10-30-2012, 08:02 PM | #618 |
Rep 843
LOL. Well, speaking of arrivals, I pick up mine tomorrow. 335i, MSPORT, xDrive, 19" (Bridgestone S001's), Sport AT. Does NOT have the DHP so should be a prime candidate. Will try the 40-60mph tests and post again tomorrow night.
10-30-2012, 08:07 PM | #619 |
Too much is never enough
655
Rep 3,079
I wish! I'm just an enthusiast (apparently in the minority around here) who loves the marque.
I'm also just a very skeptical person who tends to step back and look at the bigger picture before subscribing to a concept or drawing my own conclusions. Understand this is how most engineers are programmed. Internet forums are a very poor indicator of reality unfortunately. There's often a tendency to be drawn into the "me too" fray. I'm not saying definitively that this is not a problem. But so many times people read about a "problem" and are then driven to determine if they are also plagued with the same problem. More often than should be the case, they report back that they do indeed have said problem. All the while everyone fails to realize that they're confirming they have a problem they didn't realize they had until they read others had the problem. Again, I'm not trying to say without a doubt that there isn't a problem. I'm just begging that sound reasoning be used to logically outline the exact circumstances surrounding the issue when it occurs. Incessently posting new threads and polls isn't going to solve anything. It only feeds the hype. All I ask is that everyone follow the advice of the great Flavor Flav when perusing the internet... "Don't believe the hype!" |
10-30-2012, 08:09 PM | #620 |
Rep 4,553
Be sure not to let go of the steering wheel or hold it lightly or you may feel the wrath of the "engineer".
10-30-2012, 08:22 PM | #621 | |
655
Rep 3,079
We're all here for the same reason (I think) - we all own and love BMWs. Let's not get carried away. Have a problem? Go to the dealer. Unable to get satisfaction from the dealer? Come to the forums to see if your experience is unique. If not, initiate a constructive dialogue and share experiences. I know it's the season, but witch hunts don't help anyone in the end. |
10-30-2012, 08:26 PM | #622 | |
Rep 4,553
I spoke with CA's at 4 local dealers and mentioned to all about the F30 steering vibration. All four said they knew about it, but that it wasn't really a problem. Salesmanship. Then I called Shop Foreman I know at 2 dealers and asked them. Both said they have had cars in for the issue. They have yet to find a fix, bmw has sent engineers to look at the cars (ones that exhibited the problems worse than average) and BMW says they are working on a fix. To date, the steering rack on the F30 has been revisioned at least twice: http://www.realoem.com/bmw/showparts...71&hg=32&fg=12 The front axle support has been revisioned at least once: http://www.realoem.com/bmw/showparts...42&hg=31&fg=05 The lower joint steering assembly has been modified at least once: http://www.realoem.com/bmw/showparts...76&hg=32&fg=30 Are we dreaming here? Oh, several cars have been bought back by BMW. I must be dreaming now... Last edited by claykin; 10-30-2012 at 08:35 PM.. |
10-30-2012, 08:34 PM | #623 | |
Rep 4,553
I drove 2 x 2013 F30 328i models and BOTH exhibited steering wobble. Vibration was barely noticeable while holding wheel but was easily noticeable when holding lightly (since I'll avoid the "letting go" advice you seem to laud). I more recently drove a September build 335i MSport (without DHP). Also exhibited minor vibration while between 40-60mph and was even more noticeable while holding wheel lightly. I have also driven 2 x Cadillac ATS that also has electric steering. NEITHER had any vibration or noticeable wobble while driving (although one of them essentially broke down during the test drive which limited my ability to test the first car). Its clear that BMW is working on something to address this issue. We can either place our tails between our legs and take their word for it, or keep pushing for a fix. The F30 has been in production for less than 12 months. Why in the world would they have already revisioned the steering rack 2x? |
10-30-2012, 08:37 PM | #624 |
Rep 843
Well, I'm going to try it just the way you have all said to... I'm picky as it is so if there is anything "off" I will notice. Like I said earlier in this thread, to me it really makes no sense.. people get balancing done and the problem goes away.. if there truly is an inherent issue with the steering mechanism, you can balance the tires/wheels all day long and it should not affect the core issue. A bad tire certainly could as one guy had posted too, but again, if steering mechanics were causing it, even fixing that bad tire should not have rectified the problem. I have new 18's with the winter tires on them and I will swap them out real soon... hope to get by for a few weeks at least on the 19's.. so if I do in fact have vibration, I'll see if that changes anything. Also, not having the DHP seems the be one common factor amongst those that have the issue, but I do not remember seeing any xDrive's in the mix.. of course with all these posts I honestly don't remember. Bottom line, up until a few weeks ago, the last thing I had on my mind was testing to see if this issue exists... something brought to the forefront by this forum. The excitement of taking delivery is of course paramount, but now this will be in the back of my mind. So we'll see!!
10-30-2012, 08:40 PM | #625 | |
655
Rep 3,079
I've already said I don't disagree that there might be/have been an issue with some cars. But I have a feeling it's not as prevalent as it's being reported here. And the concept of letting go of or "lightly holding" the wheel in a car with no discernable vibration to "see" if there's a vibration present is just plain illogical. |
10-30-2012, 08:40 PM | #626 | |
Rep 4,553
10-30-2012, 08:43 PM | #627 | |
Rep 4,553
10-30-2012, 08:46 PM | #628 | |
655
Rep 3,079
This is the worst part. I'd say it's best to stay off forums until AFTER you take delivery so the whole experience isn't overshadowed with concerns! There's also a very definite chance it's a tire issue. Belts that aren't laid/aligned properly can cause vibrations, pulling and numerous other issues. Fingers crossed your car is PERFECT! Enjoy it! |
10-30-2012, 08:48 PM | #629 | |
Rep 4,553
And you think they did that to appease us? Last edited by claykin; 10-30-2012 at 09:07 PM.. |
10-30-2012, 09:00 PM | #630 |
Zooombie attaaack!!
136
Rep 1,179
I had my car for only a couple days before getting my new wheels so I kind of noticed this but it wasn't too bad. I'm glad to hear it's a common problem because I have been noticing it with my new wheels! It's not annoying or anything, but I was concerned that the different wheels caused the problem.
10-30-2012, 09:36 PM | #631 |
Rep 537
Drives: 2013 335i M
I may start a thread........"The seat warmer is too hot" Keep your hands on the wheel!!!!!!
M5 with lots of goodies
10-30-2012, 09:37 PM | #632 |
Rep 4,553
10-30-2012, 09:46 PM | #633 |
Rep 537
Drives: 2013 335i M
Or turn the wipers down to reduce the STUPIDITY AROUND ME!!!
10-30-2012, 09:58 PM | #634 |
Rep 4,553
I guess you should find new friends or at least not tell them how you feel.
Take it in stride. Its all good. Lets not bicker over this "shaky" situation. Last edited by claykin; 10-30-2012 at 10:07 PM.. |
10-30-2012, 10:16 PM | #635 |
Rep 537
Drives: 2013 335i M
HAHA...It is a little shaky around here!
10-30-2012, 10:21 PM | #636 |
Rep 4,553
Lets take a moment and pause for those in the NE (not far from you) and wish them well post Sandy. Its going to be a long and painful cleanup for some.
10-31-2012, 07:26 AM | #637 |
Rep 843
Ok guys, don't shoot the messenger here... I just copied this from another forum on the exact same topic so who knows!! But...a guy having the issue posted:
"FYI - the GM told me when he spoke to BMWNA that they have a "fix" and they will be shipping the parts to dealers to perform said fix. He told them that he didn't want to even discuss that fix with me since I've been put through so much trouble already." So, I guess we will see. When I pick up mine today I am going to ask the SM if he knows of this issue and if there is a "fix" in the works. |
10-31-2012, 07:52 AM | #638 |
Rep 5,803
i would love to know what this fix is. if its a software fix then i call bull shit.
F30 330i Alpine white/Coral red Msport 6MT
