BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > US F30 M Sport models will get Euro Brake Pads
Extreme Power House
      05-08-2012, 03:30 PM   #1
E90Fleet
South Africa
1071
Confirmed:
US M Sport models will not get the regular low dust, less bite US brake pads but will be fitted with Euro spec pads on the standard rotors.
US cars with the optional M Sport brakes fitted models will also receive the same Euro pads as their European counterparts.
BMW if you are reading, I need a job, Please.
      05-08-2012, 03:32 PM   #2
Maz335i
BMW 4 Life...
Maz335i's Avatar
Drives: 2015 SO M3 (on order)
As always man, great stuff!
Can't believe you don't work for BMW. Or are you fooling us? Lol
      05-08-2012, 03:34 PM   #3
sleedawg
Drives: 2015 328i & 2011 335i
Now the bigger question is... which rotor? Standard rotor meaning 340mm or 370mm non-drilled. I assume 340mm.
      05-08-2012, 03:49 PM   #4
E90Fleet
South Africa
1071
M Sport pack does not change the rotor with standard brakes.
Optional M Sport brakes will get a solid rotor (unlike what some initial info said, but confirmed at motor shows and latest documents).
The slotted/partially drilled rotor from the M Performance retrofit kit is available from the dealer for retrofit ( Also in standard sizes).
With M Sport brakes US and Euro 335i and Euro 328i get the same solid M Sport rotors (370x30).
With M Sport brakes US 328i get the standard US/Euro 335i rotor and standard 335i calipers, but painted blue, fitted with Euro pads (340x30).
      05-08-2012, 04:01 PM   #5
clarence
Drives: F30 328i M-Sport
Do u know wht is the weight difference between Euro standard 328i brakes & Euro 328i M-sport brakes? Also wht is the size of the rear discs on the standard Euro 328i brakes?
      05-08-2012, 05:51 PM   #6
jbres79
Drives: SS/GTI/335xi M Sport
what i am goign to have to figure out is if getting the M sport brakes pkg + M Perf drilled rotors will be less or more than not getting M sport brakes pkg and just going with the entire M Performance brake pkg.
      08-24-2012, 07:24 PM   #7
bmrm396
Drives: 2016 F80 M3
Is this the case? Now that these msports r rolling in has anyone confirmed or felt this change?
Formerly addicted to e90post
      08-24-2012, 07:37 PM   #8
justinnum1
Drives: 2015 328i Msport 6mt
wait a second...what does this mean exactly?
The msport cars(not the 2,000 brakes) will have different brakes than the sportline?...how so?
what will be the difference in brakes between the 35sportline and the 335 msport?
edit-just noticed this was created months ago
F30 328i Alpine white/Coral red Msport 6MT, HK, Zenons, msport brakes, black grills and black side sills. mperformance exhaust
      08-24-2012, 08:29 PM   #9
jpoet
Drives: 2013 335i M Sport
The brakes on my M Sport are definitely not what I would call low dust. I've only had my car for 3 days and the wheels are already filthy!
2013 335i ///M Sport, Estoril Blue II, Dynamic Handling, Sport 8AT
      08-24-2012, 08:42 PM   #10
verbs
Drives: 2015 M235i
Different brake pads, not brakes. The brake pads on the M-sport supposedly are a bit more performance oriented, and performance oriented brake pads tend to create more brake dust and not last as long. It's a trade off. The sport line and other 335i models supposedly have a lower dust/lower performance oriented brake pad.
      08-24-2012, 08:44 PM   #11
justinnum1
i'm all for better brakes
      08-24-2012, 09:26 PM   #12
bmrm396
Drives: 2016 F80 M3
^^^ me too but i keep holding out HOPING and WAITING for msport blue brakes to come to the US ... pleeeeeeeeeeeeease BMW, for the love of god
      08-24-2012, 09:31 PM   #13
justinnum1
yea, those blue breaks would match my estoril blue paint
      08-24-2012, 10:59 PM   #14
RPM90
Drives: 340i M-sport AT
I missed this originally.
Interesting.
I wonder how they'll feel?
My last test drive was at the drive event with a 335i sport line.
Wonder if I'll feel anything different.
Day one when I get my Msport is to do a bedding session on the way home.
Must be done.
Don't forget to bed the new brakes for all new 3's.
      08-24-2012, 11:06 PM   #15
justinnum1
Interesting.
Must be done.
what are you going to do to bed your brakes?
      08-25-2012, 12:57 PM   #16
Elk
Drives: 2012 335i
One of many descriptions of brake pad bedding: http://zeckhausen.com/bedding_in_brakes.htm
It is amusing with some aggressive race pads as they smoke when first truly heated.
Take the advice not to use greater speeds seriously. The F30 is a street car with street car brake cooling. It is quite easy to melt piston seals, etc.
      08-25-2012, 09:39 PM   #17
RPM90
Elks link shows a good procedure.
Here is another one:
http://www.american-performance-auto...procedure.html
The idea is the same though some show different speeds, number of times, etc...
I use a method closer to the link Elk posted.
And, as Elk said, DON'T heat them to the point of smoking.
I start with the low speed method and progress to higher speeds, then a decent length highway speed drive to let things cool nicely without applying the brakes hard
I wonder if the Msport cars will get something in the manual telling us about the different pads, along with BMW's bedding recommendation.
      08-25-2012, 10:16 PM   #18
Elk
Drives: 2012 335i
I'm sure BMW will merely suggest no hard braking for ___ miles, typical manufacturer break-in procedure.
      08-25-2012, 11:19 PM   #19
bcl0328
Drives: 2012 328i
paint em? lol
      08-25-2012, 11:58 PM   #20
Elk
Drives: 2012 335i
It is, in fact, easy to paint calipers if the color is important. You just need high temperature paint and a little patience.
      08-26-2012, 12:16 AM   #21
Maz335i
BMW 4 Life...
Maz335i's Avatar
paint em? lol
Exactly!
I did mine in red!
...and I love them!
      08-26-2012, 01:10 AM   #22
bmrm396
Drives: 2016 F80 M3
paint em? lol
If someone wants to hand me their single fixed piston rear setup from tht package I'll swap out the r bum US sliding calipers fair and square haha
