12-04-2012, 09:57 AM | #67 |
Rep 1,297
there is a guy at my work, who worked at a gas station while going to school, and he said the owner of the gas station would mix grades, so the 93 would actually be a mix of 87+89 or just one of the others, that way he would make the money on the difference plus whatever they get, I will check with him later what gas station that was, i know its somewhere by IIT
12-04-2012, 10:19 AM | #68 |
Rep 2,118
Unless you added a modification that can allow the engine to make more power at higher octane, none. the stock engine makes maximum power with 91 octane fuel in the US. The engine computer will not advance the timing to compensate for the higher octane fuel.
12-04-2012, 11:59 AM | #69 | |
Rep 87
12-04-2012, 06:27 PM | #70 |
Rep 1,285
Every state has a regulatory agency that checks for this, as well as pump accuracy. Hopefully he will get caught.
12-04-2012, 06:31 PM | #71 | |
Rep 1,285
Additionally, you may experience decreased performance; when a high octane fuel's resistance to detonation gets too high it effects combustion, wave front development, etc. in an engine not designed for it. |
12-04-2012, 09:13 PM | #73 |
Rep 49
My only input is:
1. RTFM that is localised for your country. 2. 'Premium' I think is the universal word here. For example, here in Australia we typically have readily available 91, 93, 95 and 98 Octane. 91 is usually a 10% ethanol blend. the 'Premium' fuels are typically the 95 and 98. Now in Australia we unfortunately have poorer quality fuel in the lower end of the spectrum, so I run only 95 or 98. Additionally and importantly, across both my v8 landcruiser and the 328, I have run measurements in fuel consumption and because of all the nice additives I get a much higher mileage which brings the total cost back to almost being competitive with running the 91. Also, the additives list in the 98 seems to keep my hi mileage landcrusier running more smoothly and better power (seat of the pants measurement on that last point). |
12-04-2012, 10:14 PM | #75 | |
Rep 7,047
Personally I've never tried going to lower octane and then back to see if there really is an MPG difference. In general: Another thing to keep in mind is that timing control is not static, it's continuously variable based on sensor readings telling the ECU how the engine is performing. Why is this important? It's easily acceptable that an F30 driver using 89 isn't experiencing any performance problems because in order to continually pull timing the engine would have to continually knock at such a level such that the sensor would tell the ECU to keep correcting. However, knock events that would trigger an adjustment may not be happening all that often even with 89US octane. Knock tends to rear it's ugly head under heavy loads, such as driving up steep inclined roads on a hot day, or driving hard through twistys at higher rpm and the temps are hot. These conditions are when knock can come out to play. If a driver is simply commuting at average speeds and at lower rpm, those knock events may simply not manifest. The ECU continually strive to bring tuning up to optimal. So if there aren't knock events even when using 89 there is no reason for the ECU to pull timing. The engine will be running at peak performance under those driving conditions. In winter and colder temps the chances for knock events is lessened. It's safer to run lower than optimal octane during this type of weather condition. So, I can see why some say their engine is running just fine and they feel no difference. The problem of knock becomes more likely with drivers who like to drive harder more often where they are driving their engines at higher rpm and the engines running hotter. This type of driver may very well feel a decrease in performance when using lower octane fuel. And in the summer months lower than optimal octane may really decrease performance as the hotter atmospheric temps combined with hard running higher loads and engine temps create a condition that calls knock out to play. I choose to run higher octane year round not only because the engine was designed/tuned to use it, but also because it provides a greater cushion before the conditions become favorable for knock. By using the correct octane the engine will always be running at it's highest state of tune instead of a continual state of correction and lower tuning level. We, at least I, buy these cars for the performance they provide from these great engines. I want my engine to perform at it's highest level of tune and not at it's lowest level of acceptable before damage can occur. Last edited by RPM90; 12-04-2012 at 10:30 PM.. |
12-05-2012, 05:52 AM | #76 | |
Rep 49
And agree with your last point emphatically. I dont see the point of having a luxury turbo car and not running good fuel in it, IMHO. |
12-05-2012, 09:48 AM | #77 |
Rep 98
See this article from FTC>
http://www.ftc.gov/bcp/edu/pubs/cons...tos/aut12.shtm and this show was interesting too >> http://www.cbc.ca/marketplace/episod...mpfiction.html |
12-05-2012, 10:13 AM | #78 |
Too much is never enough
655
Rep 3,079
This forum is like Groundhog Day all over again. How many times are the same subjects/arguments/discussions going to be recycled?
Unrelated - did you know the seat frames on the F30 come rusty from the factory and that it causes the brakes to squeal and the steering wheel to vibrate? True story. |
12-05-2012, 04:09 PM | #79 | |
Rep 49
I like my rusty seats. They give at least 0.2 bar additional boost. |
12-06-2012, 04:48 AM | #80 | ||
Rep 15,858
NOTE: this post is using UK fuel ratings.
BMW used to say something like this in UK data: Quote:
For my engine N55 (535i) brochure and user manual "recommends the use of RON 95 super unleaded..." RON 95 is not "super" unleaded in the UK, RON 97/98 is super unleaded. No wonder there is confusion in the different markets, if BMW don't seem to be consistent in their comments. Why test with the higher octane rated fuel, RON 98, and then recommend a lower octane, RON 95? I think the clue is in the earlier comments, "output and consumption with the RON 98", or am I a cynic? Go figure. BTW, having tried different fuels, I now use a super unleaded fuel, RON97/98. Engine is smoother, quieter, butt dyno senses it is more eager in the mid range when pulling hard, and typically returns a better mpg. HighlandPete Last edited by HighlandPete; 12-06-2012 at 04:56 AM.. |
12-13-2012, 08:37 PM | #81 |
Rep 15
In my part of the world, the oil companies charge 15 cents/litre more for 89 over 87 (or 50 cents US gallon). I therefore never bought it because it was merely 'recommended'. I never noticed any difference in performance in the e90. I just bought the new f30 with the 4cyl turbo and after reading this thread and against my better judgement I decided to splurge and bought 91. Guess what? No difference in performance or mileage. It's all bs. Save the cash and stick with 87.
12-13-2012, 08:49 PM | #82 | |
Rep 121
There may be some microscopic cracks in your scientific method. |
12-13-2012, 08:50 PM | #83 | |
Rep 70
Using 89 octane means it will burn quicker and therefore when your pistons are reaching TDC, you have already lost the optimal power generation point. |
12-14-2012, 09:38 AM | #84 | |
Rep 195
"Unless it’s recommended by your owner’s manual, don’t spend the money on high octane gas." Notice the bolded part? And what do all these BMW owner's manuals from around the world recommend under "Recommended Fuel Quality"? Higher-than-standard octane, with the numbers being pretty much the same when you adjust for the different measuring systems. I mean, the FTC literally says , that's a pretty big hint. |
12-14-2012, 06:12 PM | #85 |
Rep 1,285
Amusingly, the 2013 manual states BMW recommends both: "BMW recommends AKI 89" and "BMW recommends AKI 91"
The 2012 manual makes no mention of AKI 91, only that AKI 89 is the recommended minimum octane. Thus, use either 89 or 91, your choice. Pick one. Or both. Don't agonize over the issue, it is a small question even in the world of cars - much smaller in any larger context. |
12-14-2012, 10:22 PM | #86 |
Rep 371
When I open my gas door it says use premium fuel which is 91 octane or higher. Why are people still talking about this?
USE PREMIUM GAS IN YOUR TURBOCHARGED BMW!! |
