02-03-2013, 08:41 AM | #2465 | |
Rep 490
02-03-2013, 08:45 AM | #2466 | |
Rep 490
Thanks for being guinea pig for office (I did say its not verified) Let me know if u can see office and picture in your Bluetooth settings, if not, can u send me your cmb_medi caf file and I'll check what else need to turn on. I believe by now all is working. Just need to confirm. |
02-03-2013, 08:50 AM | #2467 | |
Rep 490
The above will get you all feature of bmw apps minus iPod video, if you want this then you'll have to add/solder a cable from your armrest USB port to the cic headUnit. Shawn did suggest using USB from Mini (the car) to retrofit as an alternative. |
02-03-2013, 09:13 AM | #2468 | |
Rep 1,544
As for 6NR, it may be due to video function of 6NR. So if ur ifone supports chi then it'll display it as video inputted from the ifone. Someone has to try 6NR w/o vdo function to see if it works. |
02-03-2013, 09:45 AM | #2469 |
Rep 41,033
02-03-2013, 09:50 AM | #2470 |
Rep 41,033
I have PM'd you the source where I bought mine from since no U.S. Dealer would sell me one.
02-03-2013, 10:05 AM | #2471 | |
Rep 41,033
Also, it is easier to just edit your existing 6NH, and change the H to a K. Make sure you hit the Ctrl-Enter afterwards to save the SALAPA-Elements before you calculate FP: ...-> Change 6NH to 6NK -> Ctrl-Enter -> Calculate FP -> Save new FA Writing the modified VO to the car is not necessary, but up to you. You can just load it, and activate it after changing it, and then use it to VO Code.
02-03-2013, 10:08 AM | #2472 |
Rep 41,033
Yes, it is simple. If it fails, revert back to factory VO, and then VO Code the ECU's again with unmodified VO.
02-03-2013, 10:15 AM | #2473 | |
Rep 41,033
However, personally I don't do this. I like to be connected to the car, and code one ECU at a time, and write it to the car, and make sure everything is working as expected before moving onto the next ECU. With the E-Sys search box, and my cheat sheet, I can copy and paste and make multiple ECU FDL changes in only a couple minutes, so I don't mind sitting in the car to do it.
02-03-2013, 10:21 AM | #2474 | |
Rep 41,033
If you Import and Activate the 6NR FSC Code, you must in this case also make sure 6NR and 6NF are written to the car's VO. If not, Dealer Programming will terminate the FSC Code with extreme prejudice, and recovering it may be impossible.
02-03-2013, 11:13 AM | #2475 |
Rep 51
Successfully coded from 6nh to 6nk
- Cover Art ist working - Office menu came out of the box (Basically I am not sure if I was there before...) - Bluetooth (Audio) menu appeared Can not test audio streaming and office functions because my smartphone (Galaxy S) seems not to be compatible with MAP Protocol. It recognizes my phone only for contacts and not for streaming. Office menü also only shows contacts no sms or email. Do you know an up 2 date smartphone which supports all these functions? Or is there another setting neccessary to activate sms / email display in office menu? I also coded the tyre pressure display, but I doesn't seem to work on a f20. The display is exactly the same as before. Only green wheels are shown on the graphic, but no data. What is the ring tone setting about in cmb media? I can choose between 3 ring tones. How do they sound? Does any body have mp3 files of them before I cange the setting? Last edited by pixelfreak0410; 02-03-2013 at 11:19 AM.. |
02-03-2013, 11:29 AM | #2476 | |
Rep 41,033
For TPMS, I assume you at least have the dashes now appearing. You need to reset the TPMS System from iDrive, and then drive it a couple miles before the Pressure and Temp values appear.
02-03-2013, 12:48 PM | #2477 |
Rep 51
Ok, I had to re-pair my phone to activate audio streaming. works fine now But my old galaxy is not capable of sending title information while streaming ... I think this will work with a newer phone.
The latest IOS6 should support MAP? I think I will try to pair an iphone 5 to see if the sms and email options will work on office menu. currently there are only contacts listed. What will happen when I flash the latest bluetooth update from bmw.com/bluetooth ? Do I have to code some FDL again? |
02-03-2013, 03:51 PM | #2478 | |
Rep 30
I am still not convinced that the software builds of CIC differ from Asian countries to the EU/US ones. I reckon the price difference should be down to software licensing and/or country specific tax etc. It would be mind-numbingly stupid if BMW actually release 2 branches of CIC builds JUST because of the locale. I am doubting Aupeo! knows this problem and deliberately tweak the encoding of those characters to make them display correctly on the CIC - so my guess is for our EU/US spec CIC the system uses ANSI or ISO as character encoding rather than utf8. but further tests are needed to verify these theories. I am getting frustrating about this as it is deemed to be a very very basic functionality and since in the NBT it does support CJK, BMW certainly has realised that the necessity of this. Finally @kon, you mentioned about removing country controller in FA and set the country flag to Hongkong sometime ago. Could you please kindly shed some light about how this could be done? After you have performed this what happened? Many thanks. |
02-03-2013, 03:55 PM | #2479 |
Rep 68
Drives: 2013 F30 328i
Hi guys.
Can anybody help me with steps or url to a DIY for coding the head unit from 6 speaker base sound to hifi sound? Will this give me balanced line level outputs? |
02-03-2013, 06:06 PM | #2481 | |
Rep 3,780
It would be amazing if someone could do a write up of a step by step of how to activate once the fsc code has been purchased.
02-03-2013, 06:38 PM | #2482 | |
Rep 84
02-03-2013, 07:13 PM | #2484 | |
Rep 490
02-03-2013, 07:14 PM | #2485 | |
Rep 490
02-03-2013, 07:16 PM | #2486 | |
Rep 490
Message menu in Office will only appear if you pair a compatible phone (with MAP support), you might want to check if your phone MAP options is activated. Tyre pressure, do you have option 2VB? If not, it will never appear as your vehicle lack the sensor & receiver to actually show you anything. You can check 2VB in your VO list or physically check your tyre stem valve whether it's metal or rubber, if rubber means no 2VB. |
