01-10-2017, 07:41 PM | #221 |
Rep 2,083
Nothing yet?
01-10-2017, 08:57 PM | #222 |
Rep 1,499
Sorry for the delay but I wanted to give it some time to prevent any placebo effect. So here is my official review....
PROS: Fairly inexpensive, easy to install, app is easy to use CONS: I don't know if I have a defective unit but my butt dyno doesn't feel any difference and I think I would with a +30 hp and +40 tq. Additionally, since I've been running the Sport I've noticed a bit of a hesitation on acceleration after a cold start. Doesn't seem to happen after the engine is warm so I don't know if running the Sport+ is the culprit. I'm going to remove the Sport over the weekend and see if the issue goes away. I did do some data logging on a stop and go traffic commute home for the hell of it. I've posted the graphs below. One thing I noticed is after hard acceleration a/f ratio can get close to 30. I'm a bit of a noob, but think this may be an issue. If you look at the graph, as boost builds and thus intake manifold pressure, mass air flow rate and vehicle speed the a/f spikes shortly after. It's almost as if the DME is not quite fast enough to compensate for the extra boost and extra air resulting in a lean mixture. The way I understand the Sport works is by tricking the DME into thinking it is running 3 psi less boost so it compensates by adding boost then a/f goes wack and it has to compensate for that. A/F normalizes around 14.5 but the data shows spikes close to 30. I want to take some time over the weekend to do some data logging in spirited driving conditions on some canyon roads to get some good data in Sport+, Sport, normal and valet mode then compare it to a stock (remove the Sport) baseline. See the graphs below. X-axis is in seconds. Data logging via LELink BLE OBD-II OBD2 Car Diagnostic Tool and OBD Fusion App on iPhone.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids Last edited by JaredG_F30; 01-11-2017 at 04:46 PM.. |
01-12-2017, 02:25 AM | #223 |
Rep 931
Best test for my point of view are :
0-120mph -> STOCK 0-120mph -> +3psi Same road, same day. Just wait 1 or 2 mile in order to do an adaptation.
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
01-12-2017, 01:02 PM | #225 |
Moon Parasite
654
Rep 1,336
May not have access to higher octane petrol.
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged |
01-15-2017, 10:36 AM | #226 | |
Rep 931
AudiA4647.50 |
01-16-2017, 12:26 PM | #227 |
Rep 1,499
Sorry guys but I didn't get to do any data logging this weekend. I spent all weekend under the hood of my wife's car replacing a bunch of stuff and included removing the intake manifold which is a PITA.
no 93 octane here in CA.
01-18-2017, 01:43 AM | #228 |
Rep 931
OK
Tnx!
01-22-2017, 01:26 PM | #229 |
Rep 289
Dinan--Why does the app require GPS to run in the background?
'17 i8 Protonic Red Edition; '17 “30 Jahre” M3
'90 Z1 Red w/red/black leather, GC coilovers, Alpina Dynamic DS-02 '91 850i Mauritius Blue/Black, BBS RS-GT '85 M635CSi Alpine w/buffalo; '03 M3 Conv, Imola ‘85 323i Baur; ‘02 X5 4.6is Estoril; ‘95 Racing Dynamics K30.4 |
01-22-2017, 04:59 PM | #230 | ||
Rep 1,476
Drives: 2022 G01 X3 M40i (Black/Black)
2022 G01 X3 M40i (Black Sapphire/Black), HK, DAP, PAP, Shadow Line
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust 2006 E90 330i (Silver) 6MT, Sport |
01-23-2017, 08:14 AM | #231 |
Rep 3,129
01-29-2017, 06:11 PM | #232 |
Rep 289
IOS 10.2. Info in the App Store states that it will run GPS in background.
02-01-2017, 08:26 PM | #233 |
Rep 1,499
OK finally got around to doing some data logging with direct comparisons with DS set at 3.0 PSI, normal and with the DS removed. Good news is AFRs look good and mimic what happens when stock. I basically figured out the spike in AFR happens when you lift off the throttle, durrr. Under throttle AFRs are in a good range in all modes. With back to back comparison, the car definitely feels faster with more available torque down low. Is it worth $300. Maybe. If you want a little extra get up and go that is easy to uninstall (if you have warranty concerns) and don't plan FBO with tune then its a good buy. If you want to go FBO with tune then skip it and get a charge pipe.
02-01-2017, 09:38 PM | #234 | |
Rep 1,476
02-03-2017, 02:00 AM | #236 | |
Rep 931
+30cv over stock are real ? Any data like 0-100mph / 0-130mph ?
02-03-2017, 02:25 PM | #237 | |
Rep 1,499
I haven't been to the drag strip so I don't have that data and not going to risk it on the street
02-03-2017, 08:43 PM | #238 | |
Moon Parasite
654
Rep 1,336
02-04-2017, 08:03 AM | #239 |
Rep 1,476
Looks like a nice run. How would that compare to stock (non Dinan Sport)?
02-05-2017, 02:28 AM | #240 |
Rep 931
this is 435i MPPK stock with classic 340cv
Year 2014
02-05-2017, 07:12 AM | #241 | |
Moon Parasite
654
Rep 1,336
AudiA4647.50 |
02-09-2017, 01:01 PM | #242 |
Rep 1
Any potential for Voiding Warranty?
Hi Everyone
I'm relatively new here and might have been discussed previously. I have a 2015 428 convertible. I want to get this installed but wondering if mod would be traceable when I take the car in for an oil change for example. (of course I would take out the tuner before I take it BMW service) Basically I want to get this and avoid losing my warranty coverage. |
