09-11-2014, 02:58 AM | #1 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
HELP! I have no idea what these codes mean
So recently i installed the ATM FMIC and the CG precision 3.5" exhaust, the day after the install ive been having problems. ive lost a lot of HP and Tq, pretty sure i have a bad boost leak somewhere but ive been too busy to look for it. The one wierd thing that doesnt seem to add up is it doesnt shift gears when i floor it, it just stays at redline until i let off the gas. But with normal driving it shifts gears just fine but still feels very underpowered. is that a sympton of boost leak also?
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| Last edited by obriennathaniel; 09-11-2014 at 07:36 PM.. |
09-11-2014, 12:11 PM | #3 |
Rep 190,750
If you have CObb or JB4 check the codes and post some logs.
09-11-2014, 07:00 PM | #4 | |
515
Rep 1,063
not on the dash no
I also checked every connection on my intake up to the manifold and everything is solid, sensors included.
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| Last edited by obriennathaniel; 09-11-2014 at 07:15 PM.. |
09-11-2014, 11:04 PM | #5 |
Rep 341
If I were you I would lift the car and start it and see if you have a leak along the exhaust. Although that kind of dip in the graph probably is not the exhaust but I would check around your down pipe.
09-12-2014, 12:30 AM | #6 |
515
Rep 1,063
I did, i checked the downpipe to the turbo manifold connection and to the exhaust, all solid
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
06-03-2015, 09:06 AM | #7 |
Rep 577
Did you ever figure this out. I think I have the same issue.
I'm thinking it may be the Diverter Valve leaking (apparently common) I also have an ATM intercooler. I removed my Chargepipes and put back the OEM ones as thought they may be leaking, but I still have the same issue. |
