BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Those with automatics, try this...
      12-07-2012, 01:19 AM   #1
x.shell
x.shell's Avatar
6579
Drives: ▋ ▉▉
So when I start up my car in the morning, I always put it in manual mode (move the stick over to the left). I don't warm it up. I just let it idle forward out of my parking space... maybe a little bit of gas. But then, at about 2.5k RPM, the car shifts to 2nd gear. It's in fully manual mode but it automatically does this. This only seems to happen in the morning on cold starts.
Has anyone else experienced this?
I read somewhere that the Automatics in the F30 "learns" your patterns and applies it to the driving. Could it be that it's shifting for me in manual mode?
I also know that the car will shift for you when you red line it... even in fully manual mode. Obviously, it's to protect the engine. But could it be that it's protecting the cold engine from revving too high?
      12-07-2012, 01:27 AM   #2
Monkeycmonkeydo
Monkeycmonkeydo's Avatar
Drives: 2013 335i sedan
To the left is actually sport automatic if the car shows s1 on your dash. Until you paddle shift or push lever down the car will shift for you but in a more aggressive sport model.
      12-07-2012, 01:36 AM   #3
KyleBerg
Drives: F30 335i M-Performance
Just moving the stick to the left doesn't put your auto tranny into manual mode; for this, you need to initiate a gear change first.
      12-07-2012, 02:07 AM   #4
x.shell
x.shell's Avatar
6579
Drives: ▋ ▉▉
It all makes sense now! Thank you guys. I always wondered what S1 vs M1 meant.
      12-07-2012, 06:20 AM   #5
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
2014 BMW 335 Xi  [10.00]
i read that it should adjust to your driving pattern, it might be doing it not to rev up the engine when the oil is still cold
2014 F30 335 X-Drive | 6-MT | Alpine White/Coral Red | ZMM ZDH ZDA |
      12-07-2012, 08:50 AM   #6
The X Men
Drives: 2013 X3 35i
Its probably not a good idea to put the car in sport mode before it is warmed up, you want to keep the rpm low.
      12-07-2012, 08:02 PM   #7
RPM90
Drives: 340i M-sport AT
Yes, when the engine is cold, keep rpm's low until the engine and oil warm up.
I always use "sport" mode, I engage it as soon as I start my engine.
BUT, with DH pkg I have sport mode set up so that I have the firmer sport steering along with firmer sport suspension, but my trans is in "comfort" mode. I didn't know about those added options with the M adaptive and VSS options. BMW did a poor job of explaining it. But I'm glad I have it as I use the optional added settings all the time.
      12-08-2012, 03:28 AM   #8
pkimM3r
pkimM3r's Avatar
205
LOL. Why is it shifting?
      12-08-2012, 08:58 AM   #9
4DRS55
Drives: GTF80,718GT4,TVG80,G05X5
I would let it warm up a bit before using manual mode.
      12-08-2012, 10:14 AM   #10
rallybull
rallybull's Avatar
Drives: F30 335i w/PPK
I have started using the manual mode when the car is cold and keep the rpms between 2200 to 2800 rpm for the first few minutes. I have noticed the car warms up much quicker that way and I don't have to literally wait 10 minutes to start going WOT.
