11-15-2017, 03:00 PM | #1 |
Rep 493
LCI LED beam adjustment?
First night time drive and not a huge fan.
HBA was working ok, but FB seemed to tail off way early, like the beans were too low. On LB they seemed too low, cutting light enough on a rural 60mph road to about 40mph visibility range. So tempted to experiment. I hate to say it but my wife's old Fiesta ST had better headlights and they were just OEM halogens. Perfectly good out of the box. My Z4 isn't good, but a quick turn on the adjusters and you can at least go 50mph+ on low beam and old halogens and not dazzle anyone. But where are the adjusters on the F3x LCI leds? I took a quick look and saw nothing obvious. Searching just gave me angel eye threads and people coding USA lights. |
11-15-2017, 03:45 PM | #2 |
Rep 493
http://f30.bimmerpost.com/forums/sho...8&postcount=10
Found a thread at last (Google better than forum search) Looks easy. Now to set up on a flat road and tweak |
11-15-2017, 03:59 PM | #5 |
Rep 493
With my Z4 I just did 1/4 at a time and ran the car a good while and just kept going till I got flashed at then wound back 1/4.
I think the mot place then had issues, so went back another 1/4 and it's been like that nearly a decade. I'm baffled how BMW can sell a car with AUC, or new even, with lights set up so badly. I honestly feel BMW engineers are great. But the rest of them from that point down are f'ing useless. Last edited by Mr Whippy; 11-15-2017 at 04:06 PM.. |
11-16-2017, 11:35 AM | #6 | |
Rep 589
Vertical only needs doing. Clockwise or anti? |
11-16-2017, 02:46 PM | #7 |
Rep 274
anti-clockwise to go up on my lci led
F31 335d M Sport | Estoril Blue & CR | M Sport+ | Pro Nav | Comfort Pack | Adaptive M Sport suspension | Active Cruise
11-16-2017, 04:07 PM | #9 |
Rep 32,881
Use a power drill and aim the beams against a wall or garage door etc. makes it a lot easier. If on level ground measure height of the middle of the headlight then make marks on wall/garage door at that height as a rough guide of the height to adjust the beams to.
11-17-2017, 02:44 AM | #10 |
Rep 3,066
Xenon's on my F31 are fantastic & wifey's Z4 not a fan of the LED look personally, but that's another story.
Agree that you shouldn't have to set them up should be done ready for use. |
11-17-2017, 04:11 AM | #11 |
Rep 493
I just used a hex key, 360deg seems about enough, or 1/4 turn around that.
720deg was almost flat. It seemed very easy to turn them, not sure I'd use a drill or anything automated unless you want to damage your lights. So I'm at 360deg and will test tonight properly. I think I can tweak the offsid up a touch more to flatten the pair of beams. Not sure these lights have an asymmetric pattern? |
11-17-2017, 12:45 PM | #12 |
Rep 554
Drives: 335D MSport 2016
7mm allen key I think at the back of the headlight, the other does the horizontal. Did mine about a month ago and much better, dark garage against the wall so you get them even
11-17-2017, 04:23 PM | #13 |
Rep 493
The top portion is so blurry though, and jaggy.
I'm not sure where to say is the top of the beam. I'm going to go more on other road users reactions and the 10cm per 7.5m as a guide. Not sure on lateral adjustment. Might have to go find a big flat open area and play around (and record what I change) |
11-18-2017, 07:47 AM | #14 |
Rep 181
I don't understand why the lights are not better.
My other half has a new shape MX-5 that cost £19K and has full led headlights as standard. They are stunning. Every time I drive it & then go back to my F31 I am disappointed. They light up a long way evenly with a laser sharp cutoff. This from a lower mounting point & they are styled as narrow slits. Best lights I have ever experienced. The F30/31 has larger higher mounted lights, they should be far better. |
11-18-2017, 02:50 PM | #15 | |
Rep 32,881
11-18-2017, 02:52 PM | #16 | |
Rep 32,881
11-19-2017, 03:23 PM | #17 |
Rep 493
I need to do more testing but from what I've seen the high and low seem joined, as in turning low beam up turns up high beam.
But I feel high beam could do with being even more up independently of low beam. It does seem weird that BMW cheaped out on the 3er spec LED lights to the point they're some of the worst out there! |
11-19-2017, 05:56 PM | #18 | |
Rep 32,881
11-19-2017, 06:03 PM | #19 | |
Fool
1857
Rep 3,542
Interestingly, the iihs almost agree, the CX-3 has longer range on low beam than the BMW but less range at high beam (less important IMO). http://www.iihs.org/iihs/ratings/veh...s-4-door-sedan http://www.iihs.org/iihs/ratings/veh...-door-suv/2017
11-20-2017, 02:06 AM | #20 |
Rep 2,495
I don't get the negativity on the Adaptive either. Mine are easily the best lights I've ever had and that's coming from my 640 with Adaptive Bixenons and a C63 with BiXenons too.
Even this morning I was blown away with how well they light up country roads both in full beam and dip. The way they adjust to traffic, when catching up other cars and oncoming makes me smile. The way the beam splits and seems to put perform the car in front's lights is epic. So I can only conclude that stock LED's aren't good and the Adaptives where they are not working properly should be checked by a dealer.
Arrived! 2022 X4M Competition, SPY + Black Merino
Gone: 2019 X3M Competition, Toronto Red, Adelaide Grey. |
11-20-2017, 02:40 AM | #21 | |
Rep 32,881
11-20-2017, 02:44 AM | #22 | ||
Rep 2,495
I wonder if like the Halogen bulbs the LED's could be upgraded?
