BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Will these work???
Extreme Power House
      04-12-2018, 10:26 PM   #1
Alexcent
Drives: 2014 328i M sport 6 speed
Will these work???
Hello,
I just found an awesome deal on some forged wheels with Toyo tires and I want to buy the setup! I am just not if they are too wide and I am not sure of the offset. I have a 2014 328i. And I want to put on these wheels and tires..
Front: 19 X 9 +22 225/35/19
Back: 19 X 10 +24 275/35/19
Thank you guys so much
      04-13-2018, 10:10 AM   #2
N0Chill 335i
N0Chill 335i's Avatar
Drives: 13' F30 335i M Sport AW
Depends on how low you are and how much negative camber you feel comfortable running. The rears are a bit aggressive for that tire size. These will not be a bolt on fit at all.
I run 9.5 et25 rears with a 255/35/19 tire. I'm fairly low and run -2.4 camber. I could fit a 275/35 but I'd need full -3 camber to do it. Those wheels are also about 15-20mm more aggressive than mine are.
Drop down to 245/35 and they may work at -3.5 maxing out the camber arms.
Best of luck.
      04-13-2018, 06:54 PM   #3
shiftdnb
Drives: 2017 F31 328dx
I don't think those 19x10's will work in the rear with a 24 offset. I just ordered 19x10 and they're doing +38 offset on 265/30/19. According to wheel calculators it'll be about 1/16 of an inch inside the fender compared to around 5/16th of inch with OEM. With that +24 you're looking at just a little past 1/2".
      04-13-2018, 07:55 PM   #4
Alexcent
So I could buy the step up and change the back tires and then I would be okay?
      04-14-2018, 01:18 AM   #5
alohasurftoad
Drives: 428i gran coupe
this set up is too aggressive for someone that is uninformed about slammed/stanced setups. please review this thread.
http://f30.bimmerpost.com/forums/sho...d.php?t=909786
my opinion for you in, NOT to get these.
