03-06-2015, 12:17 PM | #45 |
Rep 5,316
Drives: G80 M3 6MT
Did you try to do the update yourself?
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
03-06-2015, 12:47 PM | #46 | |
Rep 536
03-07-2015, 02:22 AM | #48 |
Rep 536
03-21-2015, 08:47 PM | #49 | |
Rep 8
Were you charged for the NBT upgrade or is this covered under warranty? I hope the "BMW Genius" at Herb Chambers in Sudbury knows what needs to be done. |
03-23-2015, 10:17 PM | #50 |
Rep 135
it was covered under warranty. hopefully your dealership is easier to deal with than mine.
03-31-2015, 02:34 PM | #51 |
Rep 69
Dropped my '14 F34 off at the shop this morning for it's overdue 1st year service and asked them to take a look at this issue as well. Printed out the thread for the shop folks to read. Described how update won't take and the update is needed to fix an issue with iTunes Radio metadata not showing up correctly. Hopeful they'll do the upgrade, I'm at NBT_B currently ... not holding my breath though!
03-31-2015, 07:46 PM | #52 |
Rep 69
Success! They updated the car to NBT_I and installed the Bluetooth update. Finally I can have proper song metadata when using iTunes Radio, very pleased.
*edit* Forgot to thank twincam23 for his post, your service report was really helpful in explaining to them what needed to be done! Last edited by rowat; 03-31-2015 at 08:06 PM.. |
06-10-2015, 07:17 PM | #54 |
Rep 1,227
Sorry to revive this old thread, but it seems relevant.
I have a '15 F32 and I'm having the Spotify issues where the song name, artist, and album art remains with the first song long after I've moved on to other songs. Same with the song name that appears in the LCD screen under the speedometer/tachometer. I just want to clarify, there are TWO software updates here: 1. ConnectedDrive software (e.g. UPD05062), can be updated by myself via USB flash drive at home 2. iDrive/NBT software (e.g. NBT_I...), usually needs to be updated by dealer unless you're very comfortable with car coding and flashing the system. Is this correct? If so, how do I check which version of ConnectedDrive I have, in order to know if I should bother installing UPD05062. My car was manufactured in 07/14. |
06-11-2015, 12:21 AM | #55 | |
Rep 135
2. correct. |
06-17-2015, 11:03 PM | #56 |
Rep 1,352
Drives: 2018 M3 CS
So I took my '13 AH3 in for a chassis malfunction error that popped up one day (hasn't returned, so interested to see the code it threw) and SA told me I had a recall that apparently affects all activehybrids (3,5,7). Calls for a control module reprogramming, doesn't state why, so I assume my iDrive will be updated. I'm currently on H, so I'll report back on where I am after the reflash. I assume "I" is still the most recent?
2018 M3 CS F80 l SMB l EXEC
2020 X5 M50i G05 l MW l BLACK l PREM l DHP l 22” l PARK l EXT S-LINE l LASER l TH l AG |
06-19-2015, 10:11 AM | #57 |
Rep 1,352
Drives: 2018 M3 CS
So, just a quick update...car is still at dealer, seems they couldn't find the cause of the chassis malfunction error message, just an "under voltage" code. But they did also note there is a bulletin to replace the aux fan to a bigger one...any other AH3 guys had this done? Mine is an M-Sport, I'm wondering if this is the same fan issue the M-Sports were having even two years ago, and they are replacing it just in an effort to fix the problem.
06-22-2015, 10:37 AM | #58 |
Rep 1,352
Drives: 2018 M3 CS
Final update...so per the AH recall, my control unit was reprogrammed. The aux fan issue, which does seem to be the same issue the M-Sports have been having for some time, was fixed with the new, higher output fan. Not sure if that was causing my chassis error, but they replaced it anyways.
So as it stands, I am on "I" integration level, and I was able to successfully update my BT software using UPD05062 (even though I was a mid 2013 build), I am assuming because of the higher integration level. Software shows: 002.255.060 002.255.062 Looks like I am good to go for now.
06-28-2015, 04:53 PM | #59 | |
Rep 235
Drives: 2014 F31
06-28-2015, 07:35 PM | #60 | ||
Rep 1,352
Drives: 2018 M3 CS
10-26-2015, 06:08 PM | #61 |
Rep 85
Hey guys, just been reading thru a bunch of different posts and would like to clarify some things. I guess I have the CIC head unit and that is the version before NBT, so these updates that i've been reading about on this post is all related to NBT and has nothing to do with CIC? Can anyone tell me if I go thru the hassle of getting BMW apps or 6NR and buying some sort of fsc code, will that give me the ability to use the connected drive app with my car and to be able to control spotify?? Currently, the connected app on my phone gives me an error message and can't connect. I can stream spotify and other music from my phone to the radio either thru blutooth or usb, but the cover art doesn't update and all I can do is next song or prev song. I would like to be able to browse playlists etc. Can anyone on here with CIC confirm that getting 6NR will do this for me on my iphone? TIA
10-27-2015, 11:09 AM | #62 |
Rep 38
I have been following this thread to resolve a similar issue. My sat nave, possibly as it is a Euro spec does not have an options menu under Navigation or any such identification number anywhere that i can find.
Are the Euro and North American softwares fundamentally different? |
10-27-2015, 06:28 PM | #63 | |
Rep 38
Mine is NBT _D125051 101112.2.117 for Europe 2013 |
10-31-2015, 07:40 PM | #64 |
Rep 47
My dealer has updated my car to integration L (NBT_L ), and both the phone and multimedia versions start with MN.003.xxxx .
Spotify now works perfectly with the song information/metadata. |
11-14-2015, 08:54 PM | #65 |
Rep 9
I started having BT connection issues again. I was able to do a software update to resolve the issue, but now a month later the connection issues are back. I have a Samsung Note 4 it connects then disconnects. Do I need to bring it in for an update?
03-11-2019, 12:34 AM | #66 |
Rep 4
Bluetooth artwork missing
Just updated my software to: UPD07041 thinking that this would give me my art work back...it didn't.
I have a 2015 328i xDrive, I feel like I had the art work showing say 2 weeks ago, and it stopped. I then went the update route, and now I still have no artwork.. Has anyone done a previous software restore? Thinking of doing it. Any suggestions? |
