03-24-2017, 02:22 AM | #111 |
Rep 2,357
Nobody has found an even more optimistic dyno yet for a new WR? I'll hopefully post a "delta record" soon - should not be difficult to beat but just to change focus to something tangible.
(A Dane in China) |
03-26-2017, 08:45 PM | #112 | |
Rep 33
05-14-2021, 09:02 AM | #113 |
bt5000
Rep 45
02-07-2022, 01:32 AM | #114 |
Rep 1
f30_garcia question on meth
What kit were you originally using?
During that dyno (446whp), sounds like it was charge pipe injection kit? After your upgraded turbo you went direct port? I see the controller was snow so maybe that was the entire kit you used. Thanks |
02-07-2022, 06:03 AM | #115 |
1296
Rep 3,533
This thread is like 5 years old man
01-20-2024, 08:29 AM | #116 |
Rep 2
Nice setup and numbers I wonder how much power I’m making on my 435i with
Upgraded charge pipe Vrsf intercooler MHD stage 2plus Catless downpipe CTS Intake I’m From Australia running 95ron/91oct Would I need a hpfp to get to 400hp or close to ? Or is it not worth it unless I upgrade turbo ? |
01-21-2024, 03:17 PM | #117 | |
Rep 7,606
01-23-2024, 01:11 PM | #119 |
Rep 7,606
01-23-2024, 09:32 PM | #120 | |
@_sunbish
282
Rep 611
It's not the ethanol % content that limits the fueling, it is the aggressiveness of the map/tune.
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5 |
01-24-2024, 01:21 PM | #121 | |
Rep 7,606
It goes without saying that you should select the correct map for your hardware. But even if you select the correct map if you run too high of an E% in the tank, the HPFP will crash. OP specifically asked about stage2+, so lets say you run the stage 2+ E20 stock HPFP map on MHD. Then you put E40 (40% ethanol) in the tank. Your HPFP is going to crash. MHD maps have a little headroom compared to BM3 maps, where you can get HPFP crashes with cold temperatures or slightly overshooting the E% in the tank above 30%. If you have been using MHD for a long time you may recall it used to actually be an E30 map, which they later changed to E20 to give more headroom. If you look at the website there is still a typo as it reads: "Ethanol Mix Maps: Stage 1, 2 and 2+ E20 Maps for ethanol blends of 30%" https://mhdtuning.com/products/mhd-s...icense-for-n55 So it doesnt matter if you select the stock HPFP map if you put too much ethanol in the tank the HPFP will crash. The tune will determine how high of an E% you can put (i.e., based on boost target). |
01-24-2024, 01:43 PM | #122 | |
@_sunbish
282
Rep 611
Take a look at your last sentence and my last sentence. You just typed out a lot of things for no reason.
01-24-2024, 01:58 PM | #123 |
@_sunbish
282
Rep 611
Stage 1, 2, and 2+ full E85 maps available.
Stage 1 & 2 for stock hpfp. Stage 2+ for upgraded hpfp.
01-24-2024, 02:49 PM | #124 | |
Rep 7,606
I get that your interpretation of his post was a literal E85 map (85%), but when the majority of people talk about "running E85" they are not talking about a full E85 map. I'm not arguing with you or disagreeing with what you are saying MHD offers in terms of map options. It's simply providing the context and other information for someone who is new to running E85 maps. So it's not for "no reason", its to be helpful to someone new on the forum. |
5w20282.00 |
