BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Headlight alignment
      01-20-2015, 08:10 PM   #1
rcc_007
rcc_007's Avatar
Drives: 2013 BMW 335i Xdrive
Headlight alignment
Hey guys,
I had both headlight replaced at the dealer due to a manufacture defect recently. When I got the car back the headlight seems to be pointing lower than my previous ones. Took it back to the dealership to have it checked out and they said it aligned perfectly, but it continues to bother me when I am driving. I considered take the car to another dealer but I am afraid they may charge me since they did not install the headlights. Anyone has similar issues? Any thoughts on what I should do?
      01-21-2015, 03:47 AM   #2
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
If you really do feel that they have been lowered, you can re-adjust them by yourself, but make sure that you don't aim them too high, in which the dazzle on coming traffic.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10
      01-21-2015, 06:37 AM   #3
tomsab0
Drives: F48
can you explain how this works with xenon headlights?
      01-21-2015, 11:28 AM   #4
Fronzdan
Drives: '24 M240 xDrive
I suspect there is an adjustment screw, but I'm interested to hear as well. I haven't bothered to look, but my left light seems to be slightly lower than the right.
      01-21-2015, 05:42 PM   #5
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Open your hood, you will find 2 screws over each headlight, the inner one adjusts the height of each light source. Clockwise to lower, counter-Clockwise to raise. Check on the forum, it is in the DIY sticky, really straightforward.
      01-21-2015, 05:52 PM   #6
ktula
Drives: 2014 F31
The driver side headlight is meant to be lower than the other one.
      01-21-2015, 06:14 PM   #7
Daftasabrush
Fool
Daftasabrush's Avatar
England
1857
Drives: F31 340i
Really? With adaptive headlights (in Europe) the drivers side is lower than the passenger one until you reach about 30mph, then it raises and moves towards the passenger side to create a longer beam. If you just switch the headlights on, instead of auto, they're both the same height.
http://www.al-lighting.com/lighting/headlamps/afs/ has more info on the system
      01-21-2015, 09:45 PM   #8
Fronzdan
Ahh then I guess I'm fine. So why is the driver's side lower?
We don't get adaptive headlights in US, unless you code them on.
      01-21-2015, 10:15 PM   #9
Jet Driver
Drives: 2015 328i xDrive
When xenon lights were first introduced in the US, there was a lot of pushback because they were so bright they would blind oncoming drivers. Now they have "cutoffs" that limit how high the low beams illuminate. The driver's side is lower to help with the "blinding the other guy" issue.
I've got a 2015 328i xDrive with adaptive headlights. There was no coding done.
      01-21-2015, 11:48 PM   #10
ktula
Drives: 2014 F31
Xenon headlights for the 3-series (and others) are adaptive headlights. I think you are referring to Variable Light Distribution, which are intentionally disabled for US-spec cars.
      01-22-2015, 09:13 AM   #11
Fronzdan
Yeah that. I've seen the video/demo and wish we had it.
