05-29-2016, 07:11 AM | #68 |
Rep 1,291
I chose to run the wires underneath the rear seats, so going into the cabin then tucked under the rear seats. Wire was a bit short so perhaps try beanbaguk's way.
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
05-29-2016, 10:04 AM | #69 | |
Rep 938
I haven't completed my cabling diagrams yet however this should give you an idea of where to route the cable: Remember, the cable should not be taut. It should have some slack along the whole length.
Current car: 2017 BMW G30 520d M-Sport, BMW F46 218d Grand Tourer
Previous cars: 1989 BMW E30 316i, 1998 BMW E36 323i Coupe M Sport, 2009 BMW E87 116d, 2013 BMW F31 320d M-Sport |
05-31-2016, 03:46 PM | #71 |
Rep 100
Ok, I posted the info in another thread allready (http://f30.bimmerpost.com/forums/sho....php?t=1234349), but it concerns bimmertech amp upgrades for base equipped bmw's:
I have a 428i with base setup, but I have a ASD (active sound design). Apparantely if you have base setup and ASD, the ASD acts as an amp. So: HU > ASD > Speakers in my case So some people say I should not use the normal base to hifi harness. Because the good sequence should be : HU > ASD > AMP > Speakers, like it is when you have Hifi of HK. With the normal base to hifi harness the sequence would become: HU > AMP > ASD > Speakers. What isn't a good idea... What do you guys think? Anyone that also has ASD here? |
05-31-2016, 11:02 PM | #72 | |
Rep 101
As for the harness, i suspect Bimmertech has taken the ASD wiring into account since all my speakers are making sounds. |
06-01-2016, 09:32 AM | #73 |
Rep 100
But then you push amplified sound through the ASD... and the ASD amplifies this sound again. Could this do any harm?
Also your subs don't pass the ASD anymore, so maybe that is a part of your problem... |
06-01-2016, 11:11 AM | #74 | |
Rep 1,291
On my side with base stereo my 03/2014 F30 doesn't have ASD, so not sure what the rule is.
06-01-2016, 10:41 PM | #75 | |
Rep 101
BTW, is the ASD simply just amplifies the fake exhaust signal generated from NBT or other ECU? or this is where the fake exhaust sound is actually generated and mixed into the sound systems? Have you checked with Bimmertech about how the signals pass through their harness? Maybe they did go into ASD first? Hope Bimmbertech Nelson could help explain on their base to HIFI harness mechanism. As for the SUB, even if it doesn't go through the ASD AMP, the Bimmertech AMP is still driving them. I have no complaint about the ASD sound. The weak bass i am feeling is when i am listening to music. They just don't punch.... For the latest update on my system tuning. I had cranked up all the possible gain setting in the DSP for the sub and the bass setting in iDrive is unchanged at default value (in the middle), and also adjust the switch 2 and 4 to on. Also got another suggestion from a X5 friend. He told me to change the HIFI_System in NBT coding to "individual" rather than to "HIFI", and it did help to give more solid bass. Now i think bass is ok, and still thinking if I should save some $ on adding an additional sub AMP. For those who use Focal subs, i am told that the unit were actually designed to replace the HK Subs. So it would have perfect fit if installed in the HK Sub enclosure. I have ordered the HK Sub enclosures and a B&W center tweeter and a X5 center mid range. Waiting for these parts to arrive and will have center sound stage installed. |
06-01-2016, 10:42 PM | #76 |
Rep 101
No idea, either. But mine is 05/2014, and it came with the ASD.
06-03-2016, 04:10 AM | #77 |
Rep 1,291
I just got the grill for center speaker from the dealer, will attempt to cut into the dash sometime soon.
By any chance, did you have time to make the PDF? Could save me from tragic mistakes
06-03-2016, 05:21 AM | #78 | |
Rep 938
(I'd like to replace my subs as this is really letting the whole system down at the moment).
06-03-2016, 05:33 AM | #79 |
Rep 938
Important notice for BASE STEREO BSW Stage 1 owners
This is really for owners who've upgraded their base stereo system with bavsound stage 1 kits, and then decided to upgrade to the Bimmer-Tech premium audio kit afterwards.
I've had HUGE issues getting my premium audio system to work. I won't go into a mass of details, but short of the long; I was getting a lot of clipping at 2/3 volume and above. I've worked very closely with Bimmer-Tech who've been brilliant trying to suggest all manner of things to resolve the issue. (Cables, battery, configurations, everything). Last night however I finally managed to get through to Bavsound and I think I found the cause. The bavsound front mid-range speakers come with an in-line filter, (I am not talking about the tweeter cross-over filter), and this is used to improve the sound quality when the output is from a base stereo HU system which is very very low. However, the new signal from the Bimmer-Tech amp is of course much more powerful and therefore, this filter is no longer required and will potentially cause problems, (including clipping). The short of the long is it has to be removed. (Hifi BSW S1 users will note this filter does not exist with their set-ups.) Tonight I plan to remove this filter from my BSW speakers and I'm literally praying my new amp issues are all resolved! I'll post an update on this as soon as I've completed the changes so unless you are feeling adventurous, please don't make any changes yourself until I've reported back. Remember, you do all these changes at your own risk and I take no responsibility for my suggestions!!! Fingers crossed this works!!!
06-03-2016, 01:29 PM | #82 |
Rep 1,291
PDF Is best - thanks a million
06-03-2016, 03:22 PM | #83 |
Rep 938
So this is the removal of the Bavsound Base Stereo mid-range driver filter.
This is the filter. The tweeter filter MUST remain. Removing it is pretty straightforward. Just cut the cables on each end. Make sure however you keep enough on the cables so you can re-attach it should you need to: When re-attching the cables I used crimps to ensure a solid connection. Once everything is reconnected, you can test the speakers before re-attaching the door-cards. And there you go. Clipping gone....at least in early tests. I still need to upload a HiFi BSW config file. This is basically what you will now have in terms of wiring. I hope this helps!
06-04-2016, 11:27 AM | #85 |
Rep 100
Ok, template is finished.
See pics. It has two outer lines: first line (most outside) is the size of the cover, second line fits in the dashboard. So you have to cut at the second line. I suggest you cut out everything on the template (big hole in the middle and the 4 on the corners) and then tape it to the dashboard and mark the cut out lines with a fine pen. Then remove the template and start cutting You will need a very tiny knife. There is not much room! I will use this one (it is for making scale models. It's small and very sharp): Link to PDF (hope this will work) ftp://users.pandora.be/20160604%20ce...0cut%20out.pdf |
06-04-2016, 12:15 PM | #86 |
Rep 1,291
Thanks a lot
For the link to PDF, but it asks for a password; perhaps use a google drive or dropbox?
06-04-2016, 12:25 PM | #87 | |
Rep 100
Can you PM me your emailaddress? Then I will email the pdf to you. Maybe you can put a link here? I tried google drive, but my wife also couldn't open it... Maybe because it is not set to public or something? |
06-04-2016, 12:26 PM | #88 |
Rep 1,291
Hi you can attach it as PDF with your post here in fact
