06-22-2016, 07:07 PM | #45 |
Rep 312
You'll need to code out all cold and warm checks for anything LED, otherwise it'll flash every so often. This goes for any aftermarket LED or HID headlights or bulbs.
06-23-2016, 04:40 AM | #46 |
Rep 157
Thanks I may have sorted it but wanted to be 100% sure ?
Do you know the coding needed, thanks |
06-25-2016, 01:19 PM | #47 | |
Rep 24
06-25-2016, 03:33 PM | #48 |
Rep 16
Hi
After the coding the shaking stopped , but it happens when you drive for more than 2hours then i have to switch off the light then turn it on to stop the shaking ( i can live with that ) The bulbs fits inside the head lights properly but make sure to adjust the light alignment/direction |
06-26-2016, 09:32 AM | #50 |
Rep 312
Make sure both low and high beam are coded out. These headlights use the same bulb for both. I drive 4 hours straight every week to visit family, and I've never had flashing lights or shaking issues.
07-27-2016, 12:24 PM | #51 |
Rep 24
Hey is anyone in the Portland, OR area able to easily code out the warm/cold checks on an f30? It looks like the "one-stop shop" that I went to (and otherwise did a completely kickass job) does not and it's driving me crazy D:
Other than that the install works perfectly. There's potentially a bit of money/booze/my everlasting appreciation in it for you if can help me out here |
07-29-2016, 01:46 PM | #52 | |
Rep 24
If you have you exact coding list that would be even more of a help! To the best of my understanding this is what I need to do for my HID setup: FEM Body > 3061 > AL_L_KALTUEBERWACHUNG > Nicht_aktiv FEM Body > 3061 > AL_L_WARMUEBERWACHUNG > Nicht_aktiv FEM Body > 3061 > AL_R_KALTUEBERWACHUNG > Nicht_aktiv FEM Body > 3061 > AL_R_WARMUEBERWACHUNG > Nicht_aktiv FEM Body > 3061 > FL_L_KALTUEBERWACHUNG > Nicht_aktiv FEM Body > 3061 > FL_L_WARMUEBERWACHUNG > Nicht_aktiv FEM Body > 3061 > FL_R_KALTUEBERWACHUNG > Nicht_aktiv FEM Body > 3061 > FL_R_WARMUEBERWACHUNG > Nicht_aktiv |
08-28-2016, 02:38 PM | #53 |
Rep 3
So I bought some Anzo U Bar headlights which appear to be the same as Eagle Eye, are supposed to be a direct plug and play. They look amazing on the car but my only concern is that the outer project is supposed to be the low beam and the inner projector is supposed to be the high beam (LED). The outer projector is doing both and the inner projector doesn't seem to be doing anything at all. I had them professionally installed, and the installer said there was only the one factory plug to use so he wasn't sure why they aren't working. Any ideas? Company said they would send more and I could return them but I'm wondering if I'll just run into the same issue with the new ones? The part number is 121504.
