03-09-2017, 04:19 PM | #1 |
Rep 5
Valve Cover gasket replacement DIY
I need some assistance, I have a 2012 335i F30, I've seen a few things on here for the E90 but nothing for the F30. For the N55 engine is there much difference in the engine design. I need a DIY for mine, damn if I'm paying a dealer 1500 to do this, doesn't seem that it would be that complicated. Any help would be appreciated.
03-09-2017, 07:02 PM | #2 |
Rep 2,387
You Tube is your friend.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
03-10-2017, 03:15 PM | #5 |
Rep 233
It should be very similar to the below link:
http://www.e90post.com/forums/showthread.php?t=1197637 While the E90 N55 and F30 N55 are different, I would not think there would be anything significant to worry about between the two with a valve cover replacement. I don't think an N54 guide would work as there are several significant differences (re-designed PVC system, different injectors, added Valvetronic, etc). While it appears much more involved than I expected for a valve cover (mostly due to direct injection), nothing about the job looks too difficult for a novice amateur mechanic.
03-10-2017, 08:49 PM | #6 |
Rep 5
I'm going by what the dealer said, just had the fuel pump done for a recall, they told me oil filter housing gasket and valve cover gasket have leaks, I can see where the OFH has a leak, that problem has been taken care of, not a tough task but that bolt on the bottom is a the hardest part.
03-10-2017, 08:52 PM | #7 |
Rep 5
Thanks for the link, I'll dig into it, the only thing that seems like a pain is just taking all the fuel lines and fuel rail off, and I know there's a few plastic pieces to be aware of when taking off as to not break them, thinking it'll take around 3-4 hours at most. Will keep you informed.
03-14-2017, 09:52 AM | #8 |
Rep 327
If you go to a trusted independent shop you can have it done for a lot less. Another alternative would be to go to REALOEM website and see how everything fits together.
03-14-2017, 01:03 PM | #10 |
Rep 3,947
01-06-2018, 12:11 PM | #12 |
Rep 2,387
https://www.newtis.info/. All you need to know.
01-06-2018, 12:33 PM | #13 | |
Head Fry Cook at McBurgertown
507
Rep 1,005
Thank You!
I've been looking for this for quite some time. |
01-06-2018, 12:36 PM | #14 |
Rep 7,484
Just make sure you order fresh bolts for any that have a blue marking on them. Torque them correctly. I think the correct torque is listed on the new tis link posted above.
Nice opportunity to get in there and wallnut blast while you are at it! |
