09-17-2016, 05:26 PM | #1 |
Rep 265
10mm front spacers? 437M Replicas
Hi,
Just lowered my car with H&R Sport springs. I got the 437M Replica wheels with these specs: Front - 19x8.5 ET38 Rear - 19x9.5 ET40 I think a 10mm spacer with be just right to make the front as flush as the rear already is. But when searching the forums for information, some people say that the front hub lip is over 10mm. But I have found a lot of spacers (for example BMS) that clearly states you can use the 10mm spacer in the front (but only in the front). So is it possible to use a 10mm hubcentric spacer in the front? Cannot remove my wheel to measure right now sadly. And if anyone has done this with a wheel with the same dimension, is 10mm the correct spacer you think? Pics? Thank you! |
