BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 328i 335i Front Kidney Grill / Grille removal and replacement DIY
      05-11-2017, 10:17 AM   #221
silver28
Drives: 2014 F32 435i xdrive 6 speed
I first attempted it for 10 minutes and couldn't do it. Then I read this thread, and built up the courage to use some extra force. Lots of info on here so I can't add much more but I started with upper right side on driver's side. Used fingers at first and then used this tool for the sides and bottom. It's just from a metal shed hook and I bent it into this shape. Took 6 minutes the second time around. Good luck everyone!
      05-11-2017, 11:07 AM   #222
Rick Hunter
Skull Squadron Leader
Rick Hunter's Avatar
237
Drives: '07 M Coupé & '16 435xi GCoupé
I posted this a while ago. There's no need to go through the hassle of dismantling the front bumper.
http://f30.bimmerpost.com/forums/sho...44&postcount=1
      05-12-2017, 01:52 PM   #223
GTBrandon
GTBrandon's Avatar
Drives: F34 M-Sport
2014 335xi GT  [5.00]
Thanks for this! I'm going to try when I get home! Did you paint your own grilles or install aftermarket?
GT stands for Giant Trunk, right?
www.youtube.com/Channel/UCJdwA05Tsz3WHJFBHXWi9JA
Frank Smith ECU Flash, VRSF DP, CTP FMIC, FTP CP, and K&N Drop-In
      05-12-2017, 02:45 PM   #224
Rick Hunter
237
BMW M Performance Grilles
      05-17-2017, 03:04 PM   #225
insanecoder
Drives: 340isDrive
Its a good idea but there may be a risk of breaking off either the outer or inner tabs .. you did it this way w/o a hitch?
      05-17-2017, 09:31 PM   #226
Rick Hunter
237
No risk whatsoever.
      05-18-2017, 09:41 PM   #227
the dope steez
Drives: F30 335i M-Sport
I'll throw in my two cents. Takes two seconds to do this once you figure it out. I have long skinny fingers so that helps but you should be able to do it regardless.
I started with the far outside clip on the first grill. It was simple to reach in and pull the clip back. Once you have one it will be easier to get the rest. Don't let it clip back in, and then get ready to pull on that side of the grill. Reach in to the next clip over on the bottom side and then pull it up the right way, then swift yank and it should come out clean (I fell on my ass when it popped out).
The next side is simple with the other removed
      05-19-2017, 09:49 PM   #228
Mountain_Commando
Mountain_Commando's Avatar
190
Drives: 435i Gran Coupe M-Sport
++1 on doing it without unscrewing the hood.
I fashioned a hook similar to yours from a pair of kitchen tongs.
First undid the side clip with just my finger, that was easy enough to reach.
Then worked my way through the others using my hook.
Important to give the grill a strong tug after each clip is disengaged.
Once one grill is out, unclipping the other through the big, gaping hole is a piece of cake.
And of course, the replacement grill simply snaps right in. Total process took me barely 10 minutes. Yay!
      07-10-2017, 03:01 PM   #229
blackabass
Drives: Estoril Blue 320d MSport
Looking to do this for my Blue Msport F30.
Anyone with a link to where I can buy.?
      07-13-2017, 08:19 AM   #230
Mountain_Commando
190
eBay is replete with Chinese made grills for under $50. That's what I have on my bimmer, and they're perfectly good quality.
      07-15-2017, 04:18 PM   #231
blackabass
Cheers mate. I got one from eBay and have fixed it already...looks really good.
      07-16-2017, 06:18 AM   #232
blackabass
Done and looks good.
Honestly, I think BMW should stop fitting Chrome Kidney Grills to the F30s. Anyways this is my first ever retrofit. I hope to do much more soon on my Bleu MSport F30.
The first step get your grill. I got mine from here. → http://www.ebay.co.uk/itm/231708287003
It arrived next day in the post.
Note
  1. You do not need to open the bonnet. I used my hand throughout and no issues or bruise. At some point, I thought of rubbing some cream to avoid bruises or friction on my skin but that didn't happen.
  2. There are 8 clips/lids/locks per grill. 3 at the top and bottom, 1 on both sides
Steps to retrofit
  1. Slide your hand through the grill carefully and pull the lids at the top down while you use the other hand to pull the grill slightly, from the front with little force.
  2. Do this for all 8 clips/lids/locks. Sometimes they go back inside as you do another so may be wedge the open ones with something once they are pulled out.
  3. Once you remove the first grill, the second is easy as you don't have to slide your hands through the grill anymore just put through the back from the side you just removed.
  4. Now that you have both grills removed, wipe the surface clean to remove any dirt.
  5. Place the new grill one at a time making sure the clips/lids/locks are in position then push gently till it goes in and clicks. Repeat same for the other grill and job done.
Pictures added soon as I am able to do so.
Cheers.
Next retrofit on my list.
  1. Glossy black AC Trim
  2. NBT2 EVO + iDrive 5
  3. Adaptive bi-xenon or LED
  4. LCI LED Backlights
      07-17-2017, 11:23 PM   #233
Mountain_Commando
190
I couldn't agree more! The black grill just makes a bimmer look so much more sporty and aggressive.
      08-03-2017, 05:25 AM   #234
free2d
Drives: F30 335
Most of u guys get the matte or glossy? Still thinking to do which for DIY.
My ride is black color.
      08-03-2017, 10:02 AM   #235
blackabass
It depends on what you like to be honest and also what colour is your car.
Matt Black is cool but I went for Glossy Black just to give is more sporty trim.
either one is supper cool.
      08-05-2017, 10:58 AM   #236
Mountain_Commando
190
On a black exterior, glossy for sure bro. It complements the body color which itself is glossy-ish.
435i Gran Coupe | ///M Sport Pkg | 430hp | MHD Stage 2+ | BMS Intake | Catless Downpipe | FMIC | Black Sapphire exterior | 9H Ceramic Coating | Black Anthracite interior | 19" Black ///M Wheels | Red ///M Brake Calipers | Alcantara ///M Steering wheel | ///M Metal Pedals | Alcantara dash panel | Carbon Fiber trims and gear knob | Angel Eyes LEDs | Surround Cameras | Spoiler | Coded ///M iDrive, Mirrors, HUD |
      01-11-2018, 11:36 AM   #237
F30xx
F30xx's Avatar
Drives: F30 2015xx
Great write up
      01-19-2018, 05:27 AM   #238
gobigkid
1st attempt: fail to remove
2nd attempt: Thanks to all the posts in this thread, I successfully remove the grill without opening front bumper. I did broke one tab due to my clumsy hand. Anyway, I won't use the chrome kidney grill anymore
Love the black grill so much.
      02-24-2018, 03:32 PM   #239
JoeF36
Drives: BMW 420d M-Sport
I did this today on my F36.
Didn’t even lift the bonnet. Honestly there really is no need. Reach in between the grill slats and release the side ones first. You need to give it a firm tug while simultaneously pulling the clip back. Once you release one of the side clips, the top ones start coming out easier. Took me 7-8 minutes to remove one side and only a minute or so to release the other one. Didn’t break any clips.
3 series f30, 3 series f30 forum, 3 series forum, 3-series forum, bmw 3 series f30, bmw 3 series forum, bmw 3-series f30, bmw 3-series forum, bmw f30, bmw f30 3 series, bmw f30 3-series, bmw f30 forum, diy f30, diy guides f30, f30 3 series, f30 3 series diy, f30 3 series diy guide, f30 3 series forum, f30 3 series grille, f30 3 series grilles, f30 3-series, f30 3-series forum, f30 diy, f30 diy guides, f30 forum, f30 forums, f30 grill, f30 grill diy, f30 grille, f30 grilles, f30 grills, f30 kidney grille, f30 kidney grilles
