BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > F30 M Performance Suspension
      10-22-2012, 02:41 PM   #45
4DRS55
Drives: GTF80,718GT4,TVG80,G05X5
Originally Posted by bmrm396 View Post
if u know u want to upgrade ur suspension, as i do, id rather spend the extra couple hundred bucks to get the m perf than spend a grand on the adaptive and then later switch springs etc, etc.
In your case I agree to this
Way cheaper overall and go straight for the proper performance upgrade, i dont believe in just lowering a car for looks.
I do not agree who says that the springs will not improve performance; M per suspension is not coilovers just a spring shock set up. So performance should be similar.
And the m perf susp lowers the car an addition 10mm, just FYI for the comment u quoted above
same as the e90, thats only 0.393701 inches
Also i went through the springs ordeal w my dealer on my e90. we ended up not doin any upgrade cause it was not well received when i ran it through them about the lease return process etc
If I leased it I prob would not do too many aftermarket upgrades.
      10-22-2012, 03:22 PM   #46
UhhItsANT
Drives: 2013 BMW 335i
2013 BMW 335i  [0.00]
By any chance, will this set be adaptive? Since it said for no adaptive cars. After installing these will you get the adaptive settings in idrive?
      10-22-2012, 03:30 PM   #47
Jamesons Viggen
No.
'15 Buick Regal "T"(wife)
      10-22-2012, 04:50 PM   #48
nano10
nano10's Avatar
448
Drives: 2018 F80 M3
ya my dealer is still looking into it. Im kinda bummed cause this is pretty much holding me back from my order. I know it'll be well worth the wait, plus itll save me a few hundred bucks by not payin for aftermarket install but i just keep hearin "tick tick tick" in my head haha
I completely understand, i did the same thing with m performance brakes. no regrets, I just wish my car would get here already!
2018 M3 Imola Red Competition package/Executive package/M Performance suspension
      10-22-2012, 09:16 PM   #49
bmrm396
Drives: 2018 F80 M3cs
you are wrong here. look back at the info we have on the m perf susp. m performance is a complete kit, not just springs. It is also a fact that it lowers an additional 10mm over sport or msport susp.
Just want to give you all the proper info to make ur decision. Do some more research first so ur sure ur good with springs. (its widely known springs can inherently make performance of a car worse - this is debated, but def tru in my experience)
Formerly addicted to e90post
      10-22-2012, 09:17 PM   #50
bmrm396
M division is said to be looking into a system for the adaptive, but many believe it wont come to fruition due to cost structures
heres a good link with some Q&A on M Perf Parts http://www.f30post.com/forums/showthread.php?t=660900
      10-22-2012, 09:46 PM   #51
4DRS55
What i said SPRING / SHOCK set up. Please identify "complete kit" im pretty sure its a SPRING/ SHOCK set up and if a non sport u can upgrade to thicker sway bars that are on both m-sport and sport suspension.
10mm = .39inches doesnt seem much.
I have nothing against the m-per suspensipon i think its a great set up. If you have the sport or m sport suspension the car is already lower than the other lines so putting H&R sport springs which lower the car .8in is not going to be too bad for the suspension and may work well with the set up as other members posted. I also am the paronoid type so i checked with the dealer and they said it will be fine. (if super sport then i beg to differ) If you have a nonsport line then i would def get the m per suspension because of the difference in height causing more wear and tear to the struts.
      10-22-2012, 10:00 PM   #52
PeterM
Drives: bmw 335i
Thanks for the info on the suspension
      10-22-2012, 10:01 PM   #53
nano10
nano10's Avatar
448
Drives: 2018 F80 M3
I spoke with the people at steve thomas BMW running the site posted earlier. They checked my VIN, yhis is proper kit and will not effect the the different driving modes (eco pro, comfort, sport) now i didnt get m adaptive suspension so that is why it probably is compatible with my vehicle
      10-22-2012, 11:27 PM   #54
bmrm396
to each their own ... let us know how the H&R's work out for ya and hopefully well get some more info on the m perf susp as well since there are currently no reviews out yet anyway. could be a bust, could be gold. hopefully someone can tell me before i buy it haha
      10-23-2012, 07:13 AM   #55
4DRS55
Def will, hopefully it works out good for both.
      10-24-2012, 07:14 PM   #56
nano10
nano10's Avatar
448
Drives: 2018 F80 M3
I will be ordering as soon as i find out from tisher if i can get a better price from them. If not i will go with steve thomas BMW and order. Should get installed as soon as i get car
      10-24-2012, 08:43 PM   #57
4DRS55
H&R sport springs
Got H&R sport springs installed at the dealer and the car looks amazing and rides great. It does not bounce and body roll is almost eliminated. Handling seems to be a big improvement while comfort is really close to stock; its prob about 15-20% stiffer and really noticeable around turns. You really can feel the tires work much more. Can’t wait for the BBS CH’s to arrive with wider 235's in the front and 265 in the rear.
      10-29-2012, 03:35 PM   #58
scott@bmwhn
Drives: Msport X3
Regarding vehicles equipped with M-adaptive, The kit may be offered but it will require coding out the EDC function (i.e. EDC deletion)
03' 525iT stick, 22' 530i
Previous: 20' X3 M40i, 19' 740i Msport, 17' 430i GC, 15' Msport X3 28i, 15' Sportline X1 28i, 13' Msport 328i, 09' Msport 335i, 07' Msport 335i
      10-29-2012, 06:42 PM   #59
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
any final pricing?
SOLD: 2012 335i Mineral Gray
      10-30-2012, 01:05 PM   #60
Gymkhana
Gymkhana's Avatar
Russian Federation
Drives: M3 E46
The question is - whether ill be able to install M-Performance suspension (stiffer lets say) on a car with xDrive and M-adaptive option or not.
I dont care i lose its adaptive features, for sure,in fact it will make car more stable and harder ride.
M3 E46
Best and the sharpest yet
      10-31-2012, 10:10 AM   #61
shivaswrath
Drives: 2012 335i
$1089 at Steve Thomas is a damn good deal, I'm asking my dealer to see what can be done...they claimed to have it available, in stock. I'm highly incredulous.
      10-31-2012, 10:47 AM   #62
scott@bmwhn
Drives: Msport X3
alright some more info I've come across
-NOT available for Xdrive
-CAN be installed on M-adaptive (EDC) equipped cars but requires coding the EDC function out.
-all kits DO NOT include the springs in the listed price and they are required
-Cars NOT equipped with a sports suspension REQUIRE replacment of the front & rear sway bars
Scott
      10-31-2012, 12:00 PM   #63
shivaswrath
Drives: 2012 335i
-Kits NOT equipped with a sports suspension REQUIRE replacment of the front & rear sway bars
Scott
Well for those of us with a base model, this became financially foolish...the Dinan Stage 1's (not out yet, but assuming similar model/pricing as before) are $1500 and include springs/struts and don't require revised ARB's.
That's for clarification...I guess this is why my dealership hasn't gotten back to me yet!
      11-01-2012, 03:13 PM   #64
nano10
nano10's Avatar
448
Drives: 2018 F80 M3
Spoke with evan at tischer, he said same thing. Springs needed for install not available yet. Because springs are not out yet he did not have a clear idea on the price for full kit for F30 with sport suspension.
