BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Retrofit B-Pillar Ambient Lighting
      02-02-2016, 11:45 PM   #45
MSportTune2
Aland Islands
80
Drives: F30 MSport
Originally Posted by a803sgo View Post
just so I'm clear, 63319242154 is the actual mount for the led and 61319242163 is the led with a lead attached to it that runs down to the connector at the rear door?
where does 61129335592 fit in?
thanks.
A Friend of mine bought this part# 61129335592 for his F22 to retrofit the airbag ambient light and it is wrong part. I have no idea what is the correct repair cable part#.
      02-06-2016, 06:39 PM   #46
charles.soori
Drives: 2016 F85 x5m
Wish I can do this to my f25 2016. Seems like the part is not for x3.
      02-06-2016, 08:48 PM   #47
MSportTune2
Aland Islands
80
Drives: F30 MSport
Do you have ambient light? What about the airbag cover? Is it removable?
My friend did the mod on his F22. He has the airbag logo but it is not a cover. It is part of the trim but same size as the removable airbag cover. He had it removed by cutting the airbag logo and then use the airbag cover with reflector and the LED light cum cable and hook it up to the existing ambient light.
It is cheap mod so see if you are game to try it.
      02-07-2016, 11:07 AM   #48
charles.soori
Ye I have ambiet light. If it's the same size then I can cut it. I do have the airbag trim, but not sure if it's a removable cover. I have two in the front and two in the back. If it's the same size for all bmw then i'll order 4 and try it.
      02-07-2016, 06:20 PM   #49
hsk1610
Drives: 2013 328i xDrive
Does anyone have detailed instructions on taking apart the B-pillar to do the wiring?
      02-09-2016, 12:21 AM   #50
bmbk
bmbk's Avatar
Drives: BMW F30 316I
interested here
      02-09-2016, 05:38 PM   #51
david51
david51's Avatar
France
538
Drives: bmw M3 F80
http://f30.bimmerpost.com/forums/sho...php?p=17360496
      03-16-2017, 04:36 PM   #52
AntonyKwok
Drives: F30 328i
Does anyone have the detail installation guide for this airbag lighting part?
      09-13-2017, 03:08 PM   #53
AntonyKwok
Drives: F30 328i
Originally Posted by BMW3291 View Post
You need to connect at rear door harness.
Sorry, I know this is an old post. I'm now doing this retrofit, but I don't know where the connector from the air bag should connect to. Do I need to cut the wires from the B panel and attatch with the air bag wires? I'm so confused of doing this retrofit... I'll post some pictures later to illustrate what I'm taking about
      01-10-2018, 10:21 PM   #54
ettam88
ettam88's Avatar
Drives: f31 my2013
idea: connect to the glass switch panel?
the window switch lights up at night when the indoor lighting is switched on
      04-09-2018, 02:02 PM   #55
jimmy89045
jimmy89045's Avatar
Drives: 435i
Anyone do this on an f32 msport? Or have any ideas on where to tap for power?
      03-19-2019, 03:56 AM   #56
BackBlue
BackBlue's Avatar
Drives: E46, '13 E70 N63, '19 F33 440
Originally Posted by david51 View Post
I just change the orange LEDs by blue
I always have a choice of blue or white
Can you give more detail on how you changed the LED and where you sourced the proper blue LED for the swap.
Thanks!
      03-20-2019, 12:28 AM   #57
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Thanks!
Hello
https://f30.bimmerpost.com/forums/sh...php?p=17360496
https://www.ebay.fr/itm/5-a-50pcs-LE...AzItcQkdF04pSw
BackBlue107.00
      03-22-2019, 06:04 PM   #58
BackBlue
BackBlue's Avatar
Thanks!
I'm having a bit of trouble finding the same LED's her in the US that you linked me too.
Do these look like the correct size and type?: https://www.ebay.com/itm/LCBM67S-OSR...72.m2749.l2649
      03-25-2019, 12:33 PM   #59
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Thanks!
they look identical to my leds
BackBlue107.00
      08-17-2023, 12:31 PM   #60
labanauskas
Lithuania
Drives: F30 LCI 318d
Hi,
I have f30 lci with ambient lighting. When I've removed door connector, there is no white/blue wire, only the white/red. Can I connect from b pillar wiring 2 and 3 pins together to the white/red one?
      08-17-2023, 01:33 PM   #61
eff32fl
eff32fl's Avatar
1052
Drives: 2019 440i M Sport THP MPPSK
Benzinfabrik a German company also sells blue/white replacement modules that are plug n play. No need to mess with soldering tiny LEDs. That module looks like the door card ambient lighting module.
      08-19-2023, 03:34 PM   #62
labanauskas
Lithuania
Originally Posted by labanauskas View Post
Hi,
Did mine today. I've connected only two wires: ground in pin 14 and red/white in pin 17. And it's working. Without wire slicing or tapping.
