BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > 428i to 435i Exhaust Conversion?
Studio RSR
      04-14-2016, 10:03 AM   #67
Snickaren
Drives: 428i Xdrive F32 2014
Originally Posted by SJ00 View Post
For the mpe? That sounds like a great deal!
MPE ??
      04-14-2016, 10:37 AM   #68
Trevster
Trevster's Avatar
Drives: 2014 428xi
MPE ??
M performance exhaust
      04-14-2016, 01:34 PM   #69
Snickaren
Ahh okay, I just bought the 435i damper...
      04-14-2016, 06:09 PM   #70
Who?
Who?'s Avatar
Australia
485
Drives: F87 LCI
Haha I got mine for $2200au in Australia
Crazy prices over here
Private sellers here want at least $600 for a stock 335i exhaust..
So far: 200cell downpipe, custom exhaust, lifhtweight splitter, m4 comp seats
      04-15-2016, 09:53 AM   #71
Bols
Belgium
231
Drives: F36 AW 6MT
I got mine for about 275 euros shipped, regular 35i. Wasn't mentioned but I think I got the 335i instead of a 435i but it only takes a bit more welding to get it to fit and if needed some tie straps to get the tip heights to your liking ... Use the part number and look for eBay sellers located in Germany I found 2 or 3 at the time I was looking! So worth it!
      05-01-2016, 08:18 PM   #72
Who?
Who?'s Avatar
Australia
485
Drives: F87 LCI
Finally got 2 videos
Car Warm
Car Cold
      05-02-2016, 01:27 PM   #73
CRJdriver
CRJdriver's Avatar
82
Drives: F30 & F82
I will add to this!
Dp then 35i piping all the way to MPE no resonator and no drone
Borderline obnoxiously loud when u go near the throttle, can't hear a thing at cruise.
      05-24-2016, 01:27 PM   #74
n00bim2015
Drives: BMW 428i Gran Coupe M Sport
i wonder if the duel sided exhausts are more of bmw wanting people to buy up to the 35i model rather than saving costs by only producing only duel sided exhausts for 28i and 35i cutting costs.
      05-24-2016, 09:26 PM   #75
CRJdriver
CRJdriver's Avatar
82
Drives: F30 & F82
BMW has always traditionally have dual exit on the left side. Even E36 M3 had it. E46 M3 was the first time the quad center was used. V8 and V12 (2 manifolds) had it earlier. E9x was he first time 3 series had dual exit left and right due to n54 twin turbo set up.
I think it's Germans being Germans. questioning why the added weight?
      09-16-2016, 12:57 PM   #76
shoguniori31
shoguniori31's Avatar
Drives: 2016 Bmw 428i MT
Have you ever had the conversion done?
      09-16-2016, 02:04 PM   #77
shoguniori31
Originally Posted by exclusivo View Post
You'll notice that my right tip is off center, some people say theirs lined up, some said they had to maneuver the muffler hangers, some say one tip sticks out further than the other...I decided to just leave it as is because I plan on changing the tips, so when the shop welds it, they can just cut it to fit.
Did you just cut the old exhaust and well the 435 mpe on? cuz i called the dealership and ask about the conversion and they said special modification is need for this
      09-16-2016, 04:15 PM   #78
tboooe
tboooe's Avatar
925
Drives: F36 428i GC, E36 M3 - gone :(
I did the conversion as well. You can weld it on. However, since there is a difference in diameter between the 428 exhaust the 435 exhaust, the exhaust shop has to make a piece that connects the two different pipe sizes. Its not a big deal. In my case, I did not want to weld because I wanted to be able to go back to stock if I wanted. I had the shop modify the muffler pipe and then I used the OEM clamp. I've had my exhaust for over 1.5 years now without any issues. For more info, check out my build thread in my signature.
My build thread
2015 428i GC - Alpine White - Coral Red - M Sport
      09-16-2016, 05:40 PM   #79
shoguniori31
Thanks for the reply, looked at your link. That looked more work than i thought it will. I was thinking i can just cut the old muffler,hang the 435 mpe up and clamp it down
      10-01-2016, 11:08 PM   #80
exclusivo
exclusivo's Avatar
126
Drives: race car
In theory, that is all you have to do, but getting it to line up will take some time.
any good muffler shop should be able to take care of this rather easily.
      07-06-2017, 02:43 AM   #81
Pacemaker1000
Drives: 430i GC
To resurrect this thread,
I want to do this conversion on a 430i. Looking online all the hangers and active parts look identical and it's just a swap out with no other parts needed other than a clamp and new diffuser?
Is this correct?
      07-06-2017, 06:27 AM   #82
Dang3r
Schmollbraten
Dang3r's Avatar
Drives: M4CPC // HP4 Comp.
Not sure if your muffler has flap regulated tips (probably not), aside from the fixing there shouldnt be any differences but the left side electric steered vent. You'll have to block it into open position.
Nonsens. Theres no need to equip a low powered car to looks like a bigger model from the same series. This thread is the proof that you 428ers would make look your car more than it is. Even its only a cosmetic item which has nothing to do with weight
Citizen of ///M - Town, where too much is just right
Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox
      07-06-2017, 10:46 AM   #83
Pacemaker1000
Drives: 430i GC
Just checked on realoem and apart from muffler ALL other components are the same.
Actuators different on 430/440 to 428/435 so rules out a 435 muffler for me
If it wasn't for having to cut the pipe I'd probably do it for looks alone
      07-07-2017, 01:57 AM   #84
Dang3r
Schmollbraten
Dang3r's Avatar
I'd changed my whole exhaust after the half-clamp behind the cat...but I sold it meanwhile. Otherwise you were able to buy it and change just the whole pipe w/o cutting anything
      09-01-2018, 11:59 AM   #85
skommer15@gmail.com
Drives: bmw 428i xdrive msport
428 to 440 exhaust conversion
Originally Posted by PCR0303 View Post
I have a 428i and some of us will definitely agree any -28i one sided exhaust is just a no no. Therefore I'm looking at getting the M Performance diffuser alongside the M Performance exhaust. Both being the 435i version because I want the dual exhaust setup. Now the real question, can this conversion be done? I've seen several posters get it done but I need more information on how it can be done, how long it should take, and what extra parts if any would I need? Also if any Southern California people know which reputable place would be able to do this without a problem? I've already contacted a few shops and they said they were unsure. Any helpful information would be great, thanks
I am interested in getting a new exhaust for my 428i m-sport. I have been contemplating doing the 428-435 exhaust conversion. I have found a lightly used 440 msport muffler available online and was wondering if it would mount fine stock without modification in comparison to the 435 muffler. I dont know if they utilize the same exhaust hanger points or are even similar in size. Does anyone know if this will work? I dont want to buy something that I cant use. Thank you all for any insight that you can provide!!
      09-01-2018, 12:02 PM   #86
skommer15@gmail.com
would a 440 muffler fit as well?
