04-03-2018, 09:11 PM | #1 |
Rep 67
Just installed gfb DV+ without touching or moving the turbo it took about 1 hour and 15 mins and had to make a custom tool but got it done. Took it for a ride just now after car warmed up and yeah you can tell the different at high rpm and shifts pulls stronger or maybe It my mind playing gaming with me lol.
The way I installed it (do at your own risk) 1)Remove intake. 2)Move the wastegate out of the way, held by two screws (mine was EWG) 3)Discount the charge pipe, the side of the turbo outlet (gives you a lot room) 4)Use a 4mm long round head allen key to unscrew the 3 bolts holding the DV After removing DV and follow GFB instruction. 5)Installing DV is bit tricky now, install GBF part first the then the OEM DV part. They won't fit together so don't try. 6)Hand tighten the bolts. 7)Get a long 5mm round head allen key and grind the body smooth, that's the key because without doing this the tool will not fit! 8)Tighten it, reassemble the rest, and enjoy!
2014 328i xDRIVE | BM3 Stage 1 | H&R Sport Springs | GFB DV+ | K&N Drop-in | Evolution Racewerks Intercooler
04-03-2018, 09:52 PM | #2 |
Rep 3,680
congrats. I know a lot of members have struggled with getting these in easily. mind explaining to me what these do though? what are the benefits?
04-03-2018, 09:57 PM | #3 | |
Rep 2,382
Benefits are that you retain more boost on shifts. The stock DV has about six holes or so to vent the boost, while the DV+ has one. The reason most people replace it aside from the retained boost is that similar to the stock CP, the stock DV is subject to tearing, which leads to boost leaks. For me, it was performance and preventive. Also, I got some niiiiiice flutter out of mine. Sounds great when she shifts now.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
04-03-2018, 10:12 PM | #4 | ||
Rep 67
I wish I had done some logs before and after tho I'm playing around OBD fusion at this time I'll be giving my 2 cents on it shortly and comparing the accuracy to bm3 logs.
04-03-2018, 10:21 PM | #5 | |
Rep 2,382
EDIT: I have to compensate for that 6" screen
floridaorange10161.50 |
04-03-2018, 10:27 PM | #6 |
Rep 67
That's awesome!
Are you running that wired to the tablet via enet or using a wifi agent adapter? Also, window or ios can't really tell in the pic.
04-03-2018, 10:42 PM | #7 |
Rep 2,382
The wifi agent via hotspot on the tablet. It's an Android tablet, Galaxy Tab E to specific. PM me if you plan to get a wifi agent!
04-03-2018, 11:22 PM | #9 |
Rep 67
I'll be making videos Saturday and Sunday, during and after autocross.
04-04-2018, 09:13 AM | #11 |
Rep 3,680
+1. and BunkerJ, thanks for the explanation. I would love to hear a video of that flutter too.
04-04-2018, 09:14 AM | #12 |
Rep 67
It was 6mm around head Allen key, then I Rounded the body with a bench grinder. That was for the installation because removal was easy. After that you will have room between the block and dv.
Domotron150.00 |
04-04-2018, 09:53 AM | #13 | |
Rep 2,382
Diegov209164.50 |
04-04-2018, 01:04 PM | #15 |
Rep 285
Drives: 2014 428i XDrive
I only see these for N20. Would this work for N26? Thanks
04-04-2018, 01:22 PM | #16 |
Rep 2,382
Yes. Same thing for the turbo.
04-04-2018, 01:32 PM | #18 |
Rep 67
I do not but I'll add it to my main post later on how I did it.
04-04-2018, 04:09 PM | #19 |
Rep 3,680
damn that sounds nice! like, wow. do you think that flutter sound will still be achieved with the OEM intake system? also, any downsides to doing a DV? will it require a flash tune?
04-04-2018, 04:55 PM | #20 |
Rep 2,382
It's possible, but unlikely. Stock intake silences the DV already. Even with the hood closed and inside the car driving, it has to be relatively quiet to hear the flutter. It's not the same flutter if you had no DV/BOV and were kicking the boost straight back. No downsides that I can think and no tune required.
04-04-2018, 07:20 PM | #21 | |
Rep 3,680
04-04-2018, 09:28 PM | #22 | |
Rep 2,382
EDIT: See second page. I asserted the wrong flutter.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit Last edited by BunkerJ; 04-05-2018 at 02:09 AM.. |
rjd_F301999.50 |
