02-28-2018, 03:21 PM | #23 |
Rep 51
here is a link to someone who changed all the bulbs to LED in his headlights
http://f30.bimmerpost.com/forums/sho...0#post22735850 |
crimson_king36.50 |
02-28-2018, 04:07 PM | #24 | |
Rep 8
Halogen to Led
1. A compatible Led bulb and accessories along with it to remove warning messages and flickers. (I think you posted yours and another similar one in a different both are not available anymore in the links provided) My options are below: http://www.headlightexperts.com/cata...it/category/2/ $109 https://www.carid.com/2014-bmw-3-series-led-lights/lumen-led-headlight-conversion-kit-175098964.html?parentsubmodel[]=MODEL|328i%20GT%20xDrive $150 http://www.opt-7.com/fluxbeam-led-headlights/ $100 2. Where did you buy the ENET cable? Would need a reliable source. 3. What software to use for coding? BMW coding database is something new I guess VS E-Sys ? along with E-SYS we need a database file and any instructions on would help. Thank you |
02-28-2018, 04:17 PM | #25 | ||
Rep 16,083
I've just recently seen some Asian H7 bulbs that claim to be 100 watt. Maybe they are, but that could burn out your wiring. What matters is lumens, that's how light output is measured. 55w H7 are around 1400 lumens. If you can't verify that what you're looking at isn't at least 2000 lumens don't bother. Quote:
03-01-2018, 11:03 AM | #26 | |
Rep 68
Also, Please note how much I spent for the conversion: $22.50 - Low beam LEDs $9.29 - Parking lights LEDs $8.29 - DRLs LEDs $28.68 - Vgate WiFi Adapter $35.00 - BimmerCode App Total: $103.76 Super expensive Low Beams (like some of the ones linked here) are not required |
03-01-2018, 12:52 PM | #27 | ||
Rep 5,457
Drives: F30
Please post part numbers. I will purchase immediately. Appreciate it. Anyone familiar with anything offered at O'Reilly's? Got a $10 coupon to burn there.... |
03-01-2018, 01:43 PM | #28 |
Rep 8
Billfitz and crimson_king Thank you for your quick response. I about to get the required parts and start my upgrade from halogen to led. I will let you all know once done. Thanks again.
03-01-2018, 02:06 PM | #29 | |
Rep 68
Parking light LEDs: https://rover.ebay.com/rover/0/0/0?m...2F232278724652 DRLs: https://rover.ebay.com/rover/0/0/0?m...2F281345560325 Low beam headlights: ROADSUN H7 LED Headlight Conversion Kit 6000K Cool White 72W 9000LM Replace Halogen Bulb Headlights - 3 Year Warranty https://www.amazon.com/dp/B0779BQ2WY..._JksDAbA08GCEV |
sspade2464.50 |
03-01-2018, 02:28 PM | #30 | ||
Rep 5,457
Drives: F30
03-02-2018, 12:33 AM | #31 |
Rep 68
Hey, if you look at my parking lights photo, they are the same exact color and I have a photo with a description of how they look from the inside of the car looking out
04-17-2018, 06:58 AM | #32 | |
Grand Poobah
173
Rep 305
Did you ever find the ENET cable? I've got a vid that shows an example of coding w Esys. About to drop it tonight and it contains links to ESys software and the ENET cable. |
04-17-2018, 07:32 AM | #33 |
Rep 16,083
Enet cable is the wrong term, as that refers to ethernet cable used with peripherals like printers. Google Esys cable and you'll find multiple sources.
04-17-2018, 07:53 AM | #34 | |||
¯\_(ツ)_/¯
537
Rep 1,000
sspade2464.50 |
04-17-2018, 10:52 PM | #35 |
Rep 68
^^^^ Nice vooonoo, I can vouch that it looks like this and you can also check out my post here http://f30.bimmerpost.com/forums/sho...0#post22735850 to see how they look from inside the car looking out
04-22-2018, 12:51 AM | #37 |
25cent millionaire
252
Rep 1,220
Drives: 2020 m4 comp vert
the Philips ultinon are by far the best of the best low beam h7led for our cars.. but damn are they expensive.. I ran hid for high beam 55watt, and had Steve at codemybimmer do his magic with coding, changed all lights to led, except high beams. and changed that park light to a custom made l shaped led assembly right by the fog light...
04-22-2018, 08:09 AM | #38 | |
Rep 16,083
https://www.hidplanet.com/forums/for...ultinon-h7-led More expensive doesn't always mean better. Often it just means more expensive. |
04-22-2018, 07:58 PM | #39 |
¯\_(ツ)_/¯
537
Rep 1,000
Here ya go one with fogs on and one without
04-23-2018, 09:57 AM | #40 |
Rep 8
Successful Upgrade Halogen to LED
Hi everyone,
I successfully installed LED's followed directions from crimson_king post. So it is my honor and privilege to thank him for his directions. Here I will explain my installation in detail. My Car 328 GT with H7 Halogen Low Beam and High Beam, Stock DRL (PW24W) and Stock Parking/Position Lights (H6W). Upgraded from Halogen to LED's Listed below are the 5 Parts Required for the Upgrade and some handy tools in your garage will help you like screwdrivers and a sharp long nail to take out halogen parking lamps and DRL's from the housing. Time Required: 3 hours ( If you are a beginner like me you need 3 to 4 hours depending on the skill set and tools you have and I spent time unlocking the coding feature in the ios app, I recommend you to do it prior to save time during install). 1. Parking light LEDs: 2x 6000K White Error Free BAX9S 64132 H6W 8-SMD LED Bulbs for Parking Lights = $12.99 a pair. https://rover.ebay.com/rover/0/0/0?m...2F232278724652 2. DRLs: 2x For BMW F30 3 Series 2835 White LED Bulbs PW24W Error Free DRL Daytime Light = $10.36 a pair. https://www.ebay.com/itm/281345560325?ul_noapp=true 3. Low beam headlights: ROADSUN H7 LED Headlight Conversion Kit 6000K Cool White 72W 9000LM Replace Halogen Bulb Headlights - 3 Year Warranty = $22.50 a pair. Note: I did not upgrade my high beams and I am planning to keep it as it is as. In the US most of us here use LOW beams and High beam is used in very rare instances. 4. WiFi OBD2 for BimmerCode App: Vgate iCar Pro Wi-Fi OBD2 Scanner Scan Tools OBDII Car Diagnostic Tool Code Reader Fault Check Engine Light for iOS iPhone iPad/Android Compatible with ELM327 Adapter =$26.68 https://www.amazon.com/dp/B06XGB4QL7..._6lsDAbY6BKQSW 5. Iphone BimmerCode App for iOS - Unlock Coding for $27 Note: I used iPhone 6 for my install. Note: There are no errors after the coding. Pictures of the Parts: Comparison Halogen VS Led (Before VS After) Above is Halogen Vs Below LED Improved Visibility from total 5 to 7ft with dark spots to 12 to 15 ft very clear Note: These won't affect other drivers as it is not that crazy powerful. It is just about right. Light Color: White to mild blueish purple just like the Stock Led Angel eyes Coding: Bimmer code app IOS Important Watch: https://www.youtube.com/watch?v=3mUsGMNpGvQ Note: The only hard part is to take out the low beams and you will find it yourself when you start working on. In 3 series you have to reach through the wheels. You have to press 3 prongs at the same time to release the lights. Attaching a picture for reference. Any Questions during the install please feel free to reach here or private message, I wish you all a good luck with the install. Attaching my Guru crimson_king Post here http://f30.bimmerpost.com/forums/sho...0#post22735850 Again Thank you crimson_king without your support, I would not be able to upgrade, Thanks a ton and you have made a difference in improving my safety during my night drives. Last edited by falome2; 04-23-2018 at 10:05 AM.. Reason: Wrong credits to a person |
05-15-2018, 07:32 AM | #43 |
Rep 16,083
