03-17-2018, 04:07 PM | #1 |
Rep 268
F30 Paddle Shifter Failure
Struggled to find anyone who has had this issue via google so thought I would ask here. I noticed a couple of weeks ago my down shifter wasnt working. The up shifter was fine. I took my air bag off yesterday to check connections, everything seemed fine. Today niether of them are working! Does this seem like it could be an issue with the little steering wheel loom behind the air bag. Triptronic on the gear shifter is absolutely fine.
Cheers all. |
03-17-2018, 10:21 PM | #2 | |
Rep 10,473
03-25-2018, 04:30 AM | #3 |
Rep 268
I believe it does share a connection. I purchased a new loom for the shifters from BMW and tried another down shifter and still nothing. Up always works. Down is dead.
03-25-2018, 12:13 PM | #4 |
Rep 10,473
If you tried another down shifter and still dead, and the down shifter plugs into up shifter, than the issue is clearly in the up shifter.
03-25-2018, 02:18 PM | #5 |
Rep 268
Do you think it could be that? I never thought the up shifter could be to blame as it has always worked. I'll swap it back to the standard msport one tomorrow and report back.
03-25-2018, 08:31 PM | #6 | |
Rep 10,473
The up then passes BOTH SIGNALS on a bus. The up is working, so the wiring is working. Obviously the UP isn’t passing through the commands from the down shifter, as you have tried another down shifter. That’s really the only thing left as you have eliminated the other obvious factors. Last edited by IK6SPEED; 03-25-2018 at 08:38 PM.. |
04-01-2018, 03:17 AM | #7 | |
Rep 268
04-01-2018, 04:55 AM | #8 | |
Rep 10,473
As you can see from diagram and I have attempted to tell you, if the up paddle is working, it’s not the wiring to the steering column cluster or subsequent wiring to the FEM. |
Revoltos52.50 |
04-01-2018, 01:39 PM | #9 |
Rep 268
Thanks for the diagram. It does seem a simple setup. I have put a new steering wheel loom in and tried another set of shifters but there has been no change. I understand the circuit sends two signals via a resistance change in the circuit. Each shifter creates a different resistance. Im wondering if its the FEM or the gearbox shift control module that interprets the signal then passes it on? There are other failure points in tbos setup.
04-01-2018, 06:51 PM | #10 | |
Rep 10,473
david51 |
04-02-2018, 07:38 AM | #12 |
Rep 878
04-02-2018, 07:50 AM | #13 |
Rep 10,473
04-02-2018, 03:02 PM | #14 |
Rep 268
I put my original set of m sport shifters back on. They worked fine up in till the day I swapped them for F80 ones. The F80 ones worked fine for months and then the down stopped working. Putting my old ones back on (also with the battery disconnected as I had the airbag out) did not sort the issue. To have two sets of paddles fail is very unlikely.
04-03-2018, 02:48 PM | #15 |
Rep 2,653
Had the same issues with my paddles. BMW replaced these parts under warranty:
61-35-8-707-674 - Front Control Unit 61-31-9-351-143 - Switch Unit Steering 32-30-6-854-771 - Connecting Line, Steering |
04-04-2018, 11:38 AM | #16 |
Rep 268
Bloody hell. It would appear BMW fired the parts cannon at the problem then XxThe_RemedyXx? Did they give any information to you regarding why they changed the loom, the szl and the control module?
09-10-2018, 12:06 PM | #17 |
Rep 963
Any solution to this? I am having a different issue but still with only the down shift.
I installed F80 paddles back in June and have had zero issues until last week. Now, at random times when I click the downshift, it downshifts twice instead of once... very annoying especially when trying to go from 3 -> 2 and instead it jumps from 3 -> 1. I've checked to see if it's getting stuck or if I'm holding it too long, but it seems completely random. At this point, wondering if the wiring is going bad... |
10-05-2018, 01:04 PM | #18 | |
Rep 963
Bump, still getting this issue although even more sporadically. Sometimes it doesn't happen for days - enough that I feel comfortable that the problem is gone, and then all of a sudden it will happen - keeps catching me off guard. It has yet to fail entirely though, so not like the signal is not being received... |
10-05-2018, 05:49 PM | #19 | |
Rep 10,473
10-06-2018, 11:18 AM | #20 |
Rep 1,572
Does your shifter (not the paddles) work correctly for both up and down shifts when in Manual mode? I had a similar issue on my 08 E90 335 and the cause was several broken/frayed wires in the shifter harness. See this thread for reference: https://www.e90post.com/forums/showt...ghlight=Orion4
10-07-2018, 08:10 AM | #21 | |||
Rep 963
I'm not sure how to go about isolating which part of all the electronics is the problem. Other than just swapping out harnesses and paddles. Quote:
2018 Azurite Black F80 M3 ZCP
2019 Phytonic Blue G05 X5 2013 Glacier Silver F30 335i (sold) |
10-07-2018, 12:32 PM | #22 |
Rep 10,473
