BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > LED Fogs + 50w Brake LEDs
      09-10-2015, 07:11 AM   #89
rustyminded
rustyminded's Avatar
248
Drives: BMW 328i
Originally Posted by nickhelou View Post
It might need the resistor, and it might not. If you want try it out without the CanBus connectors first, if your lights function normally, then you don't need them. It's a trial and error, as each bulbs have a different design and CanBus characteristics.
ah ok I will try my luck but what's weird I can't find it anymore on Horizon website. it's 6000k anyway so I might not like it's color vs. 5000k bulb I have.
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
      09-10-2015, 07:12 AM   #90
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Email them about CanBus connectors for H8 bulbs. They'll have them for sure.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10
      09-10-2015, 07:33 AM   #91
rustyminded
248
Drives: BMW 328i
I can't get it from Horizon everything from USA remember.
check these out
http://www.ebay.com/itm/New-2-X-H11-...de2921&vxp=mtr
http://www.ebay.com/itm/2X-H8-H9-H11...d20e3b&vxp=mtr
http://www.ebay.com/itm/H8-H11-LED-T...662c4a&vxp=mtr
      09-10-2015, 07:36 AM   #92
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
check these out
I'd go with the middle ones. They look very similar to my Horizon ones.
      09-10-2015, 07:47 AM   #93
rustyminded
248
Drives: BMW 328i
ok you are awesome man. thanks a lot can't wait till they get shipped
      09-11-2015, 02:49 PM   #94
Yeoman
Drives: 2019 M5 Comp
Added the Horizon LED 50W brake lights.. pic shows the Horizon light on the left side, and the run of the mill ebay 1156 LED on the right. Huge difference and very happy.
      09-11-2015, 04:00 PM   #95
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Congrats man, enjoy!
      10-02-2015, 04:26 AM   #96
ttxuky
ttxuky's Avatar
Spain
Drives: bmw f30 316d
What color are the bulbs, red or white??
      10-03-2015, 05:08 AM   #97
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
From the hue of the tail light, I'd say red.
      10-04-2015, 06:00 AM   #98
Gabreigns
Gabreigns's Avatar
494
Drives: F3x
Has any one tried the curved Cone H8 fog lamps from horizon? http://www.horizonleds.co.uk/cree-le...e-cone-led-45w
      10-04-2015, 07:01 AM   #99
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Nope, I'm guessing if you buy them then you will be the first.
      10-05-2015, 05:29 AM   #100
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Update:
New fog light LEDs installed. Thread updated.
      10-05-2015, 07:42 AM   #101
Gabreigns
Gabreigns's Avatar
494
Drives: F3x
Update:
Where did you order the new bulbs from? Edit: never mind. Found them.
Just pulled the trigger for the same but from US as I can get it tomorrow. Did you need Load resistors for your install of these bulbs in the fogs? I am confused. Canbus connector and load resistor the same thing? Where did you get the Canbus connector for H8 from? Also when you install these do you remove the wheels or just turn it away to access the bulb housing? Your response and experience are appreciated.
      10-08-2015, 03:49 PM   #102
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
I'm not sure about the CanBus connectors vs. resistors question, but I don't think they are the same. When installing, if you choose to work on the left side, turn the steering wheel as much to the left as you can, then you will have more leverage with the screws. Vice versa applies for the right side. Do post pictures of your results!
      10-08-2015, 04:17 PM   #103
Gabreigns
Gabreigns's Avatar
494
Drives: F3x
Here are the fogs and the results. I wish the color correction stickers worked as I think they match the led rings but not the HIDs. Still trying them out though.
      10-08-2015, 04:18 PM   #104
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Haha nothing is showing yet.
      10-08-2015, 04:40 PM   #105
Gabreigns
Gabreigns's Avatar
494
Drives: F3x
Bugger sorry.
      10-08-2015, 04:42 PM   #106
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Bugger sorry.
That looks good! Have you noticed any glare? By the way, I noticed our fog light housing gives us more side light than straight light, so when cornering these lights will be extremely useful if you don't have adaptive lights or if you simply need extra ground lighting. Congrats!
      10-08-2015, 05:27 PM   #107
Gabreigns
Gabreigns's Avatar
494
Drives: F3x
Yes they do have some glare but I don't drive with them on until I get to a countryside. The do come on when I turn as I have adaptive headlamps. I think I was expecting a huge improvement but I think I was wrong. LED in reflector lamps are not the best combination unless they come stock and the optics have been done right. Honestly there is no way of measuring the lumen output of what is claimed on the box of 3000 lumen.
I didn't need a resistor or Canbus for these leds though. Which is great! Only coding to enable LEDs. I am still going to see how it does over the week. If I am not happy guess I will go back to stock halogen as nothing can be done except go to OEM LCI LED fog lamps.
      10-11-2015, 01:00 AM   #108
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
That's sad to hear! I don't have Adaptive Xenon's so these come in handy for me. It's true that they aren't ideal in a fog light housing, they do have a powerful output in my car. I use whatever lighting they provide to help me with pot-hole vision due to the roads here being filled with them. I've noticed while cornering, the LED in the housing projects a lot to the side, which to me is helpful, as it lights up the corner's surroundings before I take it. You are right though the BMW LED Fog lights are your best option.
Cheers
      10-21-2015, 03:17 PM   #109
rjjy
Drives: TBD: 2012 Mineral White 328i
Hey Nick, really great post! Thanks for putting all this together. I've read through everything a few times but want to make sure I have this correct:
Option 1 = H8 CREE LED - 50W which is a straight swap of the bulbs and is about $35 for 2 bulbs. (Link: http://www.horizonleds.co.uk/h8-50w-...og-light-bulbs)
Option 2 = H8 CREE XHP50 LED Headlight Kit - 3000 Lumens which are actually headlight bulbs, but work and give you more light output. These are $125 for 2 bulbs. (Link: http://www.horizonleds.co.uk/h7-cree...adlight-kit-g4)
Option 3 = Replacing the halogen assembly with BMW LED Foglight Assembly. These are $350 for the 2 housings, but then I need to get LED bulbs? Is that right? (Link: https://www.ecstuning.com/ES2960697/...FVUWHwodK-sP1Q)
Sounds like Option 3 is easily the best but it's substantially more expensive. And the difference between Option 1 and Option 2 is noted throughout the thread (light output, glare, etc).
I'm leaning towards Option 1 since this is entirely an appearance upgrade for me. And each car is different, so it's impossible to know if I need the resistors or not? http://www.horizonleds.co.uk/h8-canb...ning-canceller
Thanks man.
      10-21-2015, 03:22 PM   #110
963mw
BMW Fanatic
963mw's Avatar
Drives: M2
Thanks man.
Hey man,
If you can hold on for one day, I can confirm whether you need the CanBus connectors for the option 2 lights. Apparently this new bulb design doesn't require CanBus connectors, so tomorrow I will take my connectors off and let you know how that works. Option 1 is a good place to start IMO, if you find that you need more light, then simply move on to option 2. I personally need the strongest lights possible for my car given the amount of potholes here, however, your needs may be different, hence different light choices. I will upload some pictures right now of the fog lights in action. Hope that helps! Feel free to ask if you need more help.
