08-30-2016, 11:51 AM | #89 |
Rep 7,484
The throttle lag has not much to with the gearbox and much more to do with the DME.
A new software calibration was just released for this engine: SIB 24 02 12 Subject: N52T/N55 with 8HP45: Delay in Engine Response Model F25 with either N52T or N55 engines and 8HP45 transmission up to 1/16/2012 Situation When slowing down to lower suburban road speeds and then reaccelerating, a delay in engine response may be experienced Cause Unfavorable EGS and DME software calibration Correction Program the vehicle using ISTA/P 2.46.0 or higher |
stormlv932.00 |
08-30-2016, 12:58 PM | #90 | |
BMW forever!
1389
Rep 2,418
2020 BMW X5
2019 BMW M2C 2014 BMW 335i 2009 BMW 328i |
08-30-2016, 01:20 PM | #91 | ||
Rep 7,484
08-30-2016, 01:32 PM | #92 | |
BMW forever!
1389
Rep 2,418
2020 BMW X5
08-31-2016, 06:59 PM | #93 | |
Rep 1,592
09-02-2016, 01:46 PM | #94 |
Rep 234
Exactly!
09-13-2017, 04:06 PM | #95 |
Rep 10
I have this issue on my F30 328i M Sport N26 engine, both in Comfort and Sport. Does the SI B24 02 12 apply to the N26?
I also found this updated bulletin: "This Service Information bulletin replaces SI B24 02 12 dated March 2012." https://static.nhtsa.gov/odi/tsbs/20...52360-6188.pdf Still only refers to the N55. Anybody else with this experience on the N26 engine? Is the best solution still just to drive in Sport/+ mode? I'm considering a Dinan Sport Performance Tuner -- would it help? |
09-13-2017, 04:34 PM | #96 |
Rep 4,210
I have noticed the same lag with loaners. I don't have that lag with my 330e so I have attributed that to the lnstant torque of the electric motor (which, btw, replaces the torque converter).
09-14-2017, 12:08 AM | #97 |
Rep 86
I notice a slight lag too in my 340i automatic Iv only had sticks before so I thought this was normal behavior or the car slowly applying power so you don't just rip the tires (even in sport+) with all that power instantly coming on but I was not sure because my loaner 240i msport automatic had the same type of feel
Almost like the car thinks about it for a second then says "oh looking for this? Boom" |
09-14-2017, 04:00 PM | #98 |
Rep 477
I have a 2017 330i and I definitely notice delay in throttle response, but only when hitting the throttle when coasting or from a rolling start. The delay in throttle response is quite pronounced. I absolutely did not notice this behavior in my 2014 328i with N26 engine. Up until this time I had attributed the difference to the peak torque coming at higher RPM on the B46 vs. N26, but it seems from these posts that may not be the case.
Like another poster mentioned, I also feel that sport mode in the 2017 is less aggressive than the 2014. Not sure why BMW did that since they were definitely trying to make the "base" car more sporty by making sportline standard. Last edited by LMK5; 09-14-2017 at 04:50 PM.. |
10-01-2019, 11:49 AM | #100 |
Rep 477
Tough to tell if it's turbo lag or slow decision-making by the AT, but when I'm on the freeway coasting behind a slow driver and need to make a quick pass the delay can be downright dangerous. I have learned to just floor it to execute the fastest downshift possible. Two or 3 clicks of the "-" paddle shifter will also do it, then hold down the "+" paddle to get back into "D."
10-01-2019, 01:11 PM | #101 |
Monobloc
331
Rep 447
Drives: '02 M Coupe - '19 F31 330ix
Just installed the Racechip XLR (throttle/pedal tuner)a few days ago and have no regrets. 2019 F31 with the B46/B48 here.
-2023 Honda Odyssey Elite - Sonic Gray Pearl / Black
-2019 F31 330ix Individual - Champagne Quartz / Coral Red (M-sport, Exec, Premium, Track) -2004 Honda CRV AWD - Silver / Black -2002 S54 M Coupé - Steel Gray / Dark Gray/Black |
