BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Paddle Shifter Retrofit
proTUNING Freaks
      02-26-2019, 02:53 PM   #45
zole2112
Modder of everything I own
zole2112's Avatar
147
Drives: 2013 335i Xdrive
Originally Posted by Tim.H View Post
Hi,
quick question, if you got the 428i - with the M steering wheel, do the 3-series have the same M steering wheel as the 4-series? Meaning, I only need the paddles + back piece?
and if so - does anyone by coincidence know what parts I need to buy?
Coding I can do myself.
Tx, Tim
If you haven't seen this yet, I followed this document, it has the parts listed.
File Type: pdf DIY Paddle Shifters BMW F30 Rev. 3L.pdf (5.35 MB, 683 views)
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
omorzo1.00
AndrewC198910931.00
      05-04-2019, 06:51 PM   #46
mclark2112
mclark2112's Avatar
109
Drives: 2018 BMW X3 M40i
Success! I happily have paddles on my 2015 335!
XHP
2011 335i, totaled by a deer.
2015 335xi.
2018 X3 M40i currently.
      05-07-2019, 07:30 AM   #47
kobluna
Drives: 320i
For those who has retrofitted paddles, does your transmission downshift to lowest possible gear when pulling minus paddle over a second? This is described in PDF attached by zole2112 but for me it doesn't work. I just changed paddles_verbaut to aktiv and paddles works but this direct change to lowest possible gear does not work. Does not matter if stick is in D, S or M it always shifts only one gear at a time.
Maybe I need some additional coding somewhere? Add 2TB to VO? I have basically everything that it includes already as I have quicker shifts, paddles and launch control available. LC was active from factory and I coded quicker shifts long before retrofitting paddles. That is why I did this via FDL coding. I wonder if there is some parameter that I have missed by not coding 2TB.
      05-11-2019, 05:10 PM   #48
KTE
Drives: A slow car
Have the paddles from factory, mine doesn’t shift to the lowest possible gear. I have to manually press X amount of times to get into whatever gear I need.
      05-12-2019, 01:56 PM   #49
kobluna
Drives: 320i
Thanks for the info. There is then some misinformation in the pdf. Maybe in some models it would change to lowest possible gear by holding left paddle depressed, I don't know.
      05-12-2019, 04:54 PM   #50
mclark2112
mclark2112's Avatar
109
So my shifters work perfectly, but I'm throwing a Cruise control error in the car.
I can clear it, but it comes back.
ALso, cruise control works fine. In fact all functions work fine. Ugh.
2015 335xi.
      10-12-2019, 02:06 PM   #51
mclark2112
mclark2112's Avatar
109
Figured it out, I had the wrong harness cable. With the correct one, from a car that also had a heated steering wheel, it works fine. No errors.
2015 335xi.
      10-13-2019, 12:10 AM   #52
Brandon_a
Drives: BMW F30 316i
Originally Posted by ChubbyWilly View Post
There's plenty of DYI's on this you just have to search for them.
But, I did this to my own car just last week and I've attached the PDF I used. One thing I lucked out on is that my car is pre-wired for the paddles.
I am thinking to buy the used steering with paddle shift, apart from the wiring and coding, is there anything I should be aware of?
      10-13-2019, 05:07 PM   #53
mclark2112
mclark2112's Avatar
109
It was pretty easy, once all my parts were correct. Not a very hard at all if your are reasonably mechanical and brave. I am super happy to have done it.
My car is an M-Sport, and it was prewired in the dash for the paddles, fortunately.
2015 335xi.
      10-24-2019, 02:12 PM   #54
ChubbyWilly
ChubbyWilly's Avatar
Drives: 2015 BMW 335i
Sorry for the late reply.
Just make sure all the part #s are for a 3 series and be prepared to do some wiring work if your car is not already pre-wired.
Mods: MHD Stage 2+ FlexFuel, xHP Stage 3, VRSF 5" HD Intercooler, VRSF Charge Pipe, CircuitWerks Catless DP, AFE Pro Dry S Intake filter, Eldor coils, NGK 97506 @ .026, Bilstein B14 coils.
      10-24-2019, 02:35 PM   #55
zole2112
zole2112's Avatar
147
Mine is a 2013 335xi N55 F30, it was prewired to the front FEM so I only had to change my steering wheel to a paddle steering wheel and code it for paddles.
      10-25-2019, 03:40 AM   #56
RokasLTU
RokasLTU's Avatar
Drives: Volvo V50, BMW 318d
Is there any way to know if the car is prewired besides tearing up half the car to check it manualy?
      11-10-2019, 01:59 PM   #57
lewis138@outlook.com
Drives: 2015 330d xdrive F31
Originally Posted by Nd0udoinwork View Post
Can you add paddle shifters to the base sport steering wheel, as in not the m-sport wheel. Because i like the normal wheel but want to add paddles. What parts would i need?
This is a bit unrelated, but apparently I need to comment on a thread to be able to make my own post..I had a paddle shift failure today while in sport plus mode on my f31 330d, I've searched the forums and can only see people talking about coding and I'm really under qualified in that field! Haha.
      02-15-2020, 12:10 PM   #58
markmdr
markmdr's Avatar
Drives: 2014 328d xDrive Sports Wagon
Hi guys, not sure if it's already been discussed on here but I was wondering....
I have a 2014 F31 with a non M Sport steering wheel but with paddle shifters already. How difficult would it be to upgrade to the M sport steering wheel with paddle shifters, and will all the functions work? Will I need to buy the airbag separately?
Hope someone can give some advice on this. Thanks!
Current: 2014 BMW 328d xDrive Sports Wagon
      02-22-2020, 07:59 AM   #59
Kailec
Kailec's Avatar
Drives: 2013 328i xDrive
You will need a new wheel and airbag. The only thing that will transport over are your paddles and their electronics. What functions are you referring to if they will work?
      05-16-2020, 04:57 PM   #60
jkwhar
Drives: F30 328i Xdrive | F15 x35i
Has anyone tried to make their own harness or not use the paddleshifter harness?
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD)
      06-12-2020, 08:50 PM   #61
relsah
Drives: bmw 2014 335i xdrive
Originally Posted by Kailec View Post
You got it! That being said, what line is your car? My Luxury Line came pre-wired for example, and I would imagine any Sport Line would be as well.
I have a luxury line too, so I did not bother to look if I'm pre-wired.
In bimmercode, I went to FEM->Expert Mode ->Paddles_verbaut ->aktiv
My paddle shifter still didn't work. How did you code yours?
      06-28-2020, 10:08 PM   #62
Kailec
Kailec's Avatar
Did you add the 2TB coding?
relsah32.00
      06-29-2020, 02:17 PM   #63
relsah
Yes`, I have the 2TB coding.
My issue right now is that only the left paddle works. The right paddle does nothing. I checked the plugs/connection and they seem to seated correctly.
I saw a youtube video from Kies saying that the "long blue plug' from the wiring harness should connect to the right paddle. I think mine is connected to the left paddle, so I might have to redo that part and see what happens.
      07-09-2020, 07:41 AM   #64
Kailec
Kailec's Avatar
So did swapping it work? If not there's two possibilities, that either you have faulty wiring or faulty paddles.
      07-09-2020, 11:01 AM   #65
jkwhar
Another possibilities is that the right paddle could've came from another car, like an f10 that has a different resistant value. If you have a multimeter, measure the right paddle.
https://f30.bimmerpost.com/forums/sh...43&postcount=8
      08-11-2020, 03:29 PM   #66
haagm58
haagm58's Avatar
Drives: F30 328d Sport Line
I have a Sport Line and it was not pre-wired for paddles. That said, I was able to wire it, retrofit paddles, and code them in without too many issues.
It's pretty easy to see if your car is pre-wired for paddles by checking the wiring harness in the passenger foot well. It takes maybe 10 minutes to access it.
