01-15-2013, 08:27 AM | #2025 | |
Rep 1,980
Drives: 2020 G20 320i M Sport
What exactly do I need to do to enable the use of the white iPhone cable? Was it just the line you edited under combox media? |
01-15-2013, 09:06 AM | #2026 |
Rep 1,544
01-15-2013, 09:06 AM | #2027 |
Rep 1,544
Ask dos1973.
01-15-2013, 10:55 AM | #2029 |
Rep 1,892
01-15-2013, 11:09 AM | #2030 |
Rep 15
i too can confirm that i was able to make the coding changes necessary to get rid of the y cable on my combox media, and enable bt streaming.
i tried the secondary method suggested by shawnsheridan (thanks!) and changed my vo order from 6nh to 6nk. follow the 3rd supplement guide at the beginning of the thread to do this. once i wrote the vo, then i went to the affected ecus (combox and hu_cic) and highlighted each one, and clicked code (not fdl code). the code changes were implemented automatically and the car now does bt streaming and music over regular usb! thanks for all the tips and help everyone. |
01-15-2013, 11:22 AM | #2031 | |
Rep 40,912
01-15-2013, 11:27 AM | #2032 |
Rep 40,912
If you have HU_CIC, and you have CMB_MEDIA in your SVT, you have a standalone Combox ECU. It is not necessary to check for its physical presence on the the car.
If you have the new HU_NBT, you will not see CMB_MEDIA in your SVT, as you do not have a standalone Combox ECU; however, you will have a Combox built into the HU_NBT Head Unit.
01-15-2013, 12:26 PM | #2033 | |
Rep 1,980
Thanks! |
01-15-2013, 12:42 PM | #2034 | |
Rep 40,912
He modified his VO by removing 6NH and replacing it with 6NK, and then he VO Coded HU_CIC, and it automatically handled all the required FDL Changes.
01-15-2013, 01:28 PM | #2035 | |
Rep 1,980
Seems like dos1973 was able to modify a parameter on his COMBOX MEDIA CAFD to get his iDrive to read his white iPhone cable. |
01-15-2013, 01:30 PM | #2036 |
Rep 1,544
01-15-2013, 01:43 PM | #2037 |
Rep 15
clarence, i think you're correct. i have nav but no assist, and i had a combox that supposedly required a y cable and only allowed bluetooth streaming of phone calls. changing the vo gave me all the additional functionality. except i'm not certain if i can get text messages to show up. i suspect i'd have to add 6nr and go through all that stuff to get it to work? coding the vo for 6nk did seem to add an 'office' menu, but so far all thats in there is my contacts, no messages or any apps.
01-15-2013, 01:43 PM | #2038 | |
Rep 171
Reason I want to check is there is an actual combox ncd file generated when I read my car. |
01-15-2013, 02:17 PM | #2039 | |
Rep 39
01-15-2013, 02:36 PM | #2040 | |
Rep 1,980
Thanks |
01-15-2013, 02:42 PM | #2041 | |
Rep 39
01-15-2013, 02:56 PM | #2042 | |
Rep 1,544
Bearing in mind that dos is from Germany, the info from members from other countries such as CDN & USA who also have 609+6NH means so far that this spec combination will have a castrated combox. |
01-15-2013, 03:14 PM | #2043 | |
Rep 40,912
http://www.f30post.com/forums/attach...3&d=1358466555 If you follow this complete, you will have written the modified VO to the car at the end. So, afterwards, you simply do this to VO Code the Head UNit: Connect => Read FA => Activate FA => Read VCM => Right-Click on HU_CIC (the ECU itself not the underlying CAFD) => Select CODE.
01-15-2013, 03:29 PM | #2044 | |
Rep 15
01-15-2013, 04:43 PM | #2045 |
Rep 84
I'm running into a few issues when trying to recode anything after the FEM recall with 48.3 and 3.18.4.
For example - FEM_BODY [40] cdDeploy ProcessedWithError cadf_000000794-004-124-042 Not Executable. I get the same thing in HU CIC I checked the post below that had a similar problem a few months back and found the SVT appears to looks fine. http://www.f30post.com/forums/showpo...12324765...357 I'm a bit stuck. I believe I'm on F020-12-11-505. One difference I noticed is that when I update the CAFD I don't get the little yellow dot next to the CAFD that I used to. |
01-15-2013, 04:46 PM | #2046 | |
Rep 40,912
Did you delete and replace your existing PSdZData folder with the 48.3 one, or did you copy it on top of your old one?
