07-20-2014, 01:39 AM | #1 |
Rep 1,976
Drives: 2020 G20 320i M Sport
F30 M Sport steering wheel retrofit
I just put down an offer for a brand new F30 M Sport steering wheel which includes the airbag and from my research, it retrofit is pretty much plug and play.
Does anyone know if I'll have any problems with compatibility or fitment on a North American spec'd F30? The steering wheel is coming from the UK and I'm not sure if left hand or right hand drive makes a difference. I checked the part number 32 30 7 848 338 and it seems like it is used in all markets including the US. Also, this steering wheel comes with the paddle shifters. Will it be easy to get these working?
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
07-20-2014, 09:25 AM | #2 |
Rep 987
Drives: 2022 X4 M Competition F98 LCI
You noted that you're ordering a wheel from the UK that comes with the airbag. There's a problem. The North American one has the airbag part number 32307845798 while the European one has part number 32307845797. Think it has to do with the Single and Dual Stage ones.
In terms of the paddle shifters, you need to order a new connecting line (wire) for the steering wheel and may also need to add an additional wire somewhere. Though some F30s may already be prewired. There's a thread on it. |
07-20-2014, 09:38 AM | #3 | |
Rep 1,976
I'm going to have to see if I can get the airbag somewhere else with that part number.
07-21-2014, 02:17 PM | #4 |
Rep 1,976
Just bought one that has the correct part numbers. Thanks Timbits!
Hopefully it'll arrive next week and I can see how it looks with my saddle brown interior.
07-30-2014, 09:36 AM | #5 |
Rep 1,976
Here it is !
07-30-2014, 09:39 PM | #6 |
Rep 11
How much did you end up paying for it? Wondering what it could go for. Thinking of selling mine when my car comes in and picking up the Carbon/Alcantara steering wheel.
07-30-2014, 10:55 PM | #7 |
Rep 1,976
It was $1500 USD shipped to Canada. The first one I saw was only $900 but it wasn't the correct airbag.
Thanks to Timbits93, he gave me the part numbers and I ended up getting the correct one. If yours is in good condition, you might be able to get rid of yours for $1000 at least. |
07-31-2014, 08:19 AM | #8 |
Rep 11
Yeah it would be brand new as it would be removed before delivery. My only hesitation is whether the Alcantara wheel would wear with daily use.
08-07-2014, 08:48 AM | #9 | |
Rep 180
08-15-2014, 02:13 AM | #10 |
Rep 30
08-19-2014, 01:34 PM | #12 |
Rep 119
Are all m steering wheel heat compatible?
kinetic340i0.00 |
08-19-2014, 03:43 PM | #13 | |
Rep 1,976
After that, you just need to change 205 to 2TB on your FA and VO code FEM_BODY, GWS, ICM, KOMBI, EPS and EGS with E-Sys. Not sure if we're allowed to post links from other forums here but there's a post with the pinout and instructions. I'll shoot you a PM if you want to have a look.
08-19-2014, 03:45 PM | #14 |
Rep 1,976
I never had the heated steering wheel so I had nothing to lose. You can always get the heated version and I'd assume it would be plug and play. All the connectors are exactly the same to the non-M Sport steering wheel so minus the paddles, you can get everything working without the need to code anything.
Just make sure you get the proper airbag as mentioned by Timbits93 earlier.
08-20-2014, 01:39 PM | #15 | |
Rep 119
08-20-2014, 07:04 PM | #16 |
Rep 1,976
Yep, just take out the airbag, unscrew the steering wheel and undo all the connectors, bolt the new steering wheel on and plug everything back in. No coding or wire cutting required.
08-21-2014, 12:14 PM | #17 |
Rep 119
Oh I see, so is it possible to get a steering wheel without paddlers and just use my own instead?
08-21-2014, 12:22 PM | #18 |
Rep 1,976
I honestly haven't seen anyone retrofit just the paddles without changing out the steering wheel but if you just get the M sport one that has the paddles then it's plug and play.
01-13-2015, 07:32 PM | #19 |
Rep 36
you used the original hex bolt from your car? it looks like they're different on the M tech
01-13-2015, 08:36 PM | #20 |
Rep 588
Drives: F30 320d & G29 M40i First Edtn
I remember reading somewhere with a change of airbag (from standard sport to M-Sport for instanace as you've done) you need to have the car re-coded for that... Cant remember which post but it was on here somewhere :-\
F30 320d ED Melbourne Metallic, Vis Pack, Dakota Leather, & Other Goodies
G29 M40i First EditionFrozen Orange |
01-14-2015, 12:10 PM | #21 | |
Rep 1,976
On my FEM_BODY module however, I do get a "Steering Wheel - wrong version installed error" which can only be read if you have a code reader or ISTA.
01-14-2015, 12:12 PM | #22 |
Rep 1,976
Nope, it's the same hex bolt.
