BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 2014 initial reviews????
Studio RSR
      08-01-2013, 09:23 PM   #23
ejholt
Drives: SRT Viper / M3 / X6M / Raptor
Originally Posted by PabloK View Post
I some of you lucky guys are picking up your 2014s today or tomorrow...
And quick reviews on the nav, Launch control, sail mode, m sport brakes?
I get mind Friday or Saturday and I need this to hold me over!!!
Mine came in beginning of the week. Haven't seen it yet as I dropped of my 2013 to begin the process of transferring accessories to my 2014 M-Sport. Heading down on Monday to drop off some new parts to have them install, prior to the actual delivery. Will post pics once I get to see it.
      08-01-2013, 10:24 PM   #24
EvenKeel
Drives: Sedan
Just got the car on Wednesday and therefore have a lot to learn.
I believe the "sail" mode is limited to EcoPro. The reason I say this is because under the EcoPro options on I-Drive, one of the choices you can check or uncheck is "Coast". I assume this likely has to do with the Sail mode.
      08-01-2013, 10:32 PM   #25
Atombyte
Atombyte's Avatar
Drives: 2013 M3, 2016 535i, 2019 540i
2019 540i  [0.00]
2016 535i  [0.00]
2013 M3  [0.00]
Originally Posted by n55x3 View Post
I agree with pablok, sail mode does not turn off the engine while coasting based on what I have read. It does decouple the motor from the torque converter so there is no parasitic loss or drag when coasting. You are essentially free wheeling when coasting.
Agree with OP, will be interesting to hear how this works in the real world.
If that's what happens, I would think it would burn more gas. I know that if I lift the throttle in gear and let it coast, fuel is cut off, but being in gear keeps the engine running. However, if I go to neutral (or just mash the clutch), the engine has to burn gas to keep running at idle speed. Maybe I'm missing something?
      08-02-2013, 12:19 AM   #26
nop
Drives: 2015 335i
An engine with no load on it (i.e. in neutral) takes very little gasoline to keep turning. On the other hand, when you're coasting at highway speeds the engine puts a load on the car causing it to slow down, so even though the injectors are off temporarily you will need to step on the gas sooner to maintain your velocity. On the whole, decoupling the engine when coasting can be a net win in gas efficiency.
      08-02-2013, 05:56 AM   #27
ZheHbKa
ZheHbKa's Avatar
Drives: the Wind
2014 BMW 335 Xi  [10.00]
Originally Posted by Stillhart View Post
That sounds way better than AS/S, assuming it works. The sport tranny shifts super fast so I can't see the delay being all that noticeable.
i'm sure its very sensitive and nothing to worry about, but as any new feature it will have its fans and haters
2014 F30 335 X-Drive | 6-MT | Alpine White/Coral Red | ZMM ZDH ZDA |
      08-03-2013, 09:52 PM   #28
bmrm396
Drives: 2018 F80 M3cs
anyone with comments on the steering? wondering how much of the "new" rack improvements they put into the f32 made it to the 2014 f30.
Formerly addicted to e46fanatics
Formerly addicted to e90post
