09-30-2013, 02:56 AM | #4709 |
Rep 31
09-30-2013, 02:59 AM | #4710 |
Rep 6
Hi Shawn,
I don't quite understand the link between versions of e-sys and PSdZData. Say I have e-sys 3.22.5. Will it always be compatible with any newer versions of PSdZData? I just want to ensure that if I buy an e-sys version (token etc.), I won't have to buy a new version every now and again. Thanks for you answer! |
09-30-2013, 05:33 AM | #4711 |
Rep 40,919
Yes, no problem. It works fine on Win7 or Win8, both 32-Bit or 64-Bit.
09-30-2013, 05:37 AM | #4712 | |
Rep 40,919
09-30-2013, 10:05 AM | #4713 |
Rep 42
Drives: 2013 335i M-Sport
Also answered via PM:
exact target name = F010_13_07_506VehicleInfoF010 (no DIRECT at end) "Connection via VIN" checked? = YES "Read Parameters from VCM" checked? = YES
2013 335i M Sport - Estoril Blue II / Black Leather
09-30-2013, 10:29 AM | #4714 | |
Rep 40,919
F020_13_07_506VehicleInfo=F020 2) This is wrong: "Read Parameters from VCM" checked? = YES "Series, I-step (shipment)" should be checked, with no values in the drop down box.
09-30-2013, 12:18 PM | #4715 | |
Rep 42
GAH!
I had been using with "Series, I-step (shipment)" checked. I thought you meant to use the "parameters from VCM". Regardless, it was F020 vice F010. Apparently I need to work on my reading comprehension skills. I had it in my mind it was F010 and all the documentation clearly states F020. My humblest apologies. Coding is now complete, and I feel like an idiot. Quote:
09-30-2013, 01:02 PM | #4716 | |
Rep 40,919
09-30-2013, 07:01 PM | #4717 |
Rep 40,919
2014 North American Premium Road Map for CIC
The 2014 North American Premium Road Map for CIC came out early this year:
See my post here in the General Forum for details: http://www.f30post.com/forums/showth...8#post14744158
09-30-2013, 10:52 PM | #4718 |
Rep 387
Is there any way to increase the brightness of the interior lighting? I have it set to max in the iDrive menu and its still not very bright, I have noticed that it is also dependent on the dial on the headlight switch assembly, but I don't want to increase that anymore. I would actually love to lock it at 100% the whole time... So has anyone found any codes that pertain to the interior lighting?
Edit: Just to be clear, I'm referring to the ambient lighting when the doors are closed and its dark outside.
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive WE ARE! |
10-01-2013, 02:22 AM | #4719 | |
Rep 16
I've found it here |
10-01-2013, 03:50 AM | #4720 | |
Rep 6
thanks for your answer! And are there significant improvements from one e-sys version to the other? |
10-01-2013, 08:56 PM | #4721 |
Rep 40,919
Not really. I would only update if I had no choice, or my EST Token was expired, and I needed another one.
10-02-2013, 01:05 AM | #4722 | |
Rep 387
The next request is Follow Me Home lights, IE: a short tap on the trunk button will turn the xenon's on for a few seconds.
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive WE ARE! Last edited by azwillnj; 10-02-2013 at 01:13 AM.. |
10-02-2013, 06:32 PM | #4723 |
Rep 214
Guys I get this error for some ECUs. Does this mean I need the new data file? I checked it and the file is not in the data file I have.
Current: 2019 G05 x5 50i M-Sport
Past: 2016 F10 550i M-Sport ~ 2015 F83 M4 Convertible ~ 2013 F30 335i M-Sport ~ 2006 E85 Z4 30i |
10-02-2013, 09:51 PM | #4724 | |
Rep 40,919
What PSdZData version are you using, and what is your current I-Step? http://www.f30post.com/forums/showpo...postcount=1403
10-02-2013, 11:46 PM | #4725 | |
Rep 214
10-02-2013, 11:50 PM | #4726 | |
Rep 40,919
PM sent.
10-03-2013, 12:03 AM | #4727 |
Rep 214
10-03-2013, 05:20 AM | #4728 |
Rep 2
Hi Shawn
I am a newbie to F10's (bought a 2011 535d early this year) and have come across this incredible thread. I understand i need to get or make the good cable to connect to my car but am a bit unclear so far (didnt read over 200 pages of thread yet) about what software i need, where to get it from or what it costs. Could you also tell me where to get ISTA from for doing diagnostics, resetting service indicators etc thanks very much for your help John |
10-03-2013, 05:27 AM | #4729 | |
Rep 40,919
10-03-2013, 11:51 AM | #4730 |
Rep 23
Has anyone coded the headlight washers so they dont spray down the entire hood of the car?
In that case it would be great if you would share an exact how-to on how it was done Thanks |
