BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > INPA/Tool32 Battery Registration Issues
      01-24-2020, 03:34 PM   #1
Chief_Bimmer_Fan
Drives: 2015 BMW F34 328i GT
Hi all,
I have scoured tons of posts on how to register the battery using INPA. However each time I try I cannot find the correct module to run the reset.
From what I've read, it should go like this:
1) connect and open INPA (no prob here, coms are up)
2) F5 to choose the chassis (F30)
3) select 'Body' and choose 'Power Module'
this is the issue, I only see 4 options under the body category:
Body Domain Controller BDC
Front Electronic Module (FEM)
Rear Electronic Module (REM)
Embedded Heating and Air Automatic
I'm running V5.0.6 so I think that's up to date.
I have not found a single post on the F30 chassis either.
I also tried Tool32 loading the F01.PRG but again don't see the corresponding options.
I'm about to break down and buy the Carly app and adapter but that's ~$120 (adapter and full software version) which practically eliminates the savings doing the battery job myself.
So, am I just doing something wrong or do these methods only work on the E series cars?
Thanks!
      01-24-2020, 04:24 PM   #2
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
139
Drives: BMW 316d, BMW F40 116d
Try with the FEM (Front Electronic Module).
That should be your FRM and CAS together.
      01-24-2020, 05:05 PM   #3
Chief_Bimmer_Fan
I get this error when I try. rough translation sounds like I'm missing files or something but have no idea where to start to fix it
      01-25-2020, 10:55 PM   #4
sdbmwcoding
Drives: BMW M3
Use ISTA, much easier to register battery replacement. Bimmergeeks.net/downloads has a decent and easy to setup rheinghold
      11-26-2022, 03:49 AM   #5
Wilkiewoo
Drives: Bmw 335d x-drive
https://www.bimmerpost.com/forums/sh...php?p=25726187
Hi All,
I get the same error when trying to register battery. Where do I get the ipo files for f30 battery registration, and how do I add them to inpa pls
I saw the advice about using ista, the links to good versions in forums seem to have been disabled. I have a working copy of inpa so thought it might be simpler to get the right ipo files for inpa.
Thanks in advance
      03-25-2024, 02:50 PM   #6
DS_BMW88
Sweden
Drives: BMW 218i Coupe
Hi All,
Thanks in advance
Hi! Did you found a way to use INPA instead? I don't want to end buying just a new hdd to run INSTA-P. There must be a way.
