11-28-2012, 09:06 AM | #1 |
Rep 24
Best offset for F30 front 19x8.5 & rear 19x9.5
Dear all,
My buddy has a F30 335i and he wants to know what's the best offset for the above said wheel size. He wants the wheel to line up perfectly with the fenders without rubbing. He is gonna lower his car with KW V2 as well. Maybe 2.5' to 3' drop. It will be great if you can post some pictures of yours. Thanks!! |
11-28-2012, 11:21 AM | #2 |
Rep 1,846
I have seen alot do ET 35 front and ET 38 in rear. Challenge has et 40 in rear and looks very good. I am about to try et 32 front and et 32 rear. Wish me luck!
2018 M3 Imola Red Competition package/Executive package/M Performance suspension
11-28-2012, 11:27 AM | #3 | |
Rep 24
What kind of wheels are you getting? Please post pictures once you have the wheels installed!! Good luck!! |
11-28-2012, 11:34 AM | #4 |
Rep 1,846
Wheels are BBS, they will go on car as soon i get time off work. I still need to take delivery of my car first. Pics for sure. Make sure your friend gets a quality wheel. Check out Alufelgen they are et 35 front and back and are offering sponsorships.
11-28-2012, 11:37 AM | #5 | |
Rep 266
11-28-2012, 12:05 PM | #6 | |
Rep 802
235/40R/19 = 1.22%+ Diameter vs. Stock 265/35R/19 = 1.07%+ Diameter vs. Stock Your setup: 235/35/19 = 2.34%+ Diameter vs. Stock 265/30/19 = 2.96%- Diameter vs. Stock
11-28-2012, 12:13 PM | #7 | |
Rep 478
11-28-2012, 12:49 PM | #8 | |
Rep 266
11-28-2012, 01:41 PM | #9 |
5 Star General
120
Rep 2,631
11-28-2012, 01:54 PM | #10 |
Rep 266
11-28-2012, 03:34 PM | #11 |
Rep 497
All about the drop and the tire you're getting.
Will you be dropping the car? an inch? 2 inches? What tires are you set on? For example, you can get a +22 offset rim and put 215 tires or get a +35 and get a 235 or 245 tire |
11-28-2012, 03:37 PM | #12 | |
Rep 802
Sometimes ... its not JUST about asthetics. You can accomplish your asthetic preference by doing a little math.
12-19-2012, 01:36 AM | #15 |
Rep 1,846
I just installed 19x9.5 et32 in rear with 265/30/19 Michelin PSS. No rubbing now but worried about drop. How do you guys think I can make this work? Or am I worried too much and the drop will fix how the rear tire sticks out?
12-19-2012, 11:18 AM | #16 | |
Rep 497
BTW, OEM 19"s are 35/30 sidewall
F85 (17) - DG/AB
F87 6MT (20) - Comp - BSM F80 DCT (18) - Comp - AW F30 6MT 335i - EBII |
12-28-2012, 10:36 PM | #18 |
Usofstance
78
Rep 671
no u cant rock 35 offset in the front you will rub the coil over!!!!! i learned the hard way
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance United States Of Stance |
12-28-2012, 10:40 PM | #19 |
Rep 941
If you drop it will camber in a bit, but personally i think you will still rub on hard cornering . PSS have really square sidewalls. I've had 265s in other brands that were less beefy than 255 Michelin PSS. 255 is as wide as I'd go at et32.
2015 F15 X5 25d Space Gray | Pure Excellence | Dakota Leather/Brushed Aluminium | Anthracite Head Liner | Fender Flares | Connected Drive + Real Time Traffic
2012 F30 335i Sapphire Black 2006 E92 325i Titan Silver 2000 E46 318i Cosmos Black |
12-29-2012, 12:36 AM | #20 |
Rep 1,846
Thanks guys, for now, I like the wheels and like the comfort feel of stock. I do wish I had better stance and less body roll. Just got the car 2 weeks ago so gonna see if something comes out with 20mm to 25mm drop over the M sport. On side note, anybody ever ordered custom offsets from BBS?
01-20-2013, 12:56 PM | #21 | |
Rep 7,298
01-20-2013, 01:58 PM | #22 | |
Rep 556
Drives: 2012 BMW 335I
I ask because I am running 19 x 8.5 + 35 19 x 9.5 +45 @ OP, I have had no trouble with those offsets, and I have KW V2 with about the same drop as you are requesting.. |
