10-13-2014, 10:29 AM | #45 | |
Rep 3,128
PM sent.
As far as the "piggybacks are bad" comment. Steve Dinan himself has addressed the point you are referencing... "We recently saw your post regarding our new Turbotronics project and wanted to clarify a few points to make sure your readers have the correct information. I stand by my comments on "Tech tip Tuesday". Even though we are making an ECU we are still believe software has superior performance and reliability when compared to an ad on ECU. Having said that the new Bosch ECU has proven more difficult to crack than previous models so we have been forced to go the ECU route. BTW this is Dinan's 16th Turbotronics ECU because we used to make them a long time ago but when we got very good at software we went away from them because of the obvious advantages. “Tech Tip Tuesday” was also referring to the existing piggy back boxes on the market. Our goal wasn’t to imply that a piggyback box wasn’t a viable tuning solution, but rather the current ones lack sophistication in which is why they make less power, have more drivability issues, are more prone to setting faults and are not emissions legal. I also mentioned that a box would have to be much more sophisticated in order to work properly and not risk any damage or malfunctions with the vehicle long-term. The reason our software is more expensive than current piggyback systems on the market is the level of work and research that is required to “crack” BMW’s factory computers, the additional cost of the 4 year 50k mile warranty and emissions certification. The cost our R&D, warranty and emission testing when compared to manufacturing the piggy back boxes I see on the market it is more likely they are making more money than Dinan soit is not about money as the person implied it's about doing it right. Most people assume that BMW gives us complete access to the computers, but that is not the case. We have a team of 5 engineers that do nothing but read through every line of code on each ECU to make sure that all of our software allows the car to function properly, doesn’t interfere with other electronics and keeps factory system safeguards in place. As far as the new “Turbotronics” units are concerned, (still in development) they essentially are more than a piggy back box they are a powerful ECU that has many more capabilities that the existing piggy back boxes. To help you understanding the additional capabilities as I said in "TECH TIP Tuesday" the existing boxes send a an adjusted signal to the BMWECU telling it he boost is too low and the ECU then raises the boost to what it thinks is the correct value as does ours. This false value creates errors in Fuel mixture and ignition timing. This can causesmore faults, high catalyst inlet temperatures and a loss of power.In addition when you increase power exhaust temperature will increaseand this must be countered with a slightly richer mixture. Our ECU will have the capability of setting a richer target lambda (fuel mixture) as well as correcting short term trip which is the difference between target and scheduled fuel mixture just to mention a couple of it's capabilities. By matching these two correctly we can reduce knock sensor activity which will make smother performance,protect the catalyst, increase power and allow us to make it emissions legal. We have a lot of exciting new product in the works for N55 powered cars along with products being created for the M235i. Keep an eye on our social media channels for announcements on sales, new products and more of our Tech Tip Tuesday series. Thanks again for your time and we hope this is helpful. If you’re interested, we would love to have you out to the facility to see our operation first hand. Sincerely, Steve Dinan" Fixed. Thanks. |
10-13-2014, 11:02 AM | #46 | |
Rep 1,003
Good info there, I hadn't come across that response. I'm not sure if the piggyback "other guy" doesn't or can't adjust targets like lambda or timing, but "they" don't address it anywhere that I've read so it's a mystery to me at the moment, while Dinan is clear. It's a little rich for my blood, but I understand the liability that needs to be protected against with these turbo motors. |
10-13-2014, 01:30 PM | #47 |
Rep 1,556
A couple of questions:
-Since it is a piggyback, do we have to have it installed at a Dinan dealer to have the warranty? 1.5hrs seems like a long time to install a piggyback. -Can you share how much is the extra boost is? 3psi? 4psi? -Do you have different map options like other piggybacks? Or is it a one map setting? -Will it turn off the CEL light for those that run catless down pipes? -Will your warranty be extended if the car is CPO? Or does it just cover the 4yr/50,000 mile warranty? Just curious as the information is vague still on the capabilities. So glad you guys finally came out with a tune for those of us that don't like to gamble on a 25k engine.. |
10-13-2014, 04:20 PM | #49 | |||
Rep 3,128
The 1.5 hrs of install at a dealer includes running the harness, any potential troubleshooting, as well as programming as the dealers boxes are "blank" and are programmed specifically to each model in the field. Running the harness is not simply plugging into a few select sensors but running a full ~6 foot harness around the engine bay so that melds flawlessly with the BMW elements surrounding it. Quote:
We match the new car 4yr/50k warranty, so you are covered by both BMW and Dinan. If the vehicle is out of the new car warranty a 2yr/unlimited mileage warranty takes it place. You can check our website for details on each of the warranties. |
10-13-2014, 04:22 PM | #50 |
Rep 3,128
www.realoem.com
Click on 'enter' towards the bottom center of the page and then simply enter in the last 7 digits of the VIN. That will give you most specs for your vehicle that you may want to know. It should also be listed on the sticker inside the drivers side door along the pillar unless that location has changed and I am just not aware of it. |
10-13-2014, 07:13 PM | #51 | |
Usofstance
78
Rep 671
Hey how much do you think this will cost?
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance United States Of Stance |
10-13-2014, 09:13 PM | #52 |
Rep 1,556
Thanks for the info Dinan guy. You have finally answered many of our prayers...LOL... Just buying it for the warranty peace of mind even if it is exactly like the others is worth it, but from it sounds yours is a step above.
10-14-2014, 10:37 PM | #53 | ||
Rep 4,976
Wife's Car: 2020 X4M Competition, Alpine White on Black Alcantara and Biege
Current Car: 2018 F80 M3CS, SMB, DCT, ZEC, MPE Recently Departed: 2020 F87 M2C, LBB, ZEC, 6MT (Euro Delivery Aug. 29, 2019, totaled by an idiot in a Camry who then ran from the scene) Wife's Prior Car: 2018 F80 M3, Yas Marina Blue, DCT, Black 19s, Carbon Structure Anthracite Cloth/Leather Combination, Driving Assistance Package (Euro Delivery Oct. 9, 2017) |
10-14-2014, 11:23 PM | #54 | |
Rep 3,128
Not sure if the exhaust reference was aimed at the 328 or the 320 so I will answer both. There are no plans to develop an exhaust for the 320 but if enough demand is shown than I can make a plea to Steve that it is a viable product. There is also no plans to create a different exhaust then what is currently offered for the 328i. |
10-14-2014, 11:36 PM | #55 |
Rep 134
Ummm these motors are 2.5 years old - how much patience is needed
2018 440i M Sport 2013 328i M-Sport sold 2003 745li sold 2000 528i sold |
10-15-2014, 07:56 AM | #57 |
Rep 31
Glad to see tune has been released by DINAN after much anticipated wait. I will be in contact in the near future to purchase. Will provide review after some spirited driving. Do you know who is a DINAN recommended installer for the Washington, DC area? By chance is BMW of Rockville recommended?
10-15-2014, 06:07 PM | #59 | |
Rep 3,128
93 is what the tune was developed for although you can run 91 or higher. The tune is just not tweaked for various fuel ratings. IN the future we will be developing race octane maps (100 octane) but that is a bit off yet. |
10-16-2014, 10:01 AM | #60 | |
Rep 599
10-16-2014, 10:23 AM | #61 |
Rep 3,128
The project got delayed a day so we started shooting video on a variety of things yesterday and are continuing all day today. We will get the exhaust clips filmed today with a bunch of other car footage we are shooting today. Will also provide cabin noise as well since lack of drone is kind of what we hang our hat on in addition to the normal drive-by and what not.
You will actually be seeing a lot of quality (and technical) video coming out of Dinan in the near future. With a lot of answers to a variety of questions straight from the man himself, Steve Dinan. Definitely keep an eye out. That said if you haven't seen it yet, Roads and Rides did a great synopsis video of the Dinan philosophy in general recently. I would encourage everyone to give it a look if you were ever curious as to how we tune in general terms. It can be viewed here if interested. |
10-16-2014, 10:53 AM | #62 | |
Rep 599
10-17-2014, 12:29 PM | #63 | |
Rep 3,128
A conversation has been developing on the M5 thread that Steve felt the need to respond to and explain some things about the DINANTRONICS Performance Tuner. Thought it may be pertinent to those over on this forum as well in case you were interested in a more technical explanation of Dinan's tune.
You can read the entire thread if you want but the synopsis is that a user posted his review of the DINANTRONICS performance tuner and Steve Dinan took notice and felt the need to explain why the reviewer noticed the changes he did. Link to the last page of the thread below. http://f10.m5post.com/forums/showthr...1008125&page=8 The straight to the point meat however you can read below... Quote:
"Thank you for noticing the smother operation of the Dinan ECU when compared to the competition. I thought a technical explanation of why it is so smooth might be of interest. Just to clarify the reason why you are experiencing better throttle response in general and ultimately what feels to be “more” power is based on the complexity and better control of engine tuning parameters of the DINANTRONICS system as a whole. The DINANTRONICS Performance Tuner is MUCH more than just intercepting signals as some seem to think. There are more correction factors and calculations going on in the background of our box than anything else we have seen on the market thus far. We compensate for every necessary variable so the factory ECU is not fighting itself trying to correct mismatched variables and ultimately robbing you of power. When Dinan is done tuning on the dyno we then go out on the road and do extensive tuning to improve performance. The road environment is different! You have better cooling on the engine, intercooler as well as more ram air. This results in better cylinder filling (more pressure in the cylinder) and requires slightly less boost to avoid excessive detonation. When you are done tuning on the road the car accelerates faster but will show a lower number on the dyno. We believe we are selling acceleration not dyno numbers. Our numbers on a dyno may not be the max numbers out there but there is a reason. If we were to add that extra boost that other companies run, the engine will be into the knock control system so much that you can feel the correction it is making. In addition the other units on the market do not do fuel correction they rely on the O2 sensor and knock control system to drag the mixture to the correct level. The problem with this is when you change gears it takes some time for the factory ECU to determine what this correction is; resulting in a flat spot until it figures it out. This is what you were feeling. The Dinan ECU has advanced fuel control features that add fuel to the engine so we are not relying on the factory ECU to compensate for the lack of fuel. We also have a feature that adds fuel only during gear changes to quench detonation that occurs from the spike in load as a result of the gear change. The better fuel control provides dramatically better drivability. This higher level of tuning for the road and lack of pauses on gear changes make the Dinan car faster even if you measure a lower number on the dyno. Even if more boost is a little faster what good is it if the car has bad drivability." |
10-18-2014, 01:42 AM | #65 |
Rep 3,128
We are working on that functionality but it remains to be seen if it will be possible to do it through the existing connections on the performance tuner. It may in fact require an additional interface / connectors but only time will tell.
10-19-2014, 08:16 PM | #66 |
Rep 319
thanks for all the info "Dinan" I'm getting the exhaust as soon as my BMW dealer calls me back this week. As soon as the DinanTronics comes out for my 2014 it will be going on I don't care what the wife says.
