BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY - F30 OEM Backup / reversing camera retrofit installed!
      04-10-2015, 05:10 AM   #89
thelord-akira
Drives: F30 320d
Hi guys!
Is it possible to retrofit the rear cam (or maybe also top view) to a car with only navigation business (small screen) ?
best regards
eugen
      04-13-2015, 03:29 PM   #90
tjlees
England
349
Drives: F30 Chav Mobile
Originally Posted by thelord-akira View Post
Hi guys!
best regards
eugen
The configurator allows you to do it so I would say yes
For the topview you need folding/dimming mirrors
      04-14-2015, 02:34 AM   #91
thelord-akira
Drives: F30 320d
ok thx
      04-22-2015, 04:13 AM   #92
dazz100
New Zealand
Drives: BMW 325i E90 2008
Hello
I want to fit a reversing camera to my 2008 E90 that I purchased yesterday.
I have found this number for retrofit rear camera cable(s) 61122162971
but I don't know which model(s) this will fit.
      04-22-2015, 05:39 AM   #93
dazz100
New Zealand
Hello
Does anyone know anything about the Alpine hce-c500??
It's made for the X5 so perhaps it is a candidate for other BMW models.
Looks like it sells for GBP860 ($USD1300) so it's not the cheapest option.
      04-22-2015, 10:25 PM   #94
dazz100
New Zealand
HSD Cable --- Aftermarket???
Hello
I have been looking at the issue of sourcing a long HSD cable.
It appears to me that this is a standard cable. It should be possible to use any HSD cable. This includes the aftermarket versions that are a lot cheaper than the OEM versions. Extension cables are also sold.
There seems to be a number of different versions of HSD identified by colour and sex.
It would be very helpful if someone could provide photos of the cable ends. This would allow a suitable equivalent to be identified and avoid paying a fortune for a BMW part.
I am guessing that the other cable may also be standard but I don't know enough about it. Once again, detailed close up photos would be helpful.
Full data is here:
HSD Standard
An introduction to the standard, including connector variants are here: http://www.rosenberger.com/0_documen...col_Layout.pdf
      04-22-2015, 11:33 PM   #95
squidlyboy
squidlyboy's Avatar
Drives: 2014 Alpine White 328i M-Sport
Originally Posted by dazz100 View Post
Hello
Full data is here:
HSD Standard
hey... nice find!
I think you are the first to identify what kind of cable technology the HSD cable is... at least that's the first I've heard of it. I would think with the info you posted, we should be able to source the part somewhere? The long HSD cable has been hard to identify much less locate.
In any case post #43 and post #79 prob has as much details as you are going to get. Btw... I just got my camera in today (woohoo), and here is a pic of the connector side of it if it helps at all. The second pic is of an older camera I returned, but its got the TRSVC end of the HSD cable in the pic. Sorry for the crappy quality.. buts it all I got If you find a source, please let us know. I'm interested is possibly running my TRSVC module to the front of the car if possible, and the retrofit HSD cable I ordered is probably only going to allow me to run it into the trunk.
The other reason i'm interested in sourcing the part elsewhere is that it will be 2-3 months before I can get the cable in from my current supplier (and at BMW OEM costs $$$), but if I can find it elsewhere, I will be able to install my reverse cam much earlier!!!
Btw.. Welcome to the forums!!!
      05-18-2015, 11:21 AM   #96
gini
gini's Avatar
Drives: BMW e87 120d 03.2007
hi guys,
my little contribution
10 pins connector on TRSVC module:
9 132 577
HSD cable from camera to TRSVC module:
9 272 503 with length L= 1665MM
just for information to those who needs only the HSD end connectors:
1. HSD connector (TRSVC side):
6 982 244
2. HSD connector (Camera side):
9 182 930
      05-18-2015, 12:02 PM   #97
squidlyboy
squidlyboy's Avatar
Nice - that's most of what comes with the reversing camera cable retrofit kit, which costs me a little over $200.
Looking up those components (for what i could locate), it comes out to less than $60. The only thing missing is the rest of the wiring harness that contains the pins/connectors/terminators and single wires for the K-CAN/PWR/GND/... signals, which can't be more than $20 i'm guessing.
I'm curious how you located these parts (the HSD connectors don't show up anywhere that i could google). Also, do you know where you can source these parts from?
      05-18-2015, 12:50 PM   #98
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Originally Posted by gini View Post
hi guys,
ma little contribution
9 132 577
6 982 244
9 182 930
Gini,
Terrific!!
Am I to assume that each of these are preceded by the following: 61 11. For example the HSD cable is 61 11 9 272 503. Is that correct? When I checked in April 15 BMW ETK, that part is shown for 6 series
Appreciate your help!
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH|
Retired: 2014 328i
BMW CCA
      05-18-2015, 01:03 PM   #99
tjlees
England
349
hi guys,
9 132 577
6 982 244
9 182 930
Isn't the HSD cable for a F12?
http://www.realoem.com/bmw/enUS/partxref?q=9+272+503
but good find ... here is the retrofit camera kit etc:
http://www.realoem.com/bmw/enUS/show...81#66212361833
      05-18-2015, 11:17 PM   #100
squidlyboy
squidlyboy's Avatar
PSA - Reversing Camera + Camera Module - $300
Just an FYI, since we're talking about parts...
Just noticed that on Ebay:
Reversing Camera - $129
Camera Module - $169
Both are used, but both look to be in great condition (esp the camera module) and the price for this combo is about as good as its going to get. I would get them myself, but already picked both these parts up already (at slightly more $$$ )
The only thing you would be missing is the retrofit cable kit (~$200), the trunk handle mount (~$10-$20) and some misc electrical connectors, so you could do the whole reversing camera retrofit for around $500. Thats a great price!
      05-19-2015, 12:28 AM   #101
gini
gini's Avatar
Hi guys,
61 13 9 132 577 , price approx. 6€
I am not sure about the pins sizes, so I ordered both possible sizes:
61 13 1 383 776 (0.35 MM²), price approx. 0.8€ x 15
and
61 13 8 366 260 (0.75 MM²), price approx. 0.8€ x 15
I am planning to do this retrofit on my E87 this weekend. Since I already installed a COMBOX Media in the trunk, the TRSVC control unit will be installed on the same bracket
The TRSVC control unit needs the following wires:
- 2 wires for the Power supply (shared from the COMBOX) approx. L=20mm
- 2 wires for the CAN network (shared from the COMBOX) approx. L=20mm
- 3 wires for the FBAS signal (from the TRSVC to the CIC quadlock) approx. L=4000mm
I will use a shielded industrial cable which is available in my company, approx. 5€ for 5000mm
      05-19-2015, 12:58 AM   #102
gini
gini's Avatar
HSD cable (F12 series) from camera to TRSVC module:
61 11 9 272 503 ,length L= 1665MM, approx. 80€
I will install the camera on the rear bumper, just above the car identification plate like the F20 series OEM installation
The TRSVC control unit will be installed below the COMBOX Media, on the same bracket. So, a 1665mm HSD cable is long enough in my case
Prices summary:
- TRSVC and Camera, approx. 250€ (donor F20 series)
- HSD cable, approx. 80€
- 10 pins connector with pins and cable, approx. 60€
TOTAL: approx. 390€
      05-19-2015, 01:37 AM   #103
squidlyboy
squidlyboy's Avatar
where are you ordering all this stuff from?
      05-19-2015, 06:33 AM   #104
gini
gini's Avatar
I bought the TRSVC control unit and the camera from eBay.de
and the other small parts from my BMW dealer
      05-19-2015, 07:36 AM   #105
squidlyboy
squidlyboy's Avatar
And did you get this part from your BMW dealer as well? Do you know if they have an online ordering system?
Btw.. i just noticed you are doing this retrofit on an E87. You know this is an F30 forum right? I can't possibly think that this would be compatible... especially the software you are running in your car. You didn't mention which camera and TRSVC unit you are using...
      05-19-2015, 09:55 AM   #106
gini
gini's Avatar
Yes, I bought the HSD cable from my dealer with the small parts
They don't have an online shop as far as I know
TRSVC control unit:
66 53 9 350 995
Camera:
66 53 9 240 351
I have some basic knowledge on prog. and coding. I have developed for example this application which is largely shared on the web:
https://mega.co.nz/#F!VwJzgByC!K0krmp2Rfy86NetmhCIx6A
The description of this application is on another forum. I don't think I can post the link here
What do you mean with the software running in my car? It has nothing to do with that. I already tested the FBAS signal with an iPhone and I can watch a movie in playback on my CIC
So, the rear view camera will work on my car and in any car equipped with a CIC or a NBT since the TRSVC control unit is doing the job and just providing the CIC with a FBAS signal
I shared my information here since the main parts are common with the F30 series. If it's a problem, an administrator can maybe just delete my posts
Thank you for your constructive questions
      05-20-2015, 02:04 AM   #107
squidlyboy
squidlyboy's Avatar
Sorry.. i didn't mean to insinuate anything you are doing is wrong or question anything you are doing even in general - i'm actually very intrigued by what you are doing because quite frankly, its the first time i've heard of someone diving this deep where they are actually building the HSD cables from components and using a lot of the same parts we are using for our F30 for a different model. You go boy!
      06-20-2015, 01:12 PM   #108
steelerfan
steelerfan's Avatar
163
Drives: 2017 X5 Silver
Originally Posted by squidlyboy View Post
ista/d...
Hey Squidlyboy, i have been staring at this for the better part of 2 hours & i can't figure out where the control unit gets mounted. i removed the lower panel & the airbag & i just can't see where the heck this thing gets mounted.
Original poster, where did you mount the control unit?
      06-20-2015, 01:35 PM   #109
squidlyboy
squidlyboy's Avatar
I think you are planning to do it the right way (under dash drivers side). I'm planning to do the hack way and install it in my trunk near the battery. So i'm not sure where its supposed to go in the front.
The pic i posted from rheingold shows a pretty close-up shot, so its hard to get a perspective of where its actually at in the larger scheme of the front under-dash area. Sorry man...
      06-20-2015, 02:14 PM   #110
RSnic
RSnic's Avatar
SteelerFan,
While I am not the original poster, assuming you are referring to the camera control unit, TRSV ECU, take a look at the attached BMW retrofit instruction (EBA); you'll see that the TRSV ECU is mounted on driver's side near the left foot rest.
Look over the attached -- hope it helps
File Type: pdf BMW EBA 361831 Rear View Camera Retrofit Instructions.pdf (428.8 KB, 7967 views)
Al
Retired: 2014 328i
BMW CCA
