06-28-2016, 07:29 PM | #1 |
Rep 334
Can coding correct absurd speedo error?
This is my 8th BMW. All overestimated the car's speed, usually by 3mph. This latest one, a 340i, is off by 4mph. This is really rediculous. Any other car I've ever owned (roughly 25 of them) was right on.
06-28-2016, 07:55 PM | #2 |
Rep 1,056
wonder why is this a big deal?
06-28-2016, 07:58 PM | #3 |
Rep 597
From the F30 Coding Reference Guide v1.7:
KOMBI 3000 BC_V_KORREKTUR nicht_aktiv aktiv Turns off speed correction and displays actual speed. Maybe that's what you're looking for? Agree with prev post, no idea why 3-4mph matters. Also because the table doesn't show - "aktiv" is default, you'd code to "nicht_aktiv". -tgm Last edited by tgmsocal; 06-28-2016 at 07:59 PM.. Reason: Clarification |
06-28-2016, 09:48 PM | #4 |
Rep 436
Drives: 2016 435i xDrive Gran Coupé
If your car under estimates the speed...that is an issue. You could be stopped for speeding without knowing you were over the limit. Over estimating your speed is an intentional design decision to mitigate against customer complaints. As noted above this can be adjusted by coding.
06-28-2016, 09:52 PM | #5 |
Rep 247
I can understand why it would be annoying to have this safety factor/error.
If you try to drive the speed limit using the speedometer, then you're going 4 mph under. Or you have to adjust like me and using the HUD, I'm always driving 37, 47, & 57 mph on city streets. |
06-28-2016, 10:25 PM | #6 |
Member
457
Rep 1,517
All BMWs are like 6% off, not exactly 4 mph. I actually like it because I always know I'm not speeding, especially when cruise controlling on the highway.
Previous: 2013 135i Space Grey w/Coral Red | 6 Speed MT | M Pkg | JB4 | AA Downpipes | AA Exhaust |
Previous: 2015 M3, BSM[/SO/CF | DCT | Adaptive M | 19" Black | CF Roof | Previous: 2018 M2, AW | DCT | Exec Pkg Current 2020 X7 50i |
06-29-2016, 07:01 AM | #7 | |
Rep 1,476
Drives: 2022 G01 X3 M40i (Black/Black)
2022 G01 X3 M40i (Black Sapphire/Black), HK, DAP, PAP, Shadow Line
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust 2006 E90 330i (Silver) 6MT, Sport |
06-29-2016, 07:52 AM | #8 |
Rep 548
Drives: 2011 E90 M3 ZCP
After hours and hours of research on this topic, I'm 99% sure coding those values above DO NOT do anything. The odometer will always read true, but the speedometer has a built in correction factor to increase it by around 4-6%.
06-29-2016, 07:59 AM | #9 |
Rep 6,989
The "built in correction factor" is turned off by coding as mentioned above. Checking speed against my GPS after coding the "correction" to "nicht aktiv", it's within 1 MPH of what the GPS reads. There are also portable radar trailers that the local PD sets up around town and every single time I go past one, its readout matches that of my analog and digital speedometer readouts (coded that, too).
06-29-2016, 08:00 AM | #10 |
Rep 16,060
True. Mine reads about 2MPH low at 30 and at 60. I also don't mind. Like most I tend to drive around 15% above the limit. The 'error' gives me a buffer that prevents speeding tickets.
06-29-2016, 08:02 AM | #11 | |
Rep 548
06-29-2016, 08:18 AM | #12 |
Rep 6,989
Most definitely works. I code the correction off and the digital readout (an addition to the list of selectable items in the "bc" area between tach and speedo). I've done this since 2011 on previous E-series cars and now on both of my F-series cars.
06-29-2016, 08:35 AM | #13 | |
Rep 548
BC_DIGITAL_V_KORREKTUR = Correction for Digital speed I'll give this a shot! |
06-29-2016, 08:48 AM | #14 |
Infidel
122
Rep 1,102
Or you could just step up the profile on the tires a notch like I did, and now my speedo matches the GPS speed.
Dec. 2022: Fully loaded Carbon Black G08 iX3 LCI M Sport Pro
Former: Glacier Ag. F31 328iA RWD M Sport oct. 2012, sold July 2022 | Sport Automatic | Adap. M Susp. | Pano. Moonroof | 20" ATS Racelight Grey w. Michelin PSS| M Sport brakes | Harman Kardon | Elec. Seats | PDC F&R | ACC Stop&Go | 335i MPE | Perf. Parts | |
06-29-2016, 09:58 AM | #15 |
Rep 1,476
I always thought it was dumb when people set their watches ahead by 5 minutes, so I'm not sure why I give this a pass! LOL!
06-29-2016, 10:25 AM | #16 |
Rep 16,060
It helps to know how cops work. If they're sitting on the side of the road with a hand held radar gun they can zoom in on individual cars and clock them. That's a lot of work. It's easier to use a window mounted gun that clocks every car, and set an alarm that goes off at a specified speed reading. But if they stopped every speeder that would be too much work too, so they set the alarm speed about 15% above the limit. If the limit is 65 they set it at 74. If you're doing 73 the alarm won't sound. If the limit is 65 I set my cruise at 73, knowing that will give me some leeway just in case I go by a cop who's more aggressive in his settings or has a badly calibrated radar gun. That all goes out the window in heavy traffic, there I just go with the flow. On the Jersey Pike that tends to be about 85.
06-29-2016, 01:09 PM | #17 |
Rep 6,989
Latest "cheat sheet" for 2-series shows "unable to find BC_DIGITAL_V_KORREKTUR". Also looked in BMW Coding Database and didn't find it. May not be an option on newer cars?
07-01-2016, 08:49 PM | #19 | |
Rep 597
When you say "distance traveled" do you mean odometer, trip, or nav unit? - tgm |
07-01-2016, 08:58 PM | #20 |
Zooombie attaaack!!
136
Rep 1,179
Who cares if it overestimates speed by a couple %, it's doing you a favor. Your odometer is not affected in anyway by altering the coding of the car. There are federal guidelines for weights and measures that the car must adhere to.
07-01-2016, 09:28 PM | #21 |
Rep 1,627
I personally would rather my speedo read the correct speed. I don't need or want any buffer. But.. I do appreciate my 435i being only about 2-3 MPH off at 80 MPH (optimistic) vs my e92 which was 4-5 MPH optimistic at the same speed.
M4 in MG | 6 MT
07-01-2016, 09:35 PM | #22 |
Rep 1,627
Because we want our gauges to give us correct information
M4 in MG | 6 MT
