07-17-2015, 02:36 PM | #133 |
Rep 35
Hi PandaNL,
You have created an excellent tool. Thank you for this great work One thing you should add is a reference list for Module names. Module names should be controled because people added several time the same module with a similar but not equal writing. It reduces the efficiency of your tool because different (and sometimes the same) codes are spreaded under several module which are finally the same. By exemple : FEM_BODY module is visible as - FEM_BODY (that's normal ) - FEM-BODY - FEM-Body - FEMBODY - fem body For me it's the most important evolution . But it's a lot of work because the actual content of the database must be normalized with this new rule. |
07-21-2015, 04:32 AM | #135 | |
Rep 60
Drives: F30 330e & E92 335i
Do you have a full list of all modules? I have a F21 and will check e-sys to get the correct module names, but I don't know if it will contain all modules that every F series have. |
10-11-2015, 05:48 PM | #136 |
Rep 60
Just updated the BMW Coding Database to version 1.4, I added a tab to create a profile for each car you code. It will save the profile to an xml file inside My documents under a folder called BMW Coding Database.
To update op the application and click in the top right side on the exclamation mark and click on install update. |
10-12-2015, 01:24 PM | #137 | |
Rep 80
10-12-2015, 02:28 PM | #138 |
Rep 11
The link on page 1 is not working for me.
http://tiny.cc/sfrj2w Is it working for you guys? I'd love to try this program out |
10-13-2015, 05:25 AM | #139 | |
Rep 143
(remove the spaces) Last edited by Makky; 10-13-2015 at 05:32 AM.. |
10-15-2015, 06:59 AM | #141 |
Rep 60
Changed the url on the first page. Problem is that bimmerpost still doesnt allow the words bmw and coding combined, so made a new tiny link.
10-20-2015, 02:25 PM | #142 |
Rep 968
I just installed the tool and will code my 2015 320i. I have to open my checkpoint firewall at home to tcp 3306.
I also need to code my 2015 X5. Do you have the required codes list for F15-2015 X5? Thanks! Last edited by leasehackr; 10-21-2015 at 12:27 AM.. |
09-28-2016, 11:33 PM | #146 |
Rep 26
09-29-2016, 11:01 AM | #147 | |
Rep 8,364
02-09-2018, 09:24 PM | #151 |
Rep 8,364
02-10-2018, 10:27 AM | #153 |
Rep 5,456
Drives: F30
Is this still available for download?
