BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > CHALLENGE - F30 335 - HFC and Catless Downpipes - Now Released! - Pics inside -
Closed Thread
      09-12-2013, 11:02 AM   #199
M.Suka
M.Suka's Avatar
Drives: 2013 335i M Sport
Originally Posted by mikew2069
Originally Posted by M.Suka View Post
looks like a M8 hex nut and bolt.
Yes that sounds right if I remember correctly.... Also a good trick is to super glue the nut on to the DP before installing. It'll make more sense when you're actually doing the install.
Good tip makes sense since the OEM bolts are welded on
European delivery 9-19-2012
      09-12-2013, 11:05 AM   #200
boomn29
boomn29's Avatar
Drives: 2012 BMW 335i
I read on someone's build thread that you cant re-use the 2 mounting bolts from the stock down pipe, do you know if challenge provide's you with those 2 bolts and if not does anyone know the size, thanks.
They do NOT furnish any bolts or nuts unfortunately. I had to scavenge for some.
When I loosened the rear bolt, it eventually just broke off.
2012 F30 BMW 335i
8sp; Red; Sport, 20x9f; 20x10r (wearing 245/275's) Bronze Forgeline DE3C's, M-PPK, Challenge HFC-DP.
Winter Setup: 18x8 Black Enkei's with Blizzaks!
      09-12-2013, 11:12 AM   #201
boomn29
boomn29's Avatar
MPPK + Challenge HFC DP - check out the torques...
2012 F30 BMW 335i
      09-17-2013, 01:08 AM   #202
M.Suka
M.Suka's Avatar
Nice! at what RPM was that, looks like around 2.5K.
      09-17-2013, 11:20 AM   #203
boomn29
boomn29's Avatar
Ya know, I'm not sure. I tried to snap a few pics while simply holding my phone out to the right on a secluded road (yada yada).
It'll show that ~350tq in several gears and several RPM's. I think that above pick might actually be in like 7th/8th at 50mph so I could get a clean pic.
In the lower gears (2nd/3rd), it doesn't always max to 350tq; sometimes 320tq if I recall. Still plenty of more power as compared to 100% stock - note I've got the DP and the M-PPK.
2012 F30 BMW 335i
      09-28-2013, 02:00 PM   #204
BRM6
BRM6's Avatar
Brazil
Drives: 328/335/M235i/M4 - Current M6
No bolts are provided? Which do we need to install this? Can Challenge confirm this please? I want to order, but being overseas is not as easy to find certain parts as in the US.
      09-28-2013, 05:34 PM   #205
Kongen71
Kongen71's Avatar
Belgium
Drives: F30 335i M-Sport 2013
I got my new F30 335i m-sport last month and already installed JB4. Ordered the downpipe from Evolution Racewerk but it doesn't fit my car!!!! The diameter of the flange is too small - 10.5Ø instead of 11.8Ø - apparently BMW changed the design !?! Can you please tell me the size of the catl*** before I order.
      09-30-2013, 10:51 AM   #206
GTM_Challenge
GTM_Challenge's Avatar
Drives: E46 M3, E90 M3
We will be shipping them with the 2 metric stainless bolts/nuts now to make install a little easier.
      09-30-2013, 10:55 AM   #207
GTM_Challenge
Please let me know which flange you are asking about? At the turbo, or at the exhaust side? Inner diameter or outer diameter? I'm assuming the measurement you gave is in centimeters?
      10-02-2013, 02:17 PM   #208
BRM6
BRM6's Avatar
Brazil
Can you confirm the bolts/sizes please? I bought one of your catted downpipes and have a scheduled install for next monday. Would like to be prepared!
      10-02-2013, 02:24 PM   #209
tdizzle
Drives: 2017 F80 ZCP
Don't forget to do a before/after dyno!
      10-17-2013, 06:50 PM   #210
M-terkait
M-terkait's Avatar
Kuwait
209
Drives: F30 335i 3/13
Catted - HFC. (I'll update my sig to more clearly state that).
Do you smell anything or see any smoke going out of the exhaust at WOT ?
Docrace 6266
      10-17-2013, 08:36 PM   #211
boomn29
boomn29's Avatar
There's a slight difference in smell. I notice it mostly when idleing in the garage in the morning - which is pretty normal being a cold idle on a colder day.
There's nothing like dark or black smoke or anything like that. I posted a WOT vid up to 115mph right over the exhaust and you can't see anything of the sorts.
Keep in mind; I've ran catless vehicles before (and owned a racecar).
2012 F30 BMW 335i
      10-18-2013, 12:05 PM   #212
M-terkait
M-terkait's Avatar
Kuwait
209
How did you clear codes or any error caused by the HFC-dp ?
you still running it on MPPK right ?
Docrace 6266
      10-19-2013, 09:24 PM   #213
boomn29
boomn29's Avatar
Yes; MPPK still.
The 420 exhaust code is still there. I have a code puller, so I occasionally double-check to make sure there is nothing new and clear it. But I have not tried anything to remedy.
In other cars it's pretty common to try and use spacers to help the issue. But I haven't had the energy to want to crawl back underneath the car to uninstall it - then attempt a fix that might or might not work.
2012 F30 BMW 335i
      11-03-2013, 06:43 AM   #214
M-terkait
M-terkait's Avatar
Kuwait
209
i just installed HFC DP and had already MPPK i feel difference in sound either than that i don't feel any extra power , but didn't dyno after installation ill do one and get sure.
Docrace 6266
      11-03-2013, 07:37 AM   #215
Seraphblade@sg
Drives: F30 328i
Wow. No shit.
U din know the sports display is actually a "throttle position" display? It will not show u ur actual horsepower and torque other than what the car thinks it is delivering at that throttle. Meaning, if u had a jb installed which supposedly give u 500 tq, ur "meter"' will still show 350ish?
      11-06-2013, 10:09 PM   #216
GhazaliGTE
GhazaliGTE's Avatar
Drives: 2013 335i M-Sport
Has anyone else had their CEL trip after installing the Challenge HFC DP?? Mine lit up this afternoon (approximately 100 miles after installation) and I'm not sure if it's normal for this to happen to the F30 (2013 8AT). I had it installed professionally too so I don't think it's me.. However, I am blown away by the results! The spool makes me weak at the knees and the more pronounced upshift burble makes me smile so hard every time I hear it! Thanks for a great product! Now...if we can solve this CEL problem I'd be golden! I'll reset it tomorrow and update further if it comes on.
      11-06-2013, 10:24 PM   #217
vip
vip's Avatar
Drives: 2001 Alpine White M5
how is the smell? I have the er catless dp and it smells so bad during idle, at traffic lights and occasionally while driving (all while outside or with windows down of course).
sent from bimmerpost Android app
      11-06-2013, 10:44 PM   #218
GhazaliGTE
GhazaliGTE's Avatar
It's definitely not terrible and I only notice it when the car is stopped. Let me get more time with it and I'll give a better analysis. I've only had it in for a day or two now lol. I would never describe the smell as terrible, though. Then again, as mikew2069 deduced, Iwe're still in our honeymoon stage!
      11-07-2013, 07:03 AM   #219
mikew2069
mikew2069's Avatar
413
Drives: F30 335i MSport
Yessir! Hfc dp definitely isn't going to smell as bad as catless - that's whys I opted for hfc
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4
Wagner/Evo Race/M-Performance
2016 F15 50i ///M-Sport
BM3/H&R/Borla
      11-07-2013, 08:29 AM   #220
DVC
Diligentia Vis Celeritas
DVC's Avatar
Drives: 335i
deleted
Closed Thread
