02-11-2013, 04:55 PM | #23 |
Rep 4,323
less emission=better for air pollution.
that simple.
02-12-2013, 02:04 AM | #24 |
Rep 29
I figure if BMW is willing to code the car so people no longer have to press the button to actually turn the ASS off, then it must be a bad thing for the engine. If this was so good, I doubt BMW would be so willing to code it so easily, am I right?
02-12-2013, 02:31 AM | #25 | |
Rep 503
02-12-2013, 08:02 AM | #26 | |||
Rep 3,606
Where do you guys get this stuff? Exactly. A cold engine uses more fuel on start up. ASS is instant and saves fuel. Do you really think that virtually every manufacturer in th eworld would implement this system if it didnt save any fuel or caused alternator problems?? |
02-12-2013, 08:57 AM | #28 |
Rep 104
Well the alternator is what spin/starts the engine right? In my old car, i would start/stop the car once during a one way commute. With this car, it would start and stop anywhere in the 5-10 range for the same commute. I figured it will add more wear in the long run vs. a car without ASS. Again, i'm sure BMW already accounted for this because they have all kind of smart engineers working for them.
02-12-2013, 09:11 AM | #29 | |
Rep 74
-Ed
2013 F30 328i M Sport 2008 Lotus Exige S240 |
02-12-2013, 09:56 AM | #30 | |
Rep 3,606
02-12-2013, 11:33 AM | #31 |
Rep 3,331
"I've got an engineering degree from Internet U."
Auto Start Stop has been common in Europe for years. The reality if you ever encounter a traffic light then you are stopping for more than 4 (or whatever X seconds) is and that will conserve gas. Most lights in my area are 30 seconds -2 Minutes long. If you're inching forward in bumper to bumper traffic, then just turn it off. They allow you to code it to remember it off (it doesn't disable it permanently, simply remembers your last preference) because enough people complained and it was already in the software. Mechanically, it will increase wear on the starter, but they've mentioned somewhere that the starter is tested to 1 million start/stop cycles, so in reality lots of other parts will probably fail first. (for those of you math inclined, that's ~275 restarts per day, every day for 10 years). How many of you plan on keeping this car for more than 5 years? (I'm looking at you, former E9x owners...)
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
02-12-2013, 03:45 PM | #32 | |
Rep 503
02-12-2013, 03:56 PM | #33 |
Rep 3,606
Why would they do that? If one fails they have to replace the entire unit. Doesnt matter that he was confused/didnt know. Now he does. I've learned a lot here.....
02-13-2013, 04:42 AM | #34 | |
Rep 503
02-13-2013, 08:17 AM | #35 | |
Rep 3,606
02-13-2013, 01:48 PM | #36 | ||
Rep 305
02-13-2013, 01:50 PM | #37 |
Rep 6,248
02-13-2013, 01:58 PM | #38 |
Vroooooom!
Rep 206
Drives: F20 120d
I know a guy who manually shut down his engine while at speed to save fuel. He turned the key all the way so he turned off the ignition as well. The steering wheel locked, and as you can imagine, it did not end well. He wasn't hurt, but the car was fucked...
02-14-2013, 01:14 AM | #39 |
Rep 23
The using more gas to start an engine vs idle is only when you are talking about old carbureted motors. With the newer fuel injection and more so direct injection, the car only gives the exact amount of fuel needed to start, instead of dumping it in as a carburetor would...
02-14-2013, 04:45 PM | #40 |
Rep 606
Just bought a 2012 leftover with 0 miles yesterday. 335I sportline. Love it but not feeling the A.S.S. at all. After many questions and much research I found that the MPG savings is almost nothing. The system was designed to save the environment. While I am a fan of saving the environment. The system was just to annoying to me. The starter is not actually used at all but instead the spark plugs are re-fired upon taking off from a stop. My test ride was only about 15 miles so, I will play with it some more when I pick the car up next week. Seems like a good concept but needs tweaking.
02-15-2013, 09:13 AM | #41 | |
Rep 3,606
02-15-2013, 09:21 AM | #42 |
Rep 65
ASS shouldn't be available on a manual car. It is the weirdest thing when it shuts the engine off as the clutch is let out. IMO.
2013 335i M sport 6MT --Sapphire Black Metallic/Black Dakota, premium package, technology package, dynamic handling, black grilles, 5% tint--
02-15-2013, 12:09 PM | #43 |
Rep 1,285
02-16-2013, 12:23 AM | #44 |
Rep 148
The manual says 'may cause excessive wear to certain engine components'... which is reason # 587 why I have it default to "OFF"...
As far as fuel use, its direct injection so it doesnt use an excessive amount to start up the engine again... You do get used to it starting and stopping, but to me its just more annoying...
2012 328i F30/ Window Tint, M-Performance Kidney Grilles, Sport Front Trim Pieces with Whiskers, VMR V721s 19x8.5 F/19x9.5 R, (Coilovers Coming Soon!) |
