BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F32 changed to M4 seats
Studio RSR
      07-07-2018, 07:42 AM   #89
Who?
Who?'s Avatar
Australia
485
Drives: F87 LCI
Hey David, I’ve just installed the m4 zcp seats on my m2, and currently getting the driver restraint malfunction
I tried searching for the code on bimmerlink, but the code doesn’t seem to show up there?
Do you by any chance know how to replace the airbag on the zcp seats? The two holes don’t let it separate like the regular m4 seats
Thanks mate
So far: 200cell downpipe, custom exhaust, lifhtweight splitter, m4 comp seats
      07-07-2018, 10:00 AM   #90
IK6SPEED
Drives: BMW M3 / AH3
Thanks mate
Same procedure regardless
https://www.newtis.info/tisv2/a/en/f...234/1VnXvT1ZoS
      07-09-2018, 04:20 PM   #91
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Thanks mate
Hello
did you succeed ?
      07-09-2018, 06:28 PM   #92
Who?
Who?'s Avatar
Australia
485
Drives: F87 LCI
Originally Posted by david51 View Post
Hello
did you succeed ?
yeah mate, started replacing all the parts from the original until it worked
      07-09-2018, 09:50 PM   #93
david51
david51's Avatar
France
538
Drives: bmw M3 F80
      07-19-2018, 05:58 AM   #94
Cyanfall
Cyanfall's Avatar
42
Drives: 2017 f32 440i coupe
Why did you change both front seats since you only sit in one
      07-19-2018, 11:34 AM   #95
Mousejunior
Mousejunior's Avatar
Drives: 2018 M4 SMB 6MT
2018 BMW M4  [0.00]
good point. I guess it looks better in pairs
      07-25-2018, 12:46 AM   #96
s2kvee
Drives: 2008 BMW E90 M3
I just did a similar installation today, however it was M3 seats on to my F30. Specs were the same. so it was almost a direct plug and play...
everything worked until i noticed the driver seat height adjustment didn't do anything but make noise. turns out the motor mount was broken and i had to swap it over. but after plugging in everything and testings its functions. The seats all function fine, only to realized I lost my climate control, seat heater button, my TPM went off, car started idling weird (like misfiring) and got a bunch of malfunction code like chassis stability, SRS Airbag.
The m3 set of seats came from a wrecked car, the seat belt buckle did deploy but airbags did not (luckily). I swapped over my seat belt receiver and plugged it all up. Took me about 10 minutes to figure out why all the malfunctions, i looked on some forums and alot of people say you have to swap over everything including srs airbags which is incorrect. I ONLY SWAPPED OVER THE DRIVER SEAT CONTROL MODULE BOX (LARGE GREY/BLACK RECTANGULAR BOX) and everything went back to normal. NO SRS codes, no malfunctions no weird idles, and Climate control came back as well. I didnt even bother to disconnect the battery swapping over the box. It automatically cleared the fault codes.
So far i love the seats, Looks awesome and feels softer than my original dakota leather. Sadly i only installed 75% of them, i left the rear seat backs original because my passengers need that cup holder.. lol
2008 E90 M3 6-Speed - Sold
2013 F30 335i MSport 6-Speed - Current
      12-11-2018, 07:08 PM   #97
KelvinT23
Drives: F30
F80 to f30 seats conversion
Hi david51, i'm new here.. recently retrofitted a f80 M3 seats into my f30. However im not sure how to make the badge at the seats illuminate. I've gone through the tread but not quite understand the diagram. Do u have any actual picture of where i should work about the wiring? Thanks
      12-31-2018, 12:33 PM   #98
gilbepichi@gmail.com
Drives: Bmw 435i 2014
Originally Posted by Mousejunior View Post
Just wanted to post all the pictures back to this thread. So I got everything to work. Basically have to reuse the original airbag and electronic control module then everything works. I even connect the M to light up. Any questions feel free to questions me. Thanks to david51 for all your help with this project.
Hey my friend I’m in the process of doing the same in my f32 but can you tell me step by step in order what I need to do and also I have all the m4 Herman kardon sound system from a m4 and I will like to know if it is just plug and play in my car or if a need to do don’t else like Change wiring Oe modify mine
      03-09-2019, 03:54 PM   #99
punisher12b
Drives: 2011 135i
Holy thread revival... ? If i have access to Reingold / Ista P and Ista D...
Do I need to swap anything over?? and where are yall finding your seats?
      03-12-2019, 12:41 AM   #100
Unique_Username
Drives: '16 F87
Here are the reference of BMW connectors
61130005198
61130005197
61131393723
You can use the original bmw quick coupler
61138364566
https://www.ecstuning.com/b-genuine-...n/61138364566/
Regarding the illuminated seat logos:
For the cable from X173*9B to X14*1B, do I need female MQS Fakra Pins on both sides or is the FEM side male?
Also, I don't understand the purpose of X719*1B. Can someone please explain?
I assumed that the ground connection of the illuminated logo already exists via the big yellow connector?!
      03-25-2019, 05:36 PM   #101
mat9
Drives: 428i
Hey everyone, just did the swap before finding this thread so the airbag error light got triggered. After reading all this, I swapped both airbags and seat modules but the errors remained on both the driver and passenger sides. I disconnected the battery to try and clear them with no luck. Is there anything else I need to do or are the errors supposed clear themselves?
      03-26-2019, 09:51 PM   #102
Mousejunior
2018 BMW M4  [0.00]
You will need to clear them out. Disconnect the battery won’t helps.
      03-26-2019, 10:41 PM   #103
mat9
Drives: 428i
You will need to clear them out. Disconnect the battery won't helps.
Do you know who might be able to do this for me besides the dealer? I tried some standard obd ii scanners but they couldn't clear them...
Thanks!
      04-02-2019, 10:12 PM   #104
Mousejunior
2018 BMW M4  [0.00]
Thanks!
Pretty sure you can pay someone for a small fees to clear them out. I paid $20 cad to have mine cleared out last year.
      04-10-2019, 03:42 PM   #105
lomax83
Drives: F31 335d
Hi, sorry to hijack the thread. But I am going to be installing m3 seats into my f31. The seats are manual, but could I just still plug them in? I am getting myself a bit confused with all these wiring diagrams. I need an idiots guide lol.
      05-01-2019, 10:01 AM   #106
lefthander
Drives: BMW F30
My f30 has electric seat but no heated or lumbar support.
I bought a pair of electric m3 seats with lumbar and wing support. How do I get lumbar support to work? Any help is appreciated.
      05-11-2019, 12:27 AM   #107
sactown M
Drives: 2015 435i M Sport
Hypothetically, would you be able to swap out seats in one F32 to another without any issues? Has anyone done this?
I'm looking to swap out a black interior to a grey one, I haven't seen anything in my search. Help would greatly be appreciated
      05-11-2019, 11:37 AM   #108
jimmy89045
jimmy89045's Avatar
Drives: 435i
Yes, no reason this won't work. You'll need to code new airbags or you'll have a light on. Other option is to disconnect battery and swap original airbags and control modules as instructed above. I swapped m4 seats in my 435i without coding or issues
      05-12-2019, 11:05 PM   #109
sactown M
Thanks Jimmy, so just so I get this straight...disconnect the car battery, swap out the seats (is there a cable to disconnect under the seat), change some codes on bimmercode and there should be no problem...
      05-20-2019, 04:35 PM   #110
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Drives: F32 435ix MSport
David51 - sent you a PM
