BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Washer fluid low warning on Cold Morning
      12-07-2012, 09:05 AM   #1
umbroumbro
Drives: 2013 F30 335i Xdrive
Every cold morning recently, if the outside temp below 37 then I got the temp warning light and followed by the washer fluid low warning light.
In the Noon and evening, when temp above 37, all system check OK. very annoying, I did top off the fluid using Rain-X and the car is only two weeks old. If there is leak, the warning light should always on, but it did not on all the time, only on cold morning.
Any one has similar problem ?
      12-07-2012, 11:47 AM   #2
Orient330iNYC
Drives: 2023 X7 40i
what does the light look like?
Present: 2023 G07 40i ZDH/ZDU/ZMP/ZMQ/2NH/ZPK/ZPP/ZRC/300/3AC
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Past: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC
      12-07-2012, 12:25 PM   #3
rjc32000
rjc32000's Avatar
Drives: 2014 335Xi M Sport 6MT
I have the same issue. I live in a cold climate (-4F this morning), and am getting the same warning message on a daily basis. I've topped my fluid off to the brim, but the warning light persists, although not all the time. I'll mention it to the dealer the next time I'm in for service, but would be interested to hear from others who have encountered this issue, any fixes, etc.
      12-07-2012, 12:35 PM   #4
jsedlak
jsedlak's Avatar
Drives: F30 335i 6spd
I got this... I topped off the fluid and it went away.
      12-07-2012, 12:35 PM   #5
Sprocket
Drives: BMW F31 328i
Same issue here + squealing brakes when cold. I had the car at the dealer for installation of the engine heater (+interior fan and battery charger) and mentioned these two things for them to investigate.
When I picked the car up they said they couldn't find a fault but had been in contact with BMW who said that these are known problems in cold weather and they are being investigated for a fix. No timetable available.
They're not big things but I am still quite annoyed. To top it off, the technician who installed the engine heater forgot to cut a tie strap (holding new cabling in place) so it's now pointed straight into the cooling fan making the car rattle like a cheap trabant.
Going back to the dealer again next week.
Not pleased. At all.
Melbourne Red F31 328 M sport
      12-07-2012, 01:16 PM   #6
marseille82
marseille82's Avatar
Drives: 2022 X3 M40i
Same issue here. And my washer fluid tank is full.
      12-07-2012, 03:11 PM   #7
umbroumbro
Glad to know I am not alone.....
      12-07-2012, 04:54 PM   #8
Hayir
Drives: 328i modern line
May be the fluid is freezing. Did you put the ones for -32F.
2013 328i
Modern line imperial blue/oyster, ZPP, ZCW, ZDH, ZLP, ZTP, Harman Kardon, park distance, High beam assist, Sundahes
      12-07-2012, 07:39 PM   #9
marseille82
Well I had the dealer fill mine so I suppose.
      12-07-2012, 07:43 PM   #10
umbroumbro
I fill it with the orange rainx,should be -32f,and the outside temp only 34f, even not that freezing yet
      12-07-2012, 07:56 PM   #11
Hayir
Thats weird. The weather here was 27-30F for several days and I didn`t get the warning. I keep it in the garage at night but during the day it sits on an open lot. No warnings at all.
2013 328i
      12-08-2012, 02:33 AM   #12
Sprocket
In my experience that is too warm. I only get the warnings when it's below -5C (23F).
      12-11-2012, 02:03 PM   #13
LupusLoco
Sweden
Drives: BMW 320dT F31 M-Sport
Under investigation
Hi,
I tried to find out via ETK what type of sensor/gauge BMW uses to measure fluid level (or at least fluid appearance) on F30/F31, but without any success.
I believe the common nominator seems to be that the failure occurs mainly during cold weather i.e. sub zero. I suspect it is a conductive sensor, but I'll eventually check it out at the workshop later on next week.
I have the Touring model (F31), and I've also experienced that the rear window nozzle doesn't spray any fluid when the low level warning light is lit. Not sure whether that applies at all times when warning appears, but I'll keep it under supervision.
I'm currently driving in cold snowy weather conditions so the warnings are frequent - and annoying...
      12-12-2012, 12:14 PM   #14
jsbmw87
Gear Head
Drives: 2016 M4
I've had this issue for the past month, even in weather around 55F and up. The car claims I need to put fluid in, but when I go to add fluid I can see fluid at the top of the reservoir. I'll keep you guys posted. Also having my service center check out the brake squeak that everyone else has mentioned.
2016 M4
      12-12-2012, 12:35 PM   #15
umbroumbro
thanks, looks like this bug is more common than I thought...
      12-12-2012, 01:05 PM   #16
Bold Vitalic
Drives: F30 320d
The same issue has almost every F30 owner in Russia according to a local bmw forum. I prefer to think positive - while the warning is on, headlights nozzles do not spray, thus saving fluid
      12-12-2012, 02:21 PM   #17
Sprocket
Same thing here. (Hej förresten! :-) ).
To top this off, I am suspecting that the headlight high pressure washers don't activate when the warning has been triggered. I haven't seen it spray mine in a couple of weeks.
I am giving BMW a pretty stern message on this, and I hope all of you do too. They need to fix this as it is both annoying and impacting the visibility when it's dark.
By the way, my father has an F30 328 and is using it in pretty much the same way as I am mine. He has not been getting the warning. I am considering trying to mix my washer fluid in exactly the same way as he does to see if it makes any difference....
      12-12-2012, 02:22 PM   #18
Sprocket
Sure, that's positive until you are on a dark and slushy winter road and the car refuses to spray your headlights. Then it's suddenly dangerous.
      12-13-2012, 11:18 AM   #19
jsbmw87
Gear Head
Drives: 2016 M4
My SA called and said since I wasn't using BMW approved fluid, that was my problem. Apparently RAIN-X doesn't work well with the sensors. I call BS.
2016 M4
      12-14-2012, 03:34 AM   #20
Vitoco
Infidel
Vitoco's Avatar
122
Never had the problem with mine guys (tjena!), while at work my car sits outside and we now got temps down to -20. I only use a pre-mixed fluid for -18 C (doesn´t freeze even though the outside temp is a bit lower). As someone mentioned above the sensor is most likely conductive, and I think the problem lies in the conductivity of the fluid; too high concentration of washer liquid or using deionized water to mix with it could probably be the contributing factors. Use normal "dirty" water if u mix yourself or buy a pre-mixed solution. Should work.
And about the rear washer not getting liquid when the warning has gone off, yes that seems to be the case every time so I think it´s meant to be that way.
      12-14-2012, 07:06 AM   #21
Sprocket
I used premixed I bought at Statoil at first. Then when the warning had gone off incorrectly I mixed in a bit more concentrated (thinking the premixed might have frozen since it was so darned cold). I'll try mixing myself using regular tap water + concentrated anti-freeze and see if it helps.
      12-14-2012, 07:24 AM   #22
marseille82
Huge BS. I got mine filled at the dealer and I'm experiencing the issue still.
