BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > IHKA coding evaporator pressure
Studio RSR
      07-10-2023, 04:16 AM   #1
panlat
Drives: BMW 430d GC
Hi All, in my 430d GC I have the issue of the AC evaporator freezing over, as detailed in TSB SI-B64-06-13
I have a ISTA and ESYS setup, and have used ISTA for diagnostics and ESYS for coding. Have not used ISTA-P yet.
Can i perform the action of “Activate conversion to raise the minimum evaporator temperature” myself, using ISTA-P or ESYS? How would I do that? can it be done without updating the entire car, since I don't have a power supply to do long coding actions?
Edit: excuse the title of the topic, should say "temperature"
      07-10-2023, 07:28 AM   #2
TheNine90
Drives: bmw
Its possible to use ISTA or esys. For ISTA you would likely have to update the car. For esys just add TEMP to ho-wort and vo code
      07-10-2023, 01:34 PM   #3
panlat
Drives: BMW 430d GC
OK thanks for the reply!
first time I used a HO-Wort.
I have added the HO-wort "TEMP" to the FA list, written FA to car and then coded IHKA3. anything else? can I somehow check if the coding was done right? My next long drive is thursday, then I will find if it fixed the issue.
      07-10-2023, 02:38 PM   #4
TheNine90
Drives: bmw
check coding file
IHKA_VA01 > Funktionskodierung_HO 3002 > ANHEBUNG_TEMP_VD_MIN = TEMP 2
      04-26-2024, 07:55 AM   #5
galahadbry
galahadbry's Avatar
Drives: BMW F30
Originally Posted by TheNine90 View Post
check coding file
hi there, i just got this issue my evap is freezing after 5-10mins drive. i saw this post and i tried to code my car as written above (mine was offset_plus_2k) it works fine until 8 days later. my evap is freezing again.
so i tried to code it differently, i set the ANHEBUNG_TEMP_VD_MIN to offset_plus_3k. bcs i think it would prevent the freezing. is it okay?
also i set TEMPERATURE_OFFSET to Offset_plus_3k
i wonder if it would messed up the car 🙄
thanks!
