06-19-2018, 12:21 PM | #45 | |||
Rep 4,724
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
06-19-2018, 12:39 PM | #46 |
Rep 1,934
06-19-2018, 12:40 PM | #47 |
Rep 1,934
The differences are nothing a flash tune and coilovers wouldn't solve. Cheaper to do that than add to the loan amount in the long run
Blubaron791434.50 |
06-19-2018, 05:13 PM | #48 | |
Rep 1,934
kern4174449.50 |
06-19-2018, 05:27 PM | #49 |
Rep 1,597
06-20-2018, 07:30 AM | #50 | |
Cheapskate
4450
Rep 4,993
First of all, we're comparing to a 335i. They put down what, 250awhp? The audi is closer to 300, stock. And I'm not sure why people on here keep saying its numbers are bloated? VW/Audi do the same game with HP numbers that BMW does. Secondly, we're talking about a road course. there's nothing overrated about it. The car has 30mm more tire on both front wheels, stronger push from the rear, and doesn't lose camber like our mcpherson struts when entering a turn. You're delusional if you don't think the audi takes it stock vs stock. |
Vinboyblue165.00 |
06-20-2018, 07:54 AM | #51 | |
Rep 1,290
First off, both cars are available in a myriad of different configurations. Stock vs stock isn't enough to necessarily make it fair. Instead it should be each car in the most performance spec'd format possible from the factory. This would be each with the best oem tires, brakes, suspension, rear diff etc. At that point, despite differences in chassis, weight distribution, and power, it's probably a close enough match that driver skill is going to determine who wins on a track. It probably also depends on the track. A track that has a lot of straight aways is going to, theoretically, allow the s4 to pull away due to having slightly greater power and torque relative to weight. A track that has many twists and turns might favor the 340i. Then again some might say Audi's optional differential is better and helps it narrow the presumed advantage in handling held by the better balanced bmw. At the end of the day, I think they're both great cars with performance capabilities in a practical daily driver package. |
06-20-2018, 09:34 AM | #52 | |
Cheapskate
4450
Rep 4,993
Even a 335i with msport/track pack only has a 225 tire up front. That's embarassingly thin for such a large car. And the fact that our cars aren't even offered with a factory-optioned LSD, RWD or X-drive, lends to the idea that these cars just aren't given the same performance oriented treatment that Audi gives their S-models. |
06-20-2018, 11:43 AM | #53 | ||
Rep 4,724
06-20-2018, 12:18 PM | #54 |
Cheapskate
4450
Rep 4,993
In the front? Our cars come with either 225/255 or 225 square.
06-20-2018, 01:13 PM | #56 |
Rep 400
The main difference maker in the two car in my opinion was the LSD in the audi. It feels way more planted in corners, and it feels a tad bit faster, other that than I think the BMW is better, especially in the looks department
06-20-2018, 01:47 PM | #57 |
Rep 1,358
Drives: 981CS/428/is250/JLU Rubicon
Funny how the OP writes a simi-flame bait post then vanishes
i used to lust over the A5, until I saw a black 435 m-sport hop on the freeway one evening as the sun was going down...... I knew right then what my next car would be....no regrets! |
06-20-2018, 02:50 PM | #58 | |
Cheapskate
4450
Rep 4,993
I've only had volkswagens up until this point and when youre used to being traction limited (fwd), awd seems like everything. But I'm very happy with RWD and gladly said to VW/Audi. But if I had to have awd, didn't care about driving an 8speed, and didn't mind spending an extra $10k, I'd be in an S5. |
06-20-2018, 05:25 PM | #59 |
Rep 351
what i take issue with is that you think the s4 sounds better. what?
s4 being slightly faster, i much prefer the way the 335 drives, how it feels inside, how i fit in the seat, how the idrive interface works over the audi system, and how it sounds. i also think the bmw has a more complex look to it. the s4 is clean, but it's lines are boring.
2013 335i M-Sport 6MT, MPE, VRSF CP and IC, BM3 Stage 1
2006 330i 6MT, Sport Package - sold |
06-21-2018, 02:41 PM | #60 | |
Rep 1,597
06-21-2018, 08:12 PM | #61 | ||
Rep 1,290
At least with the f30, if you don't choose the right combination of option packages, it won't feel particularly sporty to drive. I made this mistake when I initially bought my f30 335i. I just figured a 3 series is a 3 series, how can you go wrong. I thought every 3er came from the factory with a certain level of inherent performance and driving satisfaction built in. I thought that sport trims and packages were for those who enjoy a very stiff suspension and the cosmetic bits that come with it. I was kind of disappointed the more I got accustomed to my base 335i. It's not that it was a bad car. It was actually nice, but it wasn't much like the vaunted 3 series I'd always heard about in car-guy circles. Instead the f30 tries to offer something for everyone. It can be like a glorified Camry (but 2x the cost, and not as reliable) in base form, or it can at least approximate a modern 3 series experience if optioned for performance. I do like the fact that bmw is positioning the 340i as a more focused performance model in the upcoming g20 generation. Yes, I intentionally left out the "M" designation (not in reference to your post kern). I don't do this in protest to how bmw decides to use its branding, but to avoid the confusion and can of worms that inevitably gets opened upon mentioning the letter M in bmw enthusiast forums. I fully understand the marketing efforts behind such naming.... I'll add, however, that we can't really discuss which models compete with which others without delving into marketing strategies, to some degree. |
kern4174449.50 |
06-21-2018, 08:33 PM | #62 | |
Rep 14,115
Drives: G82 M4C X-Drive
The F30 simply had a "base" version available to reach the most number of customers. The G20 will get rid of that "base" 340i. What remains to be seen is the M Division's involvement with the M340i. Is it merely a collection of parts from the M Division bin (much like the current M Performance accessories), or a more hands-on approach? Interestingly, Audi has already blurred the lines a long time ago with the S car variants. They have their own high performance division called "Audi Sport GmbH" which produces the RS cars along with the R8 and only one A4: The european DTM edition and one S4: the 25quattro (which I had). They produce "S Line" parts and accessories much like the M Division makes M Performance accessories.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
06-21-2018, 09:58 PM | #63 |
Rep 377
When I was buying the 435 about 4 years ago, I considered an S4/S5 as well. I got the opportunity to take an exec demo S4 out for a test drive without the sales guy in it and really got to give it beans. Even though the S4 was a hoot to drive, it didn't drive the way I wanted my daily driver to be. There wasn't enough of a dual Jekyll and Hyde nature to the car that I found instantly in the 435. Long story short, these days I only visit Audi dealerships to reaffirm my decision to purchase other brands lol. Nothing wrong with Audis, they're just not my cup of tea.
06-22-2018, 02:18 AM | #64 | ||
Rep 1,290
I realize that the g20 won't really be offering anything new that can't be had on a current f30, as spec'd for performance. The g20 will however make it less likely that someone like me will ignorantly order the grandmother's 340i instead of the sport sedan I thought I was getting. In my mind, Audi has always marketed the S-cars as being somewhat more focused on being sport sedans. Whether they succeeded is the subject of another debate. If the g20, and upcoming m3/4 are disappointing, I suppose there's always the Stinger |
06-22-2018, 03:31 AM | #66 | |||
Rep 14,115
JamesWWIII2932.00 |
