BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > 2015 F30 LED upgrade
      12-14-2015, 12:24 PM   #89
ji99lypuff
Drives: 2014 bmw 328xi
Ok so ive seen these headlights installed on a f30 that parks around and lives around my area and a couple things to note. At first glance i thought a 4 seroes or m3/4 was coming down the block until i noticed it was actually pre lci f30 with these led replica headlights. So first inpression it looked good. And as it passed me i saw the light output and that is where it was a little confusing/worrisome,as it didnt look as bright as hids on f30 or even other car manufacture hids. but then again i was outside the car with no way of seeing how the light output was for the driver. Also they are replicas of an oem product so im sure it has its downsides but just thought id mention that as i saw it in the fleshh.
      12-14-2015, 12:43 PM   #90
lesnica
Drives: M4
Originally Posted by ji99lypuff View Post
Ok so ive seen these headlights installed on a f30 that parks around and lives around my area and a couple things to note. At first glance i thought a 4 seroes or m3/4 was coming down the block until i noticed it was actually pre lci f30 with these led replica headlights. So first inpression it looked good. And as it passed me i saw the light output and that is where it was a little confusing/worrisome,as it didnt look as bright as hids on f30 or even other car manufactureres hids. but then again i was outside the car with no way of seeing how the light output was for the driver. Also they are replicas of an oem product so im sure it has its downsides but just thought id mention that as i saw it in the fleshh.
I've noticed that Hid's have a much more sharper output and these lights are also really bright but the light is more spread out. But anything is better than halogens.
      12-14-2015, 12:49 PM   #91
ji99lypuff
Yes thats true, im sure the output is much better than the halogens! Also it looks much better than the halogens.
      12-22-2015, 01:46 PM   #92
umnmatt
Go University Minnesota!
Drives: e92 m3
install video was emailed to a lot of newsletter subscribers
      01-06-2016, 03:34 PM   #93
mrclam
Drives: 328i
That's all going to come down to the reflector/projector. I've had cars with HIDs for a long time, and this is on par if not brighter.
      01-07-2016, 01:38 AM   #94
squidlyboy
squidlyboy's Avatar
Drives: 2014 Alpine White 328i M-Sport
Can you post a pic of your cutoff against a wall?
I noticed these Umnitza LED headlights do not have projectors. Typically, HIDs/LEDs that don't have projectors and are only using reflectors have a pretty crappy cutoff. Either that, or they just throw light everywhere, blinding oncoming traffic.
In either case, the perception is low quality. Manufacturers typically do this to save on cost as real glass projectors are costly. The advantage though, when they spend the money on real glass projectors is more precision, classier/OEM look, and it starts with a cutoff that looks like this:
      01-07-2016, 10:37 AM   #95
umnmatt
Drives: e92 m3
i got them coming. there are 30 pictures on their site a little hard to navigate but they have arrows next to the photos just press on those and you get lots of images.
looks like the oem lights that also don't have projectors on the LED lights
      01-07-2016, 12:29 PM   #96
kadify
Drives: 428i xDrive GC
WHAT ARE THOSE? But seriously, I have the HIDs and the cutoff looks nothing like that. Neither have any of the cutoffs on any of my previous cars with HIDs.
      01-07-2016, 12:52 PM   #97
squidlyboy
squidlyboy's Avatar
Those are Morimoto's from Retrofit Source (TRS), but my generic mini H1 projectors from Amazon for $36/pair provides a cut-off not far-off from those.
Maybe a better question is ... what projectors are _you_using? But you did indicate that your cut-offs were measured on your previous cars, so it may have been awhile ago.
To be fair, projector technology gets better and better pretty quickly as time goes along, and TRS is on already on version 7.0 on their mini H1 projectors, which was released recently. And all the generic vendors will follow-suit shortly after... So super sharp cut-offs from projectors are pretty much a common commodity part nowadays.
The thing that surprises me that the use of projectors with LED headlights today are still pretty uncommon as far as what I've seen so far. I'm sure cost drives that decision for the most part, but the costs are coming way down, so i'm a little puzzled why more LED headlights don't include them.
      01-07-2016, 12:55 PM   #98
bowman
Drives: x1 m35i
I assume the design of these is based on OEM
http://f80.bimmerpost.com/forums/sho...d.php?t=944264
The cutoff is probably not as sharp due to reflector quality and led type. Still sharper/better then Halogens and close to OEM reflector LEDs.
      01-07-2016, 03:07 PM   #99
macrossVFX222
Drives: 2016 F10
Was about ready to order but called my shop first to make an appointment and discussed this light with the shop guys... Even they are not recommending this set for 1600+..... They are a little surprised at OEM like lights at 1600+ even for Euro cars.
so question for my friends here.... worth the money? should I wait and hope the price drop?
The shop's question is mostly on quality... 1600 ~ 2000 for factory will be acceptable... so if the quality is on-par with factory than maybe its still a good buy?
      01-07-2016, 07:37 PM   #100
sds0918
sds0918's Avatar
Drives: M235 2015
Do you guys recommend Oneighty or Umnitza? Hard to make a decision without direct comparisons. Oneighty just seems a lot more expensive.
      01-07-2016, 07:48 PM   #101
Adamr916
Adamr916's Avatar
Drives: 2014 328d
They are exactly the same light, just different dealer markups
      01-08-2016, 01:40 PM   #102
umnmatt
Drives: e92 m3
probably so.
      01-08-2016, 05:30 PM   #103
macrossVFX222
Drives: 2016 F10
I'd go with Umnitza... but that's because they are local... Also I have heard interesting comments about the other guys... disclaimer: I never ordered from either one of them.. so really its because Umnitza is close to me
      01-08-2016, 08:27 PM   #104
squidlyboy
squidlyboy's Avatar
Get this one - the one with the "hockey stick" acrylic extension all the way to the grill - way sexier, way cooler - the one without the extension seems like a mickey-mouse wanna-be in comparison. Don't compromise man - if you are going to spend a mortgage payment, go for broke.
Oneeighty/Umnitza has meh written all over it ... this one has Whoa WTF all over it
You got a BMW, not a VW
      01-08-2016, 10:16 PM   #105
ji99lypuff
I have not seen a diy on these yet. I bet they are different than the xenons and coding them is new also. Someone had said these retrofits can be near 3,000 dollars or more.
      01-09-2016, 07:23 AM   #106
Adamr916
Adamr916's Avatar
Drives: 2014 328d
€3.000 for non adaptive, €3.100 for adaptive. Which is about $3,300 for the non adaptive, and about $3,400 for the adaptive.
      01-11-2016, 03:32 PM   #107
macrossVFX222
Drives: 2016 F10
Paying 3k is one thing.... the massive retrofit is another story.... I can consider paying 3300 for it, but I don't think even at that price is plug-n-play...
Let me know if I have my info wrong... but if I remember what I read, this is basically similiar to HID retrofit which requires parts and coding.
I don't really think the after-market light is mickey-mouse per se... I've seen one in person and is actually very close to factory... but yes they are nowhere near as sexy as hockey stick
      01-11-2016, 06:23 PM   #108
Adamr916
Adamr916's Avatar
Drives: 2014 328d
I think even the wiring is different with the oem led's. The one thread I read about it, said he had to get different wiring harnesses to do the retrofit, and he was coming from adaptive xenons
      01-12-2016, 01:21 PM   #109
mrclam
Drives: 328i
I haven't gotten a chance to take photos, but I believe umnitza took some photos from when he installed them in my car. The cutoff is definitely not projector-quality.
      01-12-2016, 01:28 PM   #110
MisterZebb
Drives: 2013 328i MSport
What can/cannot be replaced on the headlights? What happens if an LED burns out?
