaaaaan.
      12-12-2012, 06:23 AM   #112
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
Originally Posted by jsedlak View Post
a 19x10+37 with a 265/30 is said to fit the same as your setup...
So why the ?
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      12-12-2012, 06:42 AM   #113
jsedlak
jsedlak's Avatar
Drives: F30 335i 6spd
Because it doesn't sound realistic. I can't believe the tyre makes up a 0.5" difference.
      12-12-2012, 11:37 AM   #114
Renus
Renus's Avatar
28
Drives: E92 335i
Nope, if you going to 10J width, ET should be at least 40 or more even reach 50.
      12-12-2012, 11:43 AM   #115
mikew2069
mikew2069's Avatar
413
Regardless of how wide the wheel is, if a 9.5" wheel has the same offset of a 10" wheel and the both have 265/30 tires, the tires will stick out the same.
BM3/H&R/Borla
      12-12-2012, 12:21 PM   #116
gtabfknkdnme
5 Star General
gtabfknkdnme's Avatar
Drives: E82, F30
this is false. the tire will stretch slightly more on the 10" wheel, then again the wheel will stick out slightly more. so how far the tire sticks out really depends on how well it stretches
      12-12-2012, 12:28 PM   #117
Renus
Renus's Avatar
28
Drives: E92 335i
Originally Posted by ric124 View Post
Adaptive M was ordered with the car, sport line with adaptive M . It works with driver modes Comfort to sport. Not sure if its as simple as buying and putting them on may need some coding.
I took the sport springs off and replaced it with H&R Sports. This setup gives a much stiffer setup than sport pkg in Sport/Sport+ mode and softer feel in eco/comfort mode.
I wasnt able to find a part number but this what I think this is the order code.
S2VFA ADAPTIVES M FAHRWERK Adaptive M suspension
I think this Adaptive suspension should be working Variable Sport Steering function, am I right?
      12-12-2012, 12:29 PM   #118
mikew2069
mikew2069's Avatar
413
True but the 'high point' of the width of the tire shouldn't really change. Doesn't just the side wall stretch?
BM3/H&R/Borla
      12-12-2012, 01:20 PM   #119
jsedlak
jsedlak's Avatar
I think this is correct... The tyre has a normal width that it is inflated to under usual circumstances. It so happens that the 265 fits with a little extra room on a 9.5" rim. That is it expands past the rim wall to fill its standard width. On a 10" rim, it should be stretched a little. I imagine at the extreme end, a 14" rim would be too wide for the tyre to seat (it can only expand so much). On a narrow rim, such as a 4" rim, the sidewall would keep expanding and either blow out or pop the tyre off the rim.
If this is correct, then tyre choice makes much more of an impact than wheel width.
However, I have no idea what the performance difference is between seating a 265 on 9.5" and 10" rims.
      12-12-2012, 04:26 PM   #120
mikew2069
mikew2069's Avatar
413
Yup, this is how I see it. Unless of course you are slammed low to the ground at which point the wheel width will also come into play.
BM3/H&R/Borla
      12-12-2012, 04:26 PM   #121
ric124
ric124's Avatar
Jamaica
453
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
I also have Variable sport Steering but that's a different option and not related to the Adaptive M.
      12-12-2012, 07:03 PM   #122
etmathews
WARRIORS come out to play yay!!
etmathews's Avatar
Drives: 2016 F30 340i M Sport
Forgestar said my 19x10 offset 38 275/30 ventus hankooks will work. Will they stick out to far?
2016 340i M Sport/Alpine White/Black Dakota Leather/Ash Wood Trim/ M performance carbon fiber spoiler, M performance grills, M performance front splitter, M performance carbon fiber mirror caps, Llumar ATX Axcess 30% tint
      12-12-2012, 07:36 PM   #123
mikew2069
mikew2069's Avatar
413
Dang did you just order 19x10 +38? I'm worried about my 19x10 +45 with 285/30 fitting and yours will stick out further than mine. Wonder why they made mine 45 and yours 38...
BM3/H&R/Borla
      12-12-2012, 07:43 PM   #124
etmathews
etmathews's Avatar
Mines coming off a 2010 e92 335i coupe. I was hoping to use the same wheels.
      12-13-2012, 06:30 AM   #125
jsedlak
jsedlak's Avatar
No way that's going to work....
Package will stick out 19 mm (0.7'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset.
      12-13-2012, 06:32 AM   #126
jsedlak
jsedlak's Avatar
That 285 may be he death of you.
The +45 should work... with a 265 tyre.
With a 275 tyre it's 8mm closer to suspension, 12mm more aggressive relative to stock M-Sport.
      12-13-2012, 06:41 AM   #127
mikew2069
mikew2069's Avatar
413
I think it can work as long as you don't plan on dropping the car. It will just be VERY aggressive.
I know that its going to be very very tight. Scott@BMW is running 19x9.5 +38 w/ 265/35 on H&R Sport springs with no rubbing. My setup will stick out 3mm further than his so I think I have a shot. There's also someone in the classifieds selling 19x10 w/ 275 tires and no rubbing and he's slammed. He's not listing his offset but they are probably +45.
I've alread talked with Discount Tire and they said that we can try it and if it rubs, we can just take them off and order a different size. No harm there, I'd just have to wait another couple days.
BM3/H&R/Borla
      12-13-2012, 06:42 AM   #128
mikew2069
mikew2069's Avatar
413
The good news is that you can always just have them machined down a little to +45 or whatever you want them to be.
BM3/H&R/Borla
      12-13-2012, 07:04 AM   #129
ric124
ric124's Avatar
Jamaica
453
2017 BMW M2  [0.00]
Nice! Take pics when done! That's the good thing about buying now there are other owners who have tried different Sizes. When I bought tire rack didn't even have a image of the f30.lol
      12-13-2012, 07:44 AM   #130
jsedlak
jsedlak's Avatar
Agreed on all accounts. I think your wheel size is good to go, and it's awesome that they're willing to replace the tyres if they rub.
Please get your wheels & car already. I'm dying over here waiting for photos.
      12-13-2012, 10:25 AM   #131
mikew2069
mikew2069's Avatar
413
Trust me man, I'm dying too! I'll probably have the wheels within a week or so but the 800 number says my car is 'waiting for a boat' so it will probably be another month. Blah!
BM3/H&R/Borla
      12-13-2012, 10:27 AM   #132
mikew2069
mikew2069's Avatar
413
Always sucks to be the guinea pig but at least you've been the only one on the road for a little while...
BM3/H&R/Borla
